Drives: Scion FR-S
Weird tick sound came from no where(not a rod knock)
Whenever I accelerate forward or backwards, there's a ticking sound that starts at 1000 to 2500 RPMs, then disappearsnpast 2500 and sounds normal up to redline. If I rev it slow, the tick is not there. If I rev it fast, it's there but disappears at 2500 RPMs.
When I do a cold start every morning, the ticking sound is there, but disappears exactly after 40 seconds every time then sounds normal during idle. I don't have crickets or chirps during idle and my oil level is perfect. My belt is also installed properly. What could this be?! FRS. 57k miles. |
#2 | |
Drives: 2017 toyota 86
#3 |
Drives: Scion FR-S
#4 | |
re-torquing might fix it, but could be a faulty gasket needing replacement. is your exhaust manifold stock? |
#5 |
Drives: Scion FR-S
Yes it is stock, and the engine was recently put back, then the sound happened. Then the sound happened. You think the gaskets got fucked during removal? What are the odds?
#6 |
Drives: Scion FR-S
Yes it is stock, and the engine was recently put back, then the sound happened. You think the gaskets got fucked during removal? What are the odds?
#7 |
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
The odds of the gaskets getting fucked during removal are around 50%. If the mechanic reused the removed gaskets the odds of him being a shitty mechanic is 100%.
#8 |
Drives: Scion FR-S
#9 |
Yup sounding more and more like gasket. Its the easiest, cheapest, and quickest fix out of the most likely possibilities. So i would start with that and hope its not the others. Get a new set of gaskets, swap um out. Check torque spec, do at least one full heat cycle, then re torque. If fixed good. If not troubleshoot more.
#10 | |
Drives: Scion FR-S
Thank you for everything. I owe you one. |
#11 |
Drives: 2013 FR-S Series 10
Yeah that was a pretty impressive internet diagnosis
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#12 | |
| Does this sound like 'tip-in knock'? | 1Cor10:23 | Engine, Exhaust, Transmission | 48 | 04-02-2016 01:06 AM |
| Weird CEL. Boost related? P0327 Knock sensor. | xkalelx | Forced Induction | 0 | 02-08-2016 09:26 AM |
| Knock sound while on and off | FatFree | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 03-14-2015 08:55 PM |
| LOUD TICK-TICK-TICK sound on right hand side | PoRco | Issues | Warranty | Recalls / TSB | 16 | 07-28-2014 12:55 PM |
| Tick Click Tick (injector orgy) | empower-auto | Issues | Warranty | Recalls / TSB | 4 | 08-27-2012 02:28 PM |
