Old 04-05-2020, 06:52 PM   #1
aa_chow
aa_chow's Avatar
Drives: 2015 FR-S, 2020 Mazda 3 Sport
Trickle charger passthrough
With COVID-19, unfortunately I had to put the car to hibernate as I don't get to drive it.
First time hooking up my FR-S to a trickle charger, and "discovered" (don't know if it's known to folks here, but nothing came up when searched) a notch/pass-through in the plastic area just above the battery, on the passenger side under the wipers. See attached pictures.
aa_chow is offline   Reply With Quote
The Following 5 Users Say Thank You to aa_chow For This Useful Post:
extrashaky (04-06-2020), Irace86.2.0 (04-05-2020), joro2 (04-06-2020), Myriad (02-14-2021), sato (04-09-2020)
Old 04-05-2020, 06:58 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
it's got a fused lead closest to the battery on the trickle charger? that makes me scared for reasons i can't explain.. you always fuse the SOURCE, not the DEVICE...
Old 04-05-2020, 08:29 PM   #3
Grady
Grady's Avatar
The source is the battery! The charger is internally protected, you need protection from shorting the battery.
Old 04-05-2020, 08:30 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I don't think I ever noticed that.
Old 04-05-2020, 08:43 PM   #5
soundman98
soundman98's Avatar
No, with a charger/maintainer, the source is the wall outlet.
Unless you're powering your house from the battery
Old 04-05-2020, 09:22 PM   #6
ls1ac
ls1ac's Avatar
I hope it is a maintainer with smarts and not a simple trickle charger.
Old 04-05-2020, 10:05 PM   #7
aa_chow
aa_chow's Avatar
Yes, it’s fully automatic.
Old 04-06-2020, 11:13 AM   #8
Grady
Grady's Avatar
Those pigtails are designed to be left on the battery. The battery is a larger power source than the wall charger. Look at it this way, Everything is plugged in, short the 2 wires together, Where is the damaging current going to come from? About 2A from the charger, not enough to damage the wires, (Plus if it is a good charger it will be circuit protected) About 350A from the battery. That will smoke those wires in seconds. This is why the fuse is and needs to be close to the battery.
The Following 3 Users Say Thank You to Grady For This Useful Post:
aa_chow (04-06-2020), JoeC (04-06-2020), soundman98 (04-06-2020)
Old 04-06-2020, 12:26 PM   #9
Lim
Drives: Scion FRS 2016
What other people do?
I went yesterday and my car barely started after 6 days of standing at parking lot.
I don't have option to put external charger.
Do you need to drive it around once in a while?
I started my Subaru legacy without any issue with a good crank. Looks like FRS keep using battery a bit more. Is there way to limit use without disconnecting battery all together?
Lim is offline   Reply With Quote
Old 04-06-2020, 12:40 PM   #10
DarkSunrise
DarkSunrise's Avatar
I'd try testing your battery to see if it's still good. A lot of the chain auto stores will test your battery for free.
2022 BRZ Build
2013 FR-S Build
Old 04-06-2020, 12:46 PM   #11
ls1ac
ls1ac's Avatar
You can use a battery disconnect switch when parking for a while, But remember the car will have to relearn setting when you restart. An other option is a small solar charger, run the wire out the back of the hood and in the door to the dash. I use one on a boat during the summer. I used to use one on a tractor before I got power to the barn.
Old 04-06-2020, 01:59 PM   #12
Grady
Grady's Avatar
Solar battery maintainer will work also.
Old 04-06-2020, 03:52 PM   #13
joro2
joro2's Avatar
Drives: 2017 BRZ Premium MT (DGM)
Thanks
Never noticed that pass thru before either.
What brand/model tender/maintainer are you guys using?
I’ve also noticed my relatively new/OEM BRZ battery does not like sitting idle for even short periods of time; 2 weeks max after which I’ve experienced pretty heavy degradation/drain.
15-20 miles continuous driving tops it back up, but like everyone else on the planet right now.... COVID.
Tender / charger suggestions welcome.
joro2 is offline   Reply With Quote
Old 04-06-2020, 04:13 PM   #14
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I use Duracell Ultra maintainers. I have 1.5 and .8 amp, both are good for maintaining. I use the 1.5s on standard batt, and .8 on tiny race batt.
And the best little battery charger I've ever had had been the Schumacher. Small, lite,does all kinds of batts, and cords fit inside when not in use.
joro2 (04-06-2020)
battery
Heater trickle and speaker grille rattle LudwigMiles Issues | Warranty | Recalls / TSB 14 09-07-2017 03:56 PM
USB charger: OEM fit mals Electronics | Audio | NAV | Infotainment 4 05-15-2015 11:18 PM
water trickle noise 'n' wet floor 2_slo Issues | Warranty | Recalls / TSB 7 09-27-2014 01:16 PM
Wireless Charger (aka Inductive Charger) in the Scion FR-S PhastekSport Electronics | Audio | NAV | Infotainment 2 01-01-2013 05:46 PM
New cars and tuning...will this trickle down to the FT86 LexusFman Engine, Exhaust, Transmission 1 12-15-2011 09:58 AM
