#15 |
Drives: 2016 Subaru BRZ
I feel like there’s a hatred towards UEL headers here
I’m running an FT86SF catted UEL header with a Perrin catback and it’s deep and rumbly, no tinnyness or raspiness. I love it lol.
#16 |
Drives: 2016 Scion FRS Release Series 2#439
Granted, for maximum power an Equal Length Header is the way to go (eg. Ace etc.).
That said, I recently installed a Gruppe-S UEL with a JDL Quiet Front Pipe. Continuing to use the stock mid-pipe and axle-back components. This combined with an OFT Stage II+ tune has brought the car to life. Sounds great IMO (from the drivers seat) without waking the neighbours. Will get more impressions in the spring once onto the track (TMP) again. |
#17 |
Drives: Drives like a crab.
It seems to attenuate when the car is warm.
Exhaust leak, then? |
#18 | |
Drives: 17 Asphalt 86
Sounds pretty good to me, and I'm not overly fond of most UEL on these cars. |
#19 | |
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Have you checked the O2 Sensors to see if there is any leak there? Have you checked any of the other exhaust sections downstream for leaks? You could try seeing if anyone with a stock one lying around can lend it to you for a few days to test that?
NARFALICIOUS
Noob Poster 1988 | 2016 |
#20 |
Drives: 2015 Firestorm Scion FRS
I have the JDL UEL with the TRD catback exhaust for 5ish years now. I feel like I should tone it down now I'm in my early 30s now. I do miss the exhaust note without the amped up subbie rumble when I was watching some youtube videos the other day. Musing whether I should go equal length or back to stock with the TRD catback so it's a bit more refined, tamer and mature as I get older.
This adulting thing changes your perspective and maturity as you get older. What have I become as a car guy? Even that Camry TRD is looking pretty good right about now...
#21 | |
It definitely sounds like a collector leak. O2 sensors could be a good culprit... I'm scared at putting some sealant/grease on sensors threads by fear of ruining them (just bought a primary O2 sensor at Toyota for a friend... was 275€ !). Well, I'll try this ultimately. If it doesn't work then... back to the stock header! Thanks. |
#22 |
Drives: Track preped NA FRS
Sound is very subjective, as you have already noticed in many posts here. But what I found in my few cases of meeting other twins at the track, is that the metal and shape of the header do affect how it sounds, and so do whats after it (FP and catback). They all have an effect and will produce very unique sounds. You may think my car sounds like rice, I think it sounds like a racecar, its all subjective (fly-by at the track from another video, its not streetable and my camera's mic gets overloaded so onboards sound like crap. 3:10 or so for the part with the sound, the golf right next to me is on stock exhaust and produces no sound basically, this is at a 92db limit track):
#23 |
Double post, ignore.
#24 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
Don't shoot the messenger (or pull the trigger, DILLIGAF?
). I thought this scenario would've existed in the forum already in the the general exhaust thread https://www.ft86club.com/forums/showthread.php?t=6064
#25 |
Thank you for your inputs.
I actually think the sound at the back is pretty decent for a 4-banger. But at the front... it doesn't neither good or right. The two times I installed catless headers (whether it was EL or UEL), it was the same thing: It sounded like there's a exhaust leak at the front. The stock header doesn't make that noise (which ultimately prooves I can install a header properly for those maybe wondering). And it's more noticeable when cold. Could the thin stainless steal provoke that? Problem is, with an UEL and its irregular pulses, it does sound like a leak which is very embarrassing unless you're driving an old rusty pickup and such sound is kind of expected. |
#26 | |
Drives: Silver FR-S
#27 | |
I'm considering header wrapping but it seems like the best way to quickly destroy a header... Btw, what do you think of your ACE350 header? Worth the $$$? Have you had the chance to compare to something else? I'm currently running a OFH Header and enjoy the added power but expected a bit more against a gutted stocked header tbh... |
#28 |
Drives: 2014 GT86
Wil: imho no other catless header is worth it's price to replace another catless aftermarket header one already has. Yes, ace very probably will perform better, but it won't double the gains. Nice gains vs stock, imho worth getting as initial purchase, but like in other cases of "upgrading", relatively slight gains over other aftermarket headers, but you still pay same .. aaand probably extra, as you may need to invest in ace specific ecutek tune to go along, over OFT you probably have now with OFH ... aaand you'll waste current investment of purchasing OFH.
If you want more, think of forced induction. |
| Sound question : Catless header + HFC Fp and Catted headr + catted Fp ? | l3ooml3al2al3a | Engine, Exhaust, Transmission | 12 | 03-22-2019 10:22 AM |
| Sound Clip of Catted UEL Header with Catless Front Pipe | lc300 | Engine, Exhaust, Transmission | 1 | 03-21-2019 05:24 AM |
| Catted Front Pipe w/ Catless Header sound difference? | HeresMyMind | Engine, Exhaust, Transmission | 6 | 09-19-2018 09:05 PM |
| catless header vs catless frontpipe | steveholt | Engine, Exhaust, Transmission | 30 | 10-10-2017 07:13 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
