Old 07-15-2012, 10:25 PM   #29
Rurounimidnight
Rurounimidnight's Avatar
Drives: Past S13 S14 350Z, Future FRS
I've always had a great experience with stance coilovers, used had them on my S14 and 350z. They ride very smooth and dampening is setup very well they aren't at all some bouncy hellaflush coilover.
Rurounimidnight is offline   Reply With Quote
Old 07-16-2012, 10:14 AM   #30
wcbjr
Drives: 2006 Subaru LGT
Originally Posted by Toyotapartsoutlet View Post
man o man, I won't those.
wcbjr is offline   Reply With Quote
Old 07-16-2012, 11:04 AM   #31
Racecomp Engineering
For a good easy read on spring rates, moment arms, motion ratios, etc:
http://www.ft86club.com/forums/showt...688#post280688
- Andrew
denkigrve (07-17-2012)
Old 07-17-2012, 02:04 PM   #32
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
The next shipment coming in will have the 7k / 7k setup.
Motion ratio on the FR-S allows for the higher rear spring rates.
Touge Factory is offline   Reply With Quote
Old 07-19-2012, 09:38 PM   #33
flipm3
Drives: BMW M3
Great to see Stance USA broadening their product!
I have had their coilovers on both my former G35 and current E46 M3. I have been nothing but happy with not only the product but their customer service. They are able to give first hand experience with street, grip, and drift setups. From my experience, there aren't many shops that can actually give first hand experience with the cars they cater too. With Stance's R&D and experience, they can provide great information.
I can't wait to see some of these local BRZs and FRS' using the Stance coilovers.
flipm3 is offline   Reply With Quote
Old 07-21-2012, 01:54 PM   #34
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
i wonder what other chassis they pulled the shock canister from. As they use threaded bodies, all they had to do was make a new lower adaptor and then just screw on a canister with valving already on the shelf. I would suspect this is the bigger reason they started with 7/5 rates as that is what the damper was valved for? Are they adjusting the valving for the incoming shipment or just tossing in different springs?
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 07-22-2012, 09:46 AM   #35
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
TouchMyHonda is offline   Reply With Quote
Old 07-25-2012, 03:25 PM   #36
Touge Factory
Drives: ZN6
Damper casings are made specifically for each vehicle, since suspension travel needs to be accounted for and clearance for other suspension components.
Yes, this was the first set that came in based on Japan's specs.
Valving is key to a properly engineered coilover setup, with also Spring consistency to aid the overall performance of the coilover.
Also - the dampers are threaded to offer independent height adjustment utilizing the brackets, not the spring...
Old 07-27-2012, 12:19 PM   #37
TouchMyHonda
Vtec Jesus
Franz?
Old 07-30-2012, 03:30 PM   #38
Touge Factory
Drives: ZN6
Here it is.... STANCE Super Sport with CR-Kiwami's!!!!
Looks just right!
The Following User Says Thank You to Touge Factory For This Useful Post:
rcm47 (07-30-2012)
Old 07-30-2012, 03:34 PM   #39
M3MPHIS
Drives: 1997 BMW M3, 2013 Subaru BRZ
Looks just right!
Beautiful. Details on wheels and tires? offset, size, tire dimensions?
M3MPHIS is offline   Reply With Quote
Old 07-30-2012, 04:03 PM   #40
Touge Factory
Drives: ZN6
Wheels are:
Work CR-kiwami
18x8.5 +38 / 225/40/18
18x9.5 +38 / 245/40/18
Old 07-30-2012, 04:13 PM   #41
jamal
jamal's Avatar
Drives: Legacy GT
Don't you mean picked from a couple different lengths that are available? If things were made specific to each vehicle you wouldn't need a thread on lower mount.
jamal is offline   Reply With Quote
Old 07-30-2012, 04:46 PM   #42
epson1
Drives: 2013 BRZ Limited
Raising and lowering the threaded mount is the proper way of lowering the car with out changing the spring preload.
When will these coils be available?
epson1 is offline   Reply With Quote
Running a Stagger stance? Xdragonxb0i Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-09-2012 12:14 PM
stance nation BRZ DuMa BRZ Photos, Videos, Wallpapers, Gallery Forum 23 05-08-2012 12:47 AM
Why are most stock wheels weak stance? #87 Other Vehicles & General Automotive Discussions 16 12-17-2011 05:15 AM
FT-86 Prototype, Stance Edition. Matador FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 80 05-21-2011 11:12 PM
Stance of the Union S2KtoFT86 Other Vehicles & General Automotive Discussions 8 05-27-2010 06:08 PM
