Old 03-26-2020, 09:57 AM   #15
Tokay444
Originally Posted by erebuswarrior View Post
Someone's an angry drunk lol. Why reply with a degenerate comment showing little intelligence, instead of supplying facts. I simply wanted to know if there's an easy way to tell if it's a built with forged internal's engine. Do you build FA20's? Probably not. I definitely don't, hence why I asked instead of assuming someone has "experience which is nothing." Good luck in the apocalypse with that attitude.
There's a super easy way without consulting a forum and letting the cat out of the bag about your own intelligence, or in this case, lack thereof.
LOOK AT THE DAMN INTERNALS!
The Following User Says Thank You to Tokay444 For This Useful Post:
Tcoat (03-26-2020)
Old 03-26-2020, 09:58 AM   #16
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Lol, 10 days at home and I'm about to snap. When you open the hood, what does it look like?
You're right, it does happen quite often. People spend a ton of money on a built engine and then trade it in for blue book. Happens with leases even more often.
Old 03-26-2020, 10:48 AM   #17
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Haha. That's true. My first thought is because I wasn't paying attention to current RPM and downshifted from 3-2 and it overevved to +/- 8500RPM and took it like a boss. No weird noises, no knock, misfire etc and several weeks later of daily redline abuse still no issues. RPM Limiter in tune is set to 7600 btw. I've been under the car a lot and it came with a nice passenger side oil cover plate and all sealant looked fairly new/fresh when I got it. Considering the tuned daily redline abuse its had for the past 2 years 30k miles, I'm surprised my oil Analysis doesn't show more wear and that I haven't broken anything other then throw out bearing.
You got lucky on the moneyshift, don't do that too often, it will break things.
Running it up to the redline is fine, the increase is probably just to add a soft limiter.
Don't know what you are referring to as a passenger side oil cover plate.
Nothing you mentioned makes me think your engine has been modified
Old 03-26-2020, 10:56 AM   #18
Spuds
The Dictater
Spuds's Avatar
Damn guys, cabin fever really setting in nowadays...
Old 03-26-2020, 11:28 AM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You have the builtest FA20
Old 03-26-2020, 11:29 AM   #20
Originally Posted by 86TOYO2k17 View Post
Everyone at minimum redlines multiple times a day, its what the car was built for.
Most manual drivers will downshift into high RPM by accident several times in an engines life with no real issues for 100k+ miles.
God I hate this assumption! My FRS saw redline maybe 10 times in the 6 years I owned it. There simply is little opportunity to drive the crap out of it for no apparent reason on the streets. I bet I am not the only one in that boat either. We don't all hammer at it even if what it was "built" for.
I think the last time I accidently over rev down shifted half the people on this forum were not born yet.
Dadhawk (03-26-2020), humfrz (03-26-2020), NoHaveMSG (03-26-2020), x808drifter (03-26-2020)
Old 03-26-2020, 11:52 AM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Unless I am at the track very rarely does mine see redline.
Old 03-26-2020, 11:57 AM   #22
86TOYO2k17
Drives: 2017 toyota 86
You’re doing it wrong then.
The Point was the car can handle redlines frequently with no issues and isn’t a sign of built engine.
After driving for 50+ years and also based on your first comment, your experience and driving style I’m not surprised you haven’t over rev down shifted in a while.
Im sure the main people driving these cars are 16-36yr olds. And don’t have your experience or granny style driving and have at least over rev down shifted at least once if they’ve put on enough miles.
The Point was engine surviving a slight over rev from a down shift isn’t a sign of a built engine.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Tokay444 (03-26-2020)
Old 03-26-2020, 12:01 PM   #23
Ahhh I don't granny shift either. There is a sweet spot between the two.
Old 03-26-2020, 12:01 PM   #24
86TOYO2k17
Go buy a Prius
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
NoHaveMSG (03-26-2020), Tokay444 (03-26-2020)
Old 03-26-2020, 12:03 PM   #25
86TOYO2k17
Granny style, not granny shift.
Like drive 60 in the left lane, never rev out rpms, take 30 seconds to get up to 60 on the on ramps etc...
Old 03-26-2020, 12:06 PM   #26
Grady
Grady's Avatar
just boost the shit out of it and see it it flies apart -
This is my vote! Let us know what PSI blew it then we will let you know if it was built or not.
The Following 2 Users Say Thank You to Grady For This Useful Post:
humfrz (03-26-2020), Tokay444 (03-26-2020)
Old 03-26-2020, 12:09 PM   #27
I drive well over the limit all the time.
I do not take 30 seconds to merge.
I can do all those without redlining.
Just because you feel a need to beat on the car does not mean it needs it to perform. You can shift just before redline with no noticeable difference in performance.
Not driving asshat style does not equate to driving like a granny.
BigTuna (03-26-2020)
Old 03-26-2020, 12:09 PM   #28
Go buy a Prius
Go buy a Corvette.
VEX Calgary built an fa20 for me and here are the results olsonpg CANADA 4 11-19-2019 01:09 PM
Built FA20 by Outfront motorsports? rixter145 Engine, Exhaust, Transmission 15 10-20-2019 04:43 PM
Built FA20 by DSport? StraightOuttaCanadaEh Engine, Exhaust, Transmission 26 08-31-2017 04:41 PM
What do you wish was built/available for the FA20 platform but is not? themajesticone Scion FR-S / Toyota 86 GT86 General Forum 14 07-14-2015 09:36 PM
what oil for BUILT MOTOR BOOSTED FA20 charged86 Engine, Exhaust, Transmission 7 02-19-2014 02:25 AM
