| Software Tuning Discuss all software tuning topics. |
Drives: 2013 Subaru BRZ
(ECUTEK) Stock tune for brz?
Does anyone have a stock tune for the brz on ECUTEK, my car wont start when i have the tuned rom in it, and i couldnt save the original tune for it, ive been trying to find it for awhile now.
#2 |
Drives: '14
Ecutek program downloads all stock maps. You just have to look for it through the program.
#3 |
Drives: brz 2017 hksv2
help, ecutek update, update rom list
| The Following User Says Thank You to tomm.brz For This Useful Post: | DarkPira7e (02-21-2020) |
#4 |
Drives: FT86
You need to know which calod to flasb to car if your doing a recovery
What is year of car and is it auto or manual Also what was your original ecu calid ? And calid of tune you flashed |
#5 |
#6 |
Rust bucket enthusiast
#7 | |
-SKUNK2 Racing Coilovers -AEM Boost & Air Flow Gauges - Setrab ProLine Oil Cooler -JDL Intercooler -RadiumAuto Fuel Lines -TurboSmart Blow-Off Valve |
#8 |
#9 | |
I flashed the Same one as ZA1JA01C Rom File 2013 Subaru BRZ 2.0 limited - (MANUEL) Which one should i flash with all these mods? -JDL Turbo Kit w/ UEL Manifold V2 -SKUNK2 Racing Coilovers -AEM Boost & Air Flow Gauges - Setrab ProLine Oil Cooler -JDL Intercooler -RadiumAuto Fuel Lines -TurboSmart Blow-Off Valve |
#10 | |
Drives: '14
| The Following 2 Users Say Thank You to kev0 For This Useful Post: | DarkPira7e (02-21-2020), tomm.brz (02-21-2020) |
#11 |
maybe you are in confusion about this, but ecutek doesn t really provide custom tunes
you need to contact a master tuner to buy one |
#12 |
You definitely need to have a custom tune. Certainly you have injectors and an aftermarket MAP sensor at minimum. Both of which will cause a wildly negative impact on a car without a tune meant to accommodate them
#13 |
Drives: FT86
Ok
Now we know you flashed turbo rom if its cranks over bit wont start its most likey cause ghe map senspr installed doesnt Match map senspr scaling in tune. If it doesnt even crank then it another problem. Most turbo tunes will reqore a 3 or 4 bar map sensor to be installed to enavle boost monitoring and overboost failsafe and boost control Ask tune supplier whaat map sensor is neeeded for tune |
| Reverting to stock tune on Ecutek | stlgrym3 | Software Tuning | 12 | 10-28-2018 12:43 AM |
| Tuner ecutek tune back to stock? | Toyota John | Software Tuning | 16 | 04-27-2016 08:08 PM |
| >>>VORTECH SUPERCHARGER KIT w/ PERRIN ECUTEK TUNE ~ ONE Kit IN STOCK - Ready to ship! | Circuit Motorsports | Forced Induction | 91 | 10-24-2013 01:07 PM |
| Ecutek stage 2 tune on stock brz | 01s0uljah | Software Tuning | 15 | 10-15-2013 03:52 PM |
| Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 01:50 AM |
