Old 02-24-2020, 11:28 AM   #29
D-VO
Drives: Whiteout FR-S, Evo 8 RS
@steve99 - So today I was able to reflash for the factory MAP sensor and drive the car again: This time the car misfired at 6000RPM again, but I got a p0108 (Input Voltage to high at MAP) at the same time. Going for a new 4 bar MAP sensor, but I don't understand how a MAP sensor can go bad after an intercooler pipe blew off.
D-VO is offline   Reply With Quote
Old 02-24-2020, 11:31 AM   #30
Did you suck some steam up into the intake?
I blew a heater line on one of my cars and the steam it sucked it messed with all my air sensors since when the water evaporated it left a film of the additives all over them.
Old 02-24-2020, 05:27 PM   #31
D-VO
Well it did suck in a boat load of hot air since the I/C pipe that decoupled was the one before the MAF sensor.
Old 02-24-2020, 06:34 PM   #32
jflogerzi
jflogerzi's Avatar
MAF cleaner?
2013 Series 10 FRS #553
Old 02-25-2020, 08:25 AM   #33
D-VO
Originally Posted by jflogerzi View Post
MAF cleaner?
I had a second MAF sensor that I tried. No change.
Old 02-25-2020, 09:24 AM   #34
Connector look OK?
Old 02-26-2020, 10:15 AM   #35
D-VO
Connector look OK?
Yep. Everything looks good. I'm trying to find where that vacuum line that comes off the throttle body goes. I see it goes into the sensor under the intake manifold then goes up between the fuel line then goes back down underneath the car. I'm thinking there may be a vacuum line that popped off in the back of the car that I can't see or hear. I've been looking for a vacuum diagram online with no luck.
Old 02-26-2020, 10:18 AM   #36
Here are the service manuals. There is a vacuum line diagram in there someplace.
https://demos.starbase7.net/t3Portal/
D-VO (02-26-2020)
Old 02-26-2020, 10:19 AM   #37
jflogerzi
jflogerzi's Avatar
If you did not clamp it down when switching to FI that could be an issue for sure.
The Following User Says Thank You to jflogerzi For This Useful Post:
Tcoat (02-26-2020)
Old 02-27-2020, 10:07 PM   #38
D-VO
So here is the list of things I've looked at or tried swapping so far:
Everything is clamped
Tried a new MAF
Tried a new MAP
Cleaned Throttle body twice
No vacuum leaks
Spark plugs are clean no fouling
No SES light or codes
Followed that vacuum line from the sensor underneath the intake manifold to the back; Still connected.
Car still pulls hard until the misfire then the RPM's will not raise any higher
A few weeks ago the misfiring was at around 6000 RPM, now the misfire starts down at 4000RPM. I only checked the resistance of the coils which gave me consistent readings but I'm not sure if there's anything else I can do. Has ANYONE else experienced this?
Old 02-27-2020, 10:36 PM   #39
jflogerzi
jflogerzi's Avatar
Tried a new MAF
Tried a new MAP
No vacuum leaks
Can you tell what cylinder the miss fire is coming from? Replace that plug and coil pack and see if that fixes it. Use ecutek to log
Old 02-28-2020, 05:24 PM   #40
D-VO
I wish I knew someone with ECUTek to log for me. I'm using open source (ecuflash) with tactrix and SD card for logging.
Old 03-19-2020, 02:02 PM   #41
D-VO
*ISSUE SOLVED!*
Hey guys. For whoever is still following this issue: I ended up changing ALL 4 coils. So just to catch up, I had a spare coil and decided to change the coil with the highest number of resistance which was a .91. The other 3 were at .86(<--intentional?). Anyway, the car started misfiring down to 4000 RPM with colder IAT's of 68-75 degrees but was breaking up at 6000 RPM when the IAT's were 90 and up(This was the only log data I had). Not sure if that meant anything. Once I changed the coil that was reading a .91 it made a hell of a difference! However, it was still lagging around 6000 RPM. At this point with no CEL's AT ALL, I decided to change all 4 coils. Good to go!
I'm guessing this means the OBDII system is trash at detecting faults with the coils? Thanks for the replies guys!
The Following 3 Users Say Thank You to D-VO For This Useful Post:
bcj (03-19-2020), DarkPira7e (03-19-2020), Tcoat (03-19-2020)
Pops/Crackle Tune do damage to your brz? Jcas Software Tuning 79 01-26-2022 10:29 AM
OFT Pops and Crackle Tune problem V4 niceman Software Tuning 8 09-16-2018 09:27 PM
OFT Backfire/Pops help DaveyBonesJones Southern California 8 08-27-2018 11:53 AM
OFT Pops and Crackle Tune just stops working after a while? stig_iv Software Tuning 12 08-21-2018 05:30 PM
