Old 08-28-2017, 12:15 PM   #1
StraightOuttaCanadaEh
Wes
Built FA20 by DSport?
Saw this in this month's mag. Considering maybe getting one and delaying the forced induction by a year. Will allow me to run more power in the end. Probably don't need more power. Anyway, thought I'd share
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
batlwagn (08-28-2017), SkAsphalt (08-30-2017)
Old 08-29-2017, 08:34 AM   #2
celek
Resident Gear Head
celek's Avatar
So wait...
A magazine company now builds engines?
PS I can replicate those for over $1000 less then they are asking.
Any you are only like 4.5 hrs away from me
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
Williampreza (05-17-2018)
Old 08-29-2017, 08:40 AM   #3
cjd
cjd's Avatar
Drives: 2017 BRZ
Also, should be a bill of materials...
The Following 2 Users Say Thank You to cjd For This Useful Post:
Cole (08-29-2017), VerusEric (08-29-2017)
Old 08-29-2017, 09:13 AM   #4
Wes
Originally Posted by celek View Post
So wait...
One day, and this day may never come, I may call upon you to perform a service for me lol
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
celek (08-29-2017)
Old 08-29-2017, 09:14 AM   #5
Wes
like a list stating what each component costs? Cause they do have a list in the lower left side
Old 08-29-2017, 09:29 AM   #6
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
So wait...
I think the mag prices are in CAD, assuming since OP is in Canada. Comes out to be around 5800 USD. So if you CAN do it for more than 1000 less...let us know....
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 08-29-2017, 09:30 AM   #7
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
The ad said 'build of materials' instead of bill of materials.
I see a lot of red flags in this ad. I've installed shortblocks that arrive ready to go, built my own shortblocks, had local shops do drop ins, and had local shops do full builds.
I'm concerned that they are listing the same shortblock for the BRZ and WRX.
"increased...superior....improved..." What are the specs? Are they 'from the factory tolerance of X to our tolerances of Y'?
"OEM Quality forged steel crankshafts" Why not OEM?
Why not ONE bearing manufacture? 3/4 options of 'you might get one of these' is a bit concerning. Have they tested all these bearings extensively in this platform?
For two THOUSAND DOLLARS less, you can get an IAG Stage 3 FA20 shortblock, which appears to be similar/a dash better, with slightly lower CR. https://www.iagperformance.com/IAG-S...g-eng-1322.htm
The MAP build with an option here and there is $1,500 less.
What is it that magically makes this engine worth so much more? Advertisements in their own magazine? lol
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following 6 Users Say Thank You to JazzleSAURUS For This Useful Post:
cjd (08-29-2017), Cole (08-29-2017), funwheeldrive (08-30-2017), lantsalot (08-30-2017), Teseo (08-29-2017), Tristor (05-21-2018)
Old 08-29-2017, 10:07 AM   #8
Wes
Probably! That's good info, thanks.
Also a rookie question, but what exactly is a short block? If let's say I'm installing one of these built engines, is there anything else I would need?
Old 08-29-2017, 10:16 AM   #9
celek
Resident Gear Head
celek's Avatar
ClubDSPORT is in California thats USD pricing
Old 08-29-2017, 10:25 AM   #10
celek
Resident Gear Head
celek's Avatar
Here if you want to know the Bill of Materials and RETAIL costs.
OEM FB25 Crankshaft 90mm Stroke $600
Darton Mid Sleeves installed $1700
Bored and Honed sized to Piston to 89mm $400
Custom Rods $1100
Custom Pistons $800 (I can have any Compression Made)
ARP Case Bolts (NOT NEEDED) $500
Case Halves NEW $1200
Main and Rod Bearings $250
Assembly Labor $500
These are all HIGH numbers off the top of my head and exactly what DSPORT IS SELLING YOU. $7050 Keep in Mind that includes NEW Case Halves from Subaru Send me good Case halves and the price is $5850
Old 08-29-2017, 10:30 AM   #11
celek
Resident Gear Head
celek's Avatar
Short block is only the crank rods and pistons in a case, no heads
StraightOuttaCanadaEh (08-29-2017)
Old 08-29-2017, 10:40 AM   #12
Wes
So how much do the heads cost? Just trying to ballpark the cost of a built engine, all expenses considered
Old 08-29-2017, 10:44 AM   #13
celek
Resident Gear Head
celek's Avatar
Are you trying to build a complete extra engine? You could pull your own heads off and put them on the short block.
If you are trying to build another engine prepare for lots of money because you will need heads valve covers front cover chains and guides intake manifold ect....
Unless you buy a used complete engine for like $2000-2500 CAD then use those parts to build a forged engine
Old 08-29-2017, 10:45 AM   #14
JazzleSAURUS
Custom Rods $1100
Assembly Labor $500
@celek, that's your version of the FA225, as DSport lists it, correct?
What is the reasoning for custom rods and pistons as opposed to some of the off the shelf versions? To accommodate the FB25 crank?
Perhaps that block doesn't seem terribly far off since it's sleeved, but to me their motors seem pretty over priced.
What are your thoughts on the other short blocks you've seen on the market like the IAG products? I've been installing them for a few years in EJ land, but I've only had to pull one FA!
end
Ernest's Flex-Fuel, FBM Stage 2 Turbo, Built FA20-V161 Driven BRZ - PHOTON Enalband24 Member's Car Journals 78 02-04-2020 01:55 PM
What do you wish was built/available for the FA20 platform but is not? themajesticone Scion FR-S / Toyota 86 GT86 General Forum 14 07-14-2015 09:36 PM
what oil for BUILT MOTOR BOOSTED FA20 charged86 Engine, Exhaust, Transmission 7 02-19-2014 02:25 AM
DSPORT Dyno Tested Performance Products - FA20 Team STILLEN Engine, Exhaust, Transmission 7 11-13-2013 06:21 PM
