Old 03-26-2020, 12:50 AM   #1
erebuswarrior
Drives: 2015 Asphalt BRZ
Do I Have A Built FA20?
I'm looking for tips/info on how I might be able to check if my 2015 Limited BRZ, FA20 was built with forged internal's. I'm looking to go turbo soon and I have some suspicions my FA20 might have been built by previous owner, or it's just a really good engine/internals.
erebuswarrior is offline   Reply With Quote
Old 03-26-2020, 01:00 AM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well, is if it runs it's probably been built by someone. I don't think engines work pre-assembly.
Why do you think your engine was modified by a previous owner?
Old 03-26-2020, 01:23 AM   #3
Originally Posted by erebuswarrior View Post
I'm looking for tips/info on how I might be able to check if my FA20 was built. I'm looking to go turbo soon and I have some suspicions my FA20 might have been built by previous owner, or it's just a really good engine/internals.
Well, about the only way to tell is either tear the engine apart or contact the former owner(s).
OR, just boost the shit out of it and see it it flies apart -
Old 03-26-2020, 01:37 AM   #4
erebuswarrior
Haha. That's true. My first thought is because I wasn't paying attention to current RPM and downshifted from 3-2 and it overevved to +/- 8500RPM and took it like a boss. No weird noises, no knock, misfire etc and several weeks later of daily redline abuse still no issues. RPM Limiter in tune is set to 7600 btw. I've been under the car a lot and it came with a nice passenger side oil cover plate and all sealant looked fairly new/fresh when I got it. Considering the tuned daily redline abuse its had for the past 2 years 30k miles, I'm surprised my oil Analysis doesn't show more wear and that I haven't broken anything other then throw out bearing.
Old 03-26-2020, 01:58 AM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Yes you do. I can feel it.
Old 03-26-2020, 02:13 AM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
You mention prior red line abuse that is your guess. And your experience which is nothing. You are a stupid dumb shit. Please go away
Old 03-26-2020, 02:35 AM   #7
OK, what did I miss -
Old 03-26-2020, 02:39 AM   #8
86TOYO2k17
Drives: 2017 toyota 86
None of this indicates it was built.
Everyone at minimum redlines multiple times a day, its what the car was built for.
Most manual drivers will downshift into high RPM by accident several times in an engines life with no real issues for 100k+ miles. Especially if you downshift to high rpm off throttle. Chances are an overrev will either cause a failure or not. Meaning it isn’t breaking something 10% and then after 10times its 100% failure. It is either not really doing anything or causing a complete failure so “handling it like a boss” just means nothing happened this time. Now a money shift WOT shift at redline in 3rd to 2nd instead of 4th and rev on throttle at 9500rpm+ is a different story.
Also most built engines have more “issues” then none built oem stock engines, the fact you haven’t had any issues is an indicator it is NOT built.
Old 03-26-2020, 03:17 AM   #9
erebuswarrior
Someone's an angry drunk lol. Why reply with a degenerate comment showing little intelligence, instead of supplying facts. I simply wanted to know if there's an easy way to tell if it's a built with forged internal's engine. Do you build FA20's? Probably not. I definitely don't, hence why I asked instead of assuming someone has "experience which is nothing." Good luck in the apocalypse with that attitude.
Old 03-26-2020, 03:26 AM   #10
erebuswarrior
Thanks man. I was just curious as to what a forged internal's FA20 might look/perform like before I throw a turbo kit on and get it dyno tuned. I've never accidentally overevved an engine, and after 2+ years owning my BRZ I finally managed to do it on accident. I'm proactive on general maintenance to be on the safe side. However, I've seen people break engines doing less so Planning on 91 6-8psi, E85 with 6 PSI for daily map, E85 8-10 psi for safe power racing (360-380whp), and maybe 4th map as valet in case I need that.
Old 03-26-2020, 03:50 AM   #11
Decep
Drives: 2013 FR-S Series 10
Hmmm.. not sure. Try moneyshifting it again. If you only did it once last time, do it twice the next. The next time, do it three times. If you reach 100 moneyshifts without any failures, then, and only then do you have a truly BUILT engine.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 03-26-2020, 08:12 AM   #12
86MLR
86MLR's Avatar
Buy an endoscope on have a look.
Or, yes, from my seatbin the interwebs here in AU I can tell your engine is built and can handle 500 crank hp.
Add more boost now.
Old 03-26-2020, 09:50 AM   #13
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Your best shop is finding old registration records and contacting the previous owner. It costs so much to rebuild an engine with stronger internals that it's not likely someone would just absent mindedly forget to include in any sales pitch.
How often do you see Craigslist adds for a WRX that has a boost controller advertised as "BUILT 400WHP RACE TUNE WRX NEW CLUTCH $3,800OBO"
For a rotting pile of untuned garbage?
Your car is and will have a stock engine for a long time to come, and that's a very good thing.
Old 03-26-2020, 09:52 AM   #14
Tokay444
Anti stance.
Tokay444's Avatar
Oh dear god...:facepalm:
How would you ever get -8500rpm? Negative revs are not a thing.
VEX Calgary built an fa20 for me and here are the results olsonpg CANADA 4 11-19-2019 01:09 PM
Built FA20 by Outfront motorsports? rixter145 Engine, Exhaust, Transmission 15 10-20-2019 04:43 PM
Built FA20 by DSport? StraightOuttaCanadaEh Engine, Exhaust, Transmission 26 08-31-2017 04:41 PM
What do you wish was built/available for the FA20 platform but is not? themajesticone Scion FR-S / Toyota 86 GT86 General Forum 14 07-14-2015 09:36 PM
what oil for BUILT MOTOR BOOSTED FA20 charged86 Engine, Exhaust, Transmission 7 02-19-2014 02:25 AM
