#253 | |
Drives: jrsc_brz
#254 | |
JDM Vaping Stance Nation
Drives: 2013 White
https://www.amazon.com/dp/B079ZBWVSF..._DeBmEbBN0KVJP You can also tint your headlights yellow if you like that look. I worked with retrofitting headlights for a while now. HIDs in a halogen projector is ok, but still not good. The main component to a good light output is good projectors. I retrofitted some morimoto projectors in, threw in some cheaper HIDs and the light output/crisp cutoff line is far superior.
Clueless
| The Following User Says Thank You to YamahaR86 For This Useful Post: | HaXx (01-29-2020) |
#255 |
Drives: jrsc_brz
I'm looking to put yellow bulbs in my 13+ brz drl. The horizontal drl beneath the headlight housing. Anybody got any recommendations? Or should I tint the lens? I'm looking for the more quality option
#256 | |
Drives: Q5 + BRZ + M796
It seems that most people paint theirs to get the yellow look. Laminex film will probably have a hard time wrapping around the curved parts of the lens.
#257 | |
Drives: jrsc_brz
#258 |
Drives: Blessed (idk it’s black?)
I have Vland headlights, and the LEDs I ran with them made it so that the back cover of the light could not fit on. I was also missing a fender liner around this time so you can assume what happened next. Some water got sprayed up into it and the DRL stopped working. Every other aspect of it works. How can I fix this?
#259 |
Drives: 2017 Toyota 86
Does anyone know if the 4 hole to 3 hole adapter plates that come in the 2017+ Toyota Fog light OEM kit have a part number and are available separately? I want to piece the kit together since I want to use Morimoto XB yellow foglights instead of buying the kit and selling the OEM fogs.
#260 |
Drives: 2013 BRZ Limited
I’m going to open up my headlights to black out the housing. What should I use to reseal the headlight after I’m done?
#261 | |
Drives: 2013 WRB BRZ Limited
If you want to do it 100% buy “headlight butyl” from www.theretrofitsource.com and either clean out the old stuff and reuse the new stuff or add a thin bead of new stuff to the existing sealant. -B |
| The Following User Says Thank You to HeresMyMind For This Useful Post: | Suparu (03-08-2020) |
#262 | |
ProCrastinationConsultant
ask for jamielle or nick, and tell matt he sucks if he doesn't have an open house this year!
| The Following User Says Thank You to soundman98 For This Useful Post: | Suparu (03-08-2020) |
#263 |
Thanks for the recommendation! I had no idea such a place was in town, I’m going to stop by and check out the shop.
#264 |
Hi all,
Has anyone been able to open the Vland Headlights? Which temperature do you use for baking? It seems that more heat is needed as for the OEM ones... Any help is apreciated. Kind regards from Switzerland Raffy |
#265 | |
What are you using? I typically use around 200F/100C. You might need to try to pry them apart in the beginning then put them back in for five minutes and try again then do it again. Maybe have someone help with a dryer or heat gun (on low), while you pry, and just make sure there are no retaining screws. The thickness of the plastics are probably cheaper than OEM, so just be careful prying.
#266 | |
I can only imagine that there is a short or damage to the circuit board. The headlights really aren't designed for LED headlight bulbs, as you now realize, so have you removed the ones you bought and put back on the cap?
| OEM foglight install question | DarkSideFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-12-2017 04:21 PM |
| FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides | Verge | Exterior Parts (Aero, Lighting, Etc.) | 12 | 11-21-2014 09:56 PM |
| Automation Lighting offers HID xenon headlight + foglight kits | jjdrivesajazz | Exterior Parts - Lighting | 138 | 01-13-2014 02:19 AM |
