Old 03-13-2020, 03:23 PM   #617
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by RuyGuy2 View Post
16x7" +35 sportline P4 Rims,
That offset looks nice...I've got 16x7 ET40, which I do love, but a little more poke would be nice too..
I'd also like to get my hands on some 16x7.5 or 8 ET35-40ish, but that seems to be a strangely difficult size to get in a 5x100 bolt pattern, and not be heavy as a brick..
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
new2subaru (03-13-2020)
Old 03-13-2020, 05:05 PM   #618
RuyGuy2
Dysentery Enthusiast
RuyGuy2's Avatar
Drives: 2017 toyota 86
Here you go. Some OG wheels here....
https://www.86worx.com/rs-watanabe-f8-16-wheel.html
RuyGuy2 is offline   Reply With Quote
The Following User Says Thank You to RuyGuy2 For This Useful Post:
Old 03-13-2020, 05:20 PM   #619
churchx
churchx's Avatar
Drives: 2014 GT86
These look heavy for 16".
And not sure that rare sizing/PCD. Wasn't it common enough for older subbies, and smaller diameter wheels more common in past? If anything rare, then offset, as again, for wheels of many older cars it often was higher, but one can easily fix/space out those tucked in wheels with spacers though.
Old 03-16-2020, 05:42 AM   #620
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
no. 16x6, 16x7 was about the widest it usually went. Anything wider was a bigger wheel. Maybe if you go back 30+ years you might find lots of really wide 16" tires, but back then they used smaller tires. The MK2 Supra came with 14" wheels and tires.
why? is offline   Reply With Quote
Old 03-16-2020, 05:54 AM   #621
churchx
churchx's Avatar
Drives: 2014 GT86
Still, light 16 in my book is more like 5.#kg (yeah, i know of TWS T66-F 16x7 of 4.82kg), 7.1 seems midweight for 16". My R17 wheels are 6.2kg
I predict that wider then 7" R16 wheels being uncommon may also mean very limited tire selection.
why? (03-18-2020)
Old 03-18-2020, 04:44 PM   #622
venturaII
venturaII's Avatar
I've always fancied the idea of 245/45-16s on a light 16x8 with an offset in the 35-40 range..
The Following 2 Users Say Thank You to venturaII For This Useful Post:
new2subaru (03-18-2020), SuperTom (03-19-2020)
Old 03-18-2020, 05:05 PM   #623
why?
why?'s Avatar
Drives: series.blue
yes at that point you need to find the tire first. Even at 205/55 you need to find a tire you want and then the wheel.
Old 03-18-2020, 05:12 PM   #624
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
The Konig Oversteer is mildly brickish at 17.9 lbs, being cast, but you get that 16x7.5" and 5x100 bolt-pattern. I've been on mine for about six years now. Paint has held up great. No chips, blisters, or scratches. Tires hold air fine.
NWFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to NWFRS For This Useful Post:
venturaII (03-19-2020), why? (03-19-2020)
Old 03-19-2020, 08:45 AM   #625
venturaII
venturaII's Avatar
Yeah, I think I recall when you first purchased yours, you posted them up in the wheel thread...they're a good looking wheel, for sure, and in a pinch (haha...see what I'm doing here?), a 245/45 will work on a 7.5" rim. It's at the bottom end of the spectrum for that tire size, but only a 1/2" narrower than the recommended standard.... If I were still on stockers, I'd certainly consider them, as I did when I was shopping. In the end I lucked out and found a lightly used set of very light weight forged 16x7 ET40 wheels (12.5 pounds) for very short money.
why? (03-19-2020)
Old 03-19-2020, 09:22 AM   #626
new2subaru
Weight Weenie
Drives: 15 FR-S
I run 16's now and with tire they're on a couple of lbs less than stock. I just found these. They're being blasted and painted shortly. 10.4lbs
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
Old 03-19-2020, 09:23 AM   #627
new2subaru
Weight Weenie
Drives: 15 FR-S
What wheels did you find again? I'm certain you've posted but can't remember.
Old 03-19-2020, 09:31 AM   #628
venturaII
venturaII's Avatar
I found an early set from Motegi's forged line...these are Forged Tracklites. I know I've posted them; I assume it was in either the wheel thread or maybe one of the 16" wheel threads? At any rate, this model isn't made any more and I was getting a little worried about putting a dent in one, since I DD with them in the summer and road conditions in New England cam be pretty bleak at times. I actually managed to score a second set for similarly short money. So I street one set, and the other have my track tires on them for the time being, until the inevitable happens...
The Following 3 Users Say Thank You to venturaII For This Useful Post:
new2subaru (03-19-2020), NWFRS (03-19-2020), why? (03-19-2020)
Old 03-19-2020, 09:41 AM   #629
RuyGuy2
RuyGuy2's Avatar
Yes, me too.
Old 03-19-2020, 11:47 AM   #630
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
225/50 with a 16x8 +30. Or maybe something from Subaru with a +55 offset and stick a meaty 25mm spacer on there.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 04:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 06:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-27-2012 11:20 PM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 08:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 11:17 AM
