Old 06-09-2017, 12:59 PM   #1
DarkSideFRS
Drives: 2013 pearl white FR-S
OEM foglight install question
I was reading up the OEM foglight install DIY and I believe the OEM fogs can only turn on when the headlights are on, correct?
How do I wire it so that it can turn on/off whenever I want it to? I've seen the DIYs for the winjet fogs that does this, but not for the OEMs. These are the DIYs I have been reading up on:
http://www.ft86club.com/forums/showthread.php?t=40153
http://www.ft86club.com/forums/showthread.php?t=27581
DarkSideFRS is offline   Reply With Quote
Old 06-12-2017, 11:41 AM   #2
DarkSideFRS
nobody?
Old 06-12-2017, 01:31 PM   #3
Not sure how the wire harness is but you could just find the hot wire and run it separate from the rest of the lights. That way the switch would be a simple on off.
Old 06-12-2017, 03:21 PM   #4
DarkSideFRS
here's the harness (pix from 1st thread I posted)... i'm not an electrical guy, so i have no idea how to look for the hot wire...
it connects to an existing harness based on this picture...
DIY: iJDMTOY LED DRL Foglight Bezel Install JDM FRS DIY (Do-It-Yourself) Guides 17 05-20-2019 01:43 PM
FRS Winjet Foglight red wire install klearfade Cosmetic Modification (Interior/Exterior/Lighting) 14 06-23-2017 05:11 PM
Winjet foglight install. TheGuyWithTheFireStorm Northern California 0 12-16-2015 01:20 AM
Question for BRZ owners with factory rear foglight P3tras BRZ First-Gen (2012+) — General Topics 1 07-09-2015 07:34 AM
Frs lip install question Kai Uhl Cosmetic Modification (Interior/Exterior/Lighting) 4 07-21-2014 09:39 PM
