Old 03-14-2015, 07:58 PM   #1
FatFree
FatFree's Avatar
Drives: 2013 Asphalt FR-S
Knock sound while on and off
There is a knocking sound that occurs after the car has warmed up a bit and then continues for about 10 minutes after the car has been turned off. It only happens about once every 2-5 minutes and I don't really notice it happening as much while I'm driving. It also doesn't happen every single time I drive the car unless I'm just not paying attention and don't hear it.
I'm not entirely sure where it's coming from but my best guess is beneath the car or somewhere in the engine bay. It's a relatively loud noise and you can even slightly feel it.
Is this an issue that should concern me or is it just something normal with the car that I don't know about? Sorry if this has already been addressed but I didn't have much luck finding any info about it.
FatFree is offline   Reply With Quote
Old 03-14-2015, 08:14 PM   #2
Tromatic
Your post is hard to decipher, but I assume you mean the noise you hear after parking and shutdown. Totally normal sounds of various metals cooling after being f-ing hot.
Tromatic is offline   Reply With Quote
Old 03-14-2015, 08:22 PM   #3
FatFree
FatFree's Avatar
Yeah, I was assuming it was just metals cooling down. That's definitely what it sounds like. But it is rather loud. And I hear it when it's running too but it's not as loud as when the car is turned off.
Old 03-14-2015, 08:38 PM   #4
Tromatic
Starting from cold, the car runs for a bit to warm up the catalytic convertors. Lots of heat into the exhaust early. I've never noticed any odd noises. Ask your dealer the next time you go, but it's more than likely normal.
ETA: Yeah, it can be loud cooling off!
Old 03-14-2015, 08:55 PM   #5
Hoahao
Drives: 2014 Monogram Hot Lava
Your car is haunted
Hoahao is offline   Reply With Quote
Engine Knock sound issue nos145 Issues | Warranty | Recalls / TSB 65 10-20-2019 04:57 PM
Does this sound like 'tip-in knock'? 1Cor10:23 Engine, Exhaust, Transmission 48 04-02-2016 01:06 AM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 09:39 AM
Tip in knock? bmsi30 Issues | Warranty | Recalls / TSB 17 08-25-2014 04:12 PM
