Old 01-29-2020, 11:09 AM   #253
HaXx
Drives: jrsc_brz
Originally Posted by YamahaR86 View Post
@89_Manny
I would go with a Sylvania brand yellow bulb. Don't recommend putting yellow HIDs in there as it scatters the light and is unusable.
this sounds awesome, link please? ive never upgraded my lowbeams, just my fogs so forgive me i dont know what im doing.
HaXx is offline   Reply With Quote
Old 01-29-2020, 11:24 AM   #254
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Not sure on the sizing but something like this:
https://www.amazon.com/dp/B079ZBWVSF..._DeBmEbBN0KVJP
You can also tint your headlights yellow if you like that look.
I worked with retrofitting headlights for a while now. HIDs in a halogen projector is ok, but still not good. The main component to a good light output is good projectors.
I retrofitted some morimoto projectors in, threw in some cheaper HIDs and the light output/crisp cutoff line is far superior.
Clueless
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
HaXx (01-29-2020)
Old 02-19-2020, 07:38 PM   #255
HaXx
Drives: jrsc_brz
I'm looking to put yellow bulbs in my 13+ brz drl. The horizontal drl beneath the headlight housing. Anybody got any recommendations? Or should I tint the lens? I'm looking for the more quality option
Old 02-23-2020, 03:44 PM   #256
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
They are LED, so there are no replaceable bulbs. You would likely have to try to unglue the DRL lens from the backing then desolder the LED's from a circuit board then solder new ones on.
It seems that most people paint theirs to get the yellow look. Laminex film will probably have a hard time wrapping around the curved parts of the lens.
Old 02-23-2020, 04:25 PM   #257
HaXx
Drives: jrsc_brz
yeah i found out through continued researching that u cant change those bulbs, and i dont want to wrap it and have it look like crap and fall off, so i just gave up on that idea haha
Old 02-28-2020, 01:45 AM   #258
Blessed_frs
Blessed_frs's Avatar
Drives: Blessed (idk it’s black?)
I have Vland headlights, and the LEDs I ran with them made it so that the back cover of the light could not fit on. I was also missing a fender liner around this time so you can assume what happened next. Some water got sprayed up into it and the DRL stopped working. Every other aspect of it works. How can I fix this?
Blessed_frs is offline   Reply With Quote
Old 02-28-2020, 09:49 AM   #259
Circa85
Drives: 2017 Toyota 86
Does anyone know if the 4 hole to 3 hole adapter plates that come in the 2017+ Toyota Fog light OEM kit have a part number and are available separately? I want to piece the kit together since I want to use Morimoto XB yellow foglights instead of buying the kit and selling the OEM fogs.
Circa85 is offline   Reply With Quote
Old 03-07-2020, 10:40 AM   #260
Suparu
Drives: 2013 BRZ Limited
I’m going to open up my headlights to black out the housing. What should I use to reseal the headlight after I’m done?
Suparu is offline   Reply With Quote
Old 03-07-2020, 11:26 AM   #261
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
Some people reuse the original sealant.
If you want to do it 100% buy “headlight butyl” from www.theretrofitsource.com and either clean out the old stuff and reuse the new stuff or add a thin bead of new stuff to the existing sealant.
-B
HeresMyMind is offline   Reply With Quote
The Following User Says Thank You to HeresMyMind For This Useful Post:
Suparu (03-08-2020)
Old 03-07-2020, 02:14 PM   #262
soundman98
ProCrastinationConsultant
soundman98's Avatar
you're in atlanta. go TO The Retrofit Source, and get some headlight butyl. depending on how nice you are, they might even be willing to seal them up for you.
ask for jamielle or nick, and tell matt he sucks if he doesn't have an open house this year!
Suparu (03-08-2020)
Old 03-08-2020, 09:28 AM   #263
Suparu
Thanks for the recommendation! I had no idea such a place was in town, I’m going to stop by and check out the shop.
Old 03-12-2020, 05:15 PM   #264
raffy_vor_lengg
raffy_vor_lengg's Avatar
Hi all,
Has anyone been able to open the Vland Headlights? Which temperature do you use for baking?
It seems that more heat is needed as for the OEM ones...
Any help is apreciated.
Kind regards from Switzerland
Raffy
raffy_vor_lengg is offline   Reply With Quote
Old 03-12-2020, 07:31 PM   #265
Irace86.2.0
Originally Posted by raffy_vor_lengg View Post
Hi all,
Raffy
I have not tried opening these headlights. I have done several of OEM headlights of different cars.
What are you using? I typically use around 200F/100C. You might need to try to pry them apart in the beginning then put them back in for five minutes and try again then do it again. Maybe have someone help with a dryer or heat gun (on low), while you pry, and just make sure there are no retaining screws.
The thickness of the plastics are probably cheaper than OEM, so just be careful prying.
Old 03-12-2020, 07:54 PM   #266
Irace86.2.0
When you say DRL, do you mean the boomerangs, and if so then how was the boomerang operating normally? Was it always on, or did they come on with the parking lights only, or did they come on with the headlights only, or did they come on with the parking lights or headlights, but not when the stalk is turned to Off? And now it never comes on, right?
I can only imagine that there is a short or damage to the circuit board.
The headlights really aren't designed for LED headlight bulbs, as you now realize, so have you removed the ones you bought and put back on the cap?
OEM foglight install question DarkSideFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-12-2017 03:21 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 08:56 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
