#29 | |
Drives: Silver FR-S
#30 |
Drives: 2013 Subaru BRZ
Out of curiosity, is the sound you're experiencing similar to what I've encountered on my setup? I made a thread about it with no response yet.
Check it out here. |
#31 |
Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
I've got an OFH and OFT Tune mated to a full Perrin, catted, 2.5 inch Headerback (from when perrin used to make a catted front pipe). It is a glorious sound. My friend had the same setup, but catless, and 3 inch. He liked mine better since the cat helps pull some of the harshness out of the exhaust note. For a very gentlemanly setup, I replaced the OEM catted front pipe to tone it down even more.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα |
#32 |
My car sounds like the bestest twin in the world.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
| The Following User Says Thank You to 86MLR For This Useful Post: | SuperTom (02-14-2020) |
#33 |
Drives: FR-S Whiteout
On this car? Yes. IMO
OTOH a stock header and front pipe with an open exhaust are some of the better sounding 86's. Even with a factory catback, or perhaps especially with it, no cats sound like you're using a empty can of corned beef for a muffler. With the factory header-back it's barely louder than stock.
Intent > Content
cowardice is the mother of cruelty. |
#34 | |
Drives: Drives like a crab.
But it's not rasp (I've experienced rasp and nothing says "rice" better than it) like you have on decel. I agree a simple muffler delete sounds the best but it's hard to go back to a car with a massive torque dip. They're planning on offering E85 in Belgium this year so I'll wait and see. I'm currently leaning toward a solution like this one: https://www.heatshieldproducts.com/header-armor |
#35 | |
Drives: 2017 toyota 86
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | wparsons (02-14-2020) |
#36 | |
Drives: Silver FR-S
| The Following User Says Thank You to Chamaco For This Useful Post: | wparsons (02-14-2020) |
#37 |
Drives: 2013 frs red
With a big enough leak they all sound like shit
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Decep (02-14-2020) |
#38 |
Drives: C5, GT-86, '24 Colorado TrailBoss
Start at the front of the car (Header to block) and work your way back tightening. Have you actually got under the car with it running and the skid plate removed and used your hand to check for air?
#39 |
Drives: Halo 860
Good to see other people mentioning the clapping sound or whatever you want to call it, that had me stressed out after my install thinking I had a leak somewhere. Checked multiple times and found nothing, and yeah it's only super pronounced when the right side of the car is against something bouncing the sound back to the cabin.
#40 |
Drives: '13 BRZ Limited / 76' 914 1.8T
I was getting driven nuts by what I thought was an exhaust leak - I even changed from Borla to Tomei UEL headers and heat wrapped them to try and cut down the noise. That "exhaust leak" / "valve tapping" sound just seems inherent with the setup.
Automotive photo and video
www.mikespock.com |
#41 |
Could be because the header and overpipe meet on the passenger side more or less
#42 | |
It's worse when the car is cold. At low speed, low RPM, under load (not too much load) the sound is very embarrassing. If I remember well, a gutted stock header would do the same. But can't remember if the shield would affect that. Well, I guess a conservative supercharger setup is the way to go... Too bad, I kind of liked the bru' UEL after all... |
| Sound question : Catless header + HFC Fp and Catted headr + catted Fp ? | l3ooml3al2al3a | Engine, Exhaust, Transmission | 12 | 03-22-2019 10:22 AM |
| Sound Clip of Catted UEL Header with Catless Front Pipe | lc300 | Engine, Exhaust, Transmission | 1 | 03-21-2019 05:24 AM |
| Catted Front Pipe w/ Catless Header sound difference? | HeresMyMind | Engine, Exhaust, Transmission | 6 | 09-19-2018 09:05 PM |
| catless header vs catless frontpipe | steveholt | Engine, Exhaust, Transmission | 30 | 10-10-2017 07:13 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
