Old 04-02-2020, 01:47 PM   #1
Gtouma
Drives: Gt86 2013
Slight vibration/shaking on idle after fixing some leaks
Hello,
I recently fixed the leaks of the Cylinder head , camshaft housing and cap (driver side ) by removing the engine then dismantling the parts along with the timing cover and chain ,
We placed all the parts correctly even i have replaced the spark plugs , new engine/ transmission mounts with new ones,
However now there is a light vibration which is exactly the same to the typical cold start vibration but it doesn't go away even if the car gets warm,
There is no CEL or error codes and the car drives normally fine ( i have been driving for around 1500km) and RPM is stable on idle the car just shakes ,
I have doubled checked if everything was installed correctly like all sensors , timing chain, wiring and solenoids ect. , but the issue is still there,
2013 stock manual transmission
driven 75,000KM
Please i need your support,
Thank you
Gtouma is offline   Reply With Quote
Old 04-02-2020, 02:12 PM   #2
p1l0t
p1l0t's Avatar
If you are super confident about the internal work then maybe it's the mounts?
p1l0t is online now   Reply With Quote
Old 04-02-2020, 05:10 PM   #3
Gtouma
Drives: Gt86 2013
I have changed the mounts to new ones ��
Is it the timing chain ? But an CEL would come out ?
Old 04-02-2020, 07:09 PM   #4
p1l0t
p1l0t's Avatar
That's what I'm saying though in a modern car with no CELs the culprit to me would be the mounts. Did you scan for pending codes?
Old 04-02-2020, 08:30 PM   #5
Welcome to our forum -
Did you replace the motor mounts with OEM mounts or some after market mounts that you might as well have welded the engine to the frame?
If so, like ol @p1l0t eluded to, you might consider checking the mounts and make sure you didn't put them in on the wrong side or upside down or backwards or tightened them up too tight of not tight enough.
Old 04-03-2020, 07:16 AM   #6
Gtouma
Drives: Gt86 2013
Thank you for the replies,
Yes i have doubled checked if the mounts are placed correctly and even scanned the car couple of times and no errors appeared 😭
Old 04-03-2020, 04:42 PM   #7
hmmm.....OK, let's check in with @steve99 , he is pretty smart about these things -
Old 04-06-2020, 06:11 AM   #8
steve99
Drives: FT86
Do you have a diagnostic tool that can monitor AFR fuel trims intake mabifold pressure\vaccuum and possibly intake and exhaust cam timing.
Id check carefully for intake or exhaist leaks as well, but i suspect it may be an assembly issue like cam sprokets one tooth out or similar.
Valve spring recalls, bumping idle, low mileage, leaks, dealership, OH MY.. MuseChaser Issues | Warranty | Recalls / TSB 7 11-17-2018 03:06 PM
Vibration when idle Mattstermh Issues | Warranty | Recalls / TSB 27 07-27-2016 12:12 AM
Engine shaking/vibrations at 1700rpm - when in neutral/idle kharn83 Issues | Warranty | Recalls / TSB 9 11-07-2013 10:00 PM
ECU replaced. Still has slight misfire, rough idle xomp Issues | Warranty | Recalls / TSB 1 11-01-2012 08:53 AM
Severe Shaking while in Idle from 0-5 mph ScionFR-S Engine, Exhaust, Transmission 1 10-15-2012 09:42 PM
