Old 03-29-2020, 04:41 AM   #4257
BanhMi
Drives: 2016 FRS
What size tires would you guys recommend for 18x9 +30? I’m lowered by about an inch
BanhMi is offline   Reply With Quote
Old 03-29-2020, 10:57 AM   #4258
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I'm running 18x9 +30 with a 245/35/18. They fit Perfectly!
I LIKE TIRES!
Vital (03-30-2020)
Old 04-01-2020, 09:13 PM   #4259
BanhMi
Drives: 2016 FRS
Just curious would 225/35/18 work? How much stretch would I be getting
Old 04-01-2020, 10:21 PM   #4260
Vital
Drives: 2015 BRZ
Will it work, yes. Should you do it, no. There will be a noticeable amount of stretch. Stick to the 255/35 or 245/35
The Following User Says Thank You to Vital For This Useful Post:
Leonardo (04-01-2020)
Old 04-01-2020, 10:22 PM   #4261
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, but I would suggest a 225/40/18 instead. It will be closer to OEM diameter, there are way more options, and it will be a bit less of a stretch than a 225/35. It will look stretched. My 245/35 is barely stretched imo.
I LIKE TIRES!
Vital (04-02-2020)
Old 04-02-2020, 05:26 PM   #4262
Snoopyjh
Drives: 2014 BRZ Limited
18x9.5 +38 with 255 35 18is poking wayyyy too much... Ive researched and everyone said it should fit i have fortunr auto 500 btw.
Am i gonna need camber to get that flushed? Or even to reduce the poke? Little poke is okay but this.. LOL
Sent from my SM-G988U using Tapatalk
Snoopyjh is offline   Reply With Quote
Old 04-03-2020, 09:36 AM   #4263
Vital
Drives: 2015 BRZ
Yes, you might need to lower the car a little more and add negative camber in the front. Idk if Fortune Autos come with camber plates or not if not then you can buy camber bolts for the front.
The Following 2 Users Say Thank You to Vital For This Useful Post:
Leonardo (04-03-2020), Snoopyjh (04-03-2020)
Old 04-03-2020, 12:44 PM   #4264
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have FA500s. They have camber plates. I am also using camber bolts. You will want -2 to - 3 front and -2 rear. You may also want rear LCA. My 18x9 +30 have the same poke (1.7mm different) as 18x9.5 +38. With the amount of negative camber I suggested, you will be flush.
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Snoopyjh (04-03-2020), Vital (04-06-2020)
Old 04-15-2020, 04:30 PM   #4265
Bowtie2bimmer
Drives: 2016 Scion FR-S
I am looking to pickup some 17x8 Avid1 AV20 +35 wheels for my FRS. The tires on my car are still in good shape (the dealer i bought it from just put new ones on) and was considering just swapping them over to the new wheels. My two questions are
1) Will the 215/45 fit the 8 rim and not look stretched?
2) since the rim is wider and offset is different, will it clear without rubbing? Car is also lowered on TRD springs
Sent from my SM-G973U using Tapatalk
Bowtie2bimmer is offline   Reply With Quote
Old 04-15-2020, 04:50 PM   #4266
N_Raged
Drives: 2019 BRZ Sport-Tech RS
1) Fits but will look stretched. I even consider the stock 215/45 to look stretched on the 7.5" Performance Pack rim.
https://www.ft86club.com/forums/show...52#post3197452
2) https://www.ft86motorsports.com/wheelitfit/
N_Raged is offline   Reply With Quote
Old 04-20-2020, 10:41 AM   #4267
H_K
Drives: '13 Scion fr-s
I was originally looking at TSW Nurburgrings and Konig Dekagrams and were told these were reps... Is this true? I thought these companies had good reputations.
Which companies aren't considered to make reps but still have affordable options for daily use and occasional track use? Are Enkei RPF1's the only real option without spending $400+ per wheel?
H_K is offline   Reply With Quote
Old 04-26-2020, 01:11 AM   #4268
LatentWagen
Drives: '17 BRZ / CBS + PP
Your 17x8.5's are rare. Anyway, 17x9 is popular. A 17x9 +45 is very close (2mm to 4mm) to the stock strut and spring, especially with a 245/40 tire. Your 17x8.5 +48 wheels should be 3.4 mm farther away from the spring perch. Try them on your BRZ and post some pics!
Since we're on lock-down I had some time to polish up the SSRs... so, um, slightly delayed with the pics, but better late than never
Still needs a drop
LatentWagen is offline   Reply With Quote
Old 05-04-2020, 01:03 PM   #4269
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
I wouldn't call TSW or Konig wheels reps. Just because TSW likes limit the distribution channels through vendors like Discount Tire direct and others probably gets them a bad rep in some eyes. Konigs certainly aren't from my opinion and fitment industries say Konig and Enkei share a very similar history. If you like the particular wheel and it fits from either of these three companies, especially from their flow formed lines, I wouldn't have problem with them or tracking them. Just because you didn't spend 2-10k on a set of wheels doesn't mean they're not an original design or good wheels.
Now my 18x8.5 Avids are true reps. I'd be leery of hard track use and they might not survive a serious pot hole, but I've got 2-3k miles on em and they're just fine and still lighter than stock. So it depends what you are going to be using them for but just trying to avoid wheels because ooo they're replicas is probably not the best reason to choose or not choose. If they look nice in the stance you have most people wouldn't know that ooo those are HRE three piece... nice wheels! Yeah the set cost half as much or as much as the car I would say that from 700-1200 a set new is the price point where below that you see lower quality and replicas.. above that price point you can be the judge whether it's worth your needs and price. Just another opinion of course
AKITA is offline   Reply With Quote
The Following User Says Thank You to AKITA For This Useful Post:
H_K (05-05-2020)
Old 05-07-2020, 01:16 AM   #4270
DonnyDang
Drives: 2018 GT86
I'm running 18x9.5 +35 wrapped with 245/35/18, with airlift 3p suspension. Will I have any clearance issues?
DonnyDang is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
