Old 03-18-2020, 09:43 AM   #4243
Vital
Drives: 2015 BRZ
Originally Posted by hpanju View Post
Any issues running a 235/45/17 tire with a 17x8 +45 rim on stock suspension?
No.
The Following User Says Thank You to Vital For This Useful Post:
Leonardo (03-18-2020)
Old 03-18-2020, 08:08 PM   #4244
carlovestela
Drives: 2015 Firestorm FRS
18 x9.5 + 41 wheels with 265/35/18 achilles tires
No rubbing issues using tein flex z coils?
carlovestela is offline   Reply With Quote
Old 03-18-2020, 09:58 PM   #4245
Leonardo
Country Boy 4 Life
Leonardo's Avatar
You should be ok with enough negative camber and possibly the rear bumper tab shaved. Totally doable 👌
I LIKE TIRES!
Old 03-18-2020, 10:35 PM   #4246
carlovestela
How many negative camber? Like -2 front -1.5 rear?
What you mean rear bumper need to shaved?
Old 03-19-2020, 12:17 AM   #4247
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I would suggest -2.5 rear, and -3.0 front front for those wheels. But, you will see when you get th on. If you only have coils, the natural rear camber may be enough, but you'll probably also want rear LCA.
The bumper tab will rub on a 265. Either shave it, or it "shaves" itself.
I LIKE TIRES!
Vital (03-20-2020)
Old 03-19-2020, 03:16 AM   #4248
Herc
Drives: GT86 HOT LAVA
Question, which is the lowest ET i could go in front?
Tein coilovers
225/40/18
8.5J
Will ET30 fit?
Herc is offline   Reply With Quote
The Following User Says Thank You to Herc For This Useful Post:
Leonardo (03-19-2020)
Old 03-19-2020, 11:19 AM   #4249
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Tein coilovers
225/40/18
8.5J
Will ET30 fit?
Yes, 18x8.5 +30 will look great with 225/40 tires and some negative camber. The lowest et for 18x8.5? (That I would suggest) Maybe +20, which will poke like 18x9.5 +33. +35 is really common for 18x9.5 wheels. You can totally run a lower offset, but I don't think that setups that require more than -3.5 front ( or very close) are great. That's a good amount of camber for AutoX. Looks great. Is functional. And won't destroy your tires instantly.
I'm running 18x9 +30 front. I have also run 18x8 +20 front. Both sizes fit with -1.5 front for me. Though I am running -2.5 front now.
I LIKE TIRES!
Vital (03-20-2020)
Old 03-25-2020, 03:12 PM   #4250
Snoopyjh
Drives: 2014 BRZ Limited
Will it fit? If anyone has knowledge on this soecific set up please help!
Rays Gram Light 57DR 18x9.5 +38 with 255/40/18 on Fortune Auto 500
Would i need to get LCAs?
https://www.fitmentindustries.com/wh...cing-coilovers
I wanted that fitment like that except the tires are 255/40 for me
Thanks!
Sent from my SM-G988U using Tapatalk
Snoopyjh is offline   Reply With Quote
Old 03-25-2020, 03:22 PM   #4251
Vital
Drives: 2015 BRZ
Thanks!
Yes it will fit. The 255/40 will be a taller tire just keep that in mind and it will affect your speedometer. You do not need LCA necessarily it will depend on how much you lower the car. Lowering the car adds camber naturally so if you go really low you will need LCAs to correct the camber if you want to get it even.
The Following 2 Users Say Thank You to Vital For This Useful Post:
Leonardo (03-26-2020), Snoopyjh (03-25-2020)
Old 03-25-2020, 03:26 PM   #4252
Snoopyjh
Do you know why some ppl might choose 35 over 40 and vice versa? I guess 40 would add to the overall height tiny bit
Old 03-25-2020, 03:49 PM   #4253
Vital
Drives: 2015 BRZ
Yes, ideally when you are upgrade tires you want to stay close to OEM specs. When you go to big it starts affecting gearing and the car can start feeling sluggish and heavy etc. People generally want lower profile tires because it helps with accleration, handling and turn-in and yes weight is a bit of a factor.
You can use a tire size calculator and see the specs for OEM vs the new size tire so you can compare specs. https://www.discounttire.com/learn/tire-size-calculator
Leonardo (03-26-2020), Snoopyjh (03-26-2020)
Old 03-26-2020, 10:33 AM   #4254
H_K
Drives: '13 Scion fr-s
Hey guys, I have a 1" lift on my car (Subtle Solutions 1" HDPE lift kit) and still running stock tires/wheels.
I'm looking to upgrade very soon and was thinking of going with something a little wider. What wheel/tire size would look good with a bit of a lift? I'm not looking for perfect fitment or anything. The lift is due to shitty roads here in Montreal and having a perfect fitment isn't ideal for daily driving here - too many potholes.
I was thinking 17x8" with 235/40 or 235/45... I know there'd still be a wheel gap due to the lift... Would I be really shooting myself in the foot by keeping the wheel diameter the same? Should I consider 18's instead? I still want a decent amount of tire sidewall to help cushion the ride a bit and prevent wheel damage when hitting inevitable potholes on these roads.
Also, what should I look for in terms of offset?
H_K is offline   Reply With Quote
The Following User Says Thank You to H_K For This Useful Post:
Old 03-26-2020, 11:21 AM   #4255
Leonardo
Country Boy 4 Life
Leonardo's Avatar
There is a lifted thread. Guys have posted all the weird sizes they have been using. I mean, I like to suggest tires that are OEM diameter.
I would suggest 16 or 17. 18s are for looks.
17x8 +35 or +40, IMO will work good with a lift.
Um... maybe a 235/45/17 or a bit taller 215/50/17. 235/45 is 2.9% larger, and 215/50 is 3.4% larger diameter... These sizes are tall, but not crazy like some of the sizes in the thread below. 215/65/16s are almost 10% larger!!!
EDIT: some guys are running WAY taller tires... Wow!
Found it!
https://www.ft86club.com/forums/showthread.php?t=105692
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
H_K (03-26-2020), Vital (03-26-2020)
Old 03-26-2020, 12:13 PM   #4256
H_K
Found it!
Thank you for the response! I will check out this thread for some inspiration
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
