#15 |
Drives: 2014 Scion FR-S
Start data logging, turn on all cylinder misfire channels, watch AFR
#16 |
Drives: Whiteout FR-S, Evo 8 RS
No answer huh? Same thing just happened to me after popping an intercooler pipe. Limped home at 2000 rpm put the pipe back on, but now it won't go passed 5800-6000 rpm without misfiring. So far only tried reseting ECU because I thought maybe the trims went all out of whack. NOPE! Time to log.
#17 |
Rust bucket enthusiast
@D-VO
This is an issue with a coilpack, guaranteed. I had this come up randomly recently. I replaced the top coilpack on the passenger side (following the misfire code it threw) and the problem went away immediately. |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | D-VO (03-19-2020) |
#18 |
Drives: brz 2017 hksv2
log and check for misfire and look at injection DI end to spark, the value in ms at the rpm you get the problem, but I also think it s coilpack(s)
| The Following User Says Thank You to tomm.brz For This Useful Post: | D-VO (03-19-2020) |
#19 |
Drives: 2013 Asphalt FRS
If it was a coil or fuel issue it should throw a misfire cel. This is not happening so I would look at the tune and make sure. If you have a old tune that's for FI try it and see if it changes
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
| The Following User Says Thank You to FRS Justin For This Useful Post: | D-VO (03-19-2020) |
#20 |
Just don't forget that the tuner could've disabled the CEL. Not that they should've but you never know.
#21 |
Drives: FT86
Check it not an overboost fuel cut set up in tune, if map sensor goes bad it can trip early
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | D-VO (02-17-2020), FRS Justin (02-09-2020) |
#22 |
Car may not throw a cel but it could still misfire.... Check for dtcs. When I was dealing with a idle lean condition due to tune, I would not always pop a cel but it would log a dtc and car would drive wired till clear. What AFR are you seeing at WOT, but I would get your car checked by your tuner
2013 Series 10 FRS #553
#23 |
@DarkPira7e I'm getting no misfire codes. Mine are all still enabled except for the rear O2 and MAP sensor SES because I'm using an OMNI 4 BAR MAP sensor.
@steve99 How can I test the MAP sensor? I'm logging the boost level with the MAP and it's still climbing as it did in previous logs. The only datalog line that I see changing is the timing; it drops by 1 - 2 degrees during the misfire and AFR's start going up to a maximum of 12.8. It almost feels like its hitting a rev limiter. |
#24 |
Also, when the coolant temp is low (not sure the exact number) the misfire happens @4500rpm
#25 | |
Also are you logging misfires counts? He showed me a table where in the hire rpms it requires 20ish to long a cell and at low loads it's was near 90!!! Yikes ![]() Sent from my GM1915 using Tapatalk
| The Following User Says Thank You to jflogerzi For This Useful Post: | D-VO (02-18-2020) |
#26 |
Wow! Well I'm the tuner and I never programmed such a thing. When I get home I have to look at the log again to see the oil temps. Good call!
#27 | |
Drives: FT86
Also make sure it reads close to 14psi or 1 bar with engine off igniiton on |
#28 |
Ok. Maybe I can put the stock one back on for testing since the problem does happen right around 8psi
| Pops/Crackle Tune do damage to your brz? | Jcas | Software Tuning | 79 | 01-26-2022 11:29 AM |
| OFT Pops and Crackle Tune problem V4 | niceman | Software Tuning | 8 | 09-16-2018 10:27 PM |
| OFT Backfire/Pops help | DaveyBonesJones | Southern California | 8 | 08-27-2018 12:53 PM |
| OFT Pops and Crackle Tune just stops working after a while? | stig_iv | Software Tuning | 12 | 08-21-2018 06:30 PM |
