Old 01-31-2020, 06:36 PM   #1
Wil
Wil's Avatar
Drives: Drives like a crab.
Do all catless header sound like complete garbage?
Hi everyone,
I recently installed an OFH 2 UEL catless header on my 2013 GT86 and it sounds like crap.
I mean, almost like there's a leak. Except there's none! It sounds like my exhaust is made of coke cans. Sounds like a helicopter, almost. Do you see what I mean?
Here's what I've done:
1. I installed the header with 3 new gaskets - sounded bad
2. I retorqued everything to be absolutely sure everything was perfectly installed - still sounded bad
3. I unmounted the header, noticed a very very small crack (it's second hand) - rewelded it and rebolted the header after polishing the block, header and overpipe flanges and applied some Holts Firegum on the header to overpipe section - still, no improvement
4. Retorqued everything again after driving just to be sure.
Still bad
I already had that problem with a gutted stock header but assumed it was the empty cat that was creating some resonance.
So, simple question:
Do all catless header sound "tiny" like described above?
Can't even say it's because of the thinner stainless steel, it does it with a the gutted stock header as well.
Thank you for your inputs
Wil is offline   Reply With Quote
Old 01-31-2020, 06:52 PM   #2
86MLR
86MLR's Avatar
Personally I found a catless UEL header to be obnoxiously loud on a NA car with a 2.5" XForce or decated OEM header back exhaust.
So much so I removed the Tomei UEL header within 2 weeks of installing it and replaced it with a decated OEM header.
I never found the OEM decated system tinny. And I decated both the hesder and front pipe.
I currently have an UEL header with my AVO turbo setup, but the turbo does an excellent job at muffling the noise.
The Following User Says Thank You to 86MLR For This Useful Post:
HaXx (02-21-2020)
Old 01-31-2020, 07:04 PM   #3
PulsarBeeerz
Drives: JRSC BRZ SOLD
I have a catless HKS header, resonated front pipe and resonated Perrin exhaust. I have zero raspiness. I could see the oem exhaust not being able to tone it down.
PulsarBeeerz is offline   Reply With Quote
Old 01-31-2020, 07:26 PM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I have catless HKS headers and their R-Spec front pipe and find the tone just fine.
MS, CSCS, TSAC-F, CPT
Old 01-31-2020, 09:16 PM   #5
Lantanafrs2
Drives: 2013 frs red
No drone or raspiness with my ofh. Completley stock from header back
Lantanafrs2 is offline   Reply With Quote
Old 01-31-2020, 09:34 PM   #6
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
you have uel they are designed intentionally to sound like trash.
i have ace headers and as of right now stock everything behind the merge and think it sounds fine. i will be pick up a 60s tomorrow so its probably going to sound like shit. ill probably get a custom straight through on the end or something
Old 01-31-2020, 10:35 PM   #7
jflogerzi
jflogerzi's Avatar
My catless JDL 4-2-1 EL sounds great with a stock FP with stock resonator removed and a nice vibrant resonator added in place and a mxp SP catback
2013 Series 10 FRS #553
Old 01-31-2020, 10:42 PM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Unequal length is literally the sound of poor design. With that said, a catted UEL header gets the lumpiness without the bark
The Following 6 Users Say Thank You to DarkPira7e For This Useful Post:
DylanJZA (02-02-2023), lamawithonel (02-01-2020), mrg666 (02-01-2020), RToyo86 (02-03-2020), TylerLieberman (07-18-2020), Ultramaroon (01-31-2020)
Old 01-31-2020, 10:48 PM   #9
Nothing says performance like the sound of a dead cylinder.
The Following 9 Users Say Thank You to Ultramaroon For This Useful Post:
DarkPira7e (01-31-2020), DylanJZA (02-02-2023), korhun (02-04-2020), lamawithonel (02-01-2020), mrg666 (02-01-2020), PulsarBeeerz (02-01-2020), soundman98 (02-01-2020), Tanstin (07-27-2020), TylerLieberman (07-18-2020)
Old 02-01-2020, 03:10 AM   #10
Wil
Wil's Avatar
I don't think the problem is EL/UEL.
It sounds like there's a leak. You see what I mean when I say the "helicopter sound", on throttle? Like pulses are resonating against thin metal. I don't have the problem with a catted stock header.
Had the problem with a gutted stock header that had the heat shield removed. Might try putting it back on and see what develops.
Old 02-01-2020, 07:53 AM   #11
DarkPira7e
DarkPira7e's Avatar
Why not pay a shop the labor to put it on the lift and find out if there's a leak? It's take them 2 minutes to diagnose
Old 02-01-2020, 08:03 AM   #12
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
I was never happy with the quietness of the stock exhaust. (MY14) Did some reading and decided to keep stock EL header. Although I replaced the CAT with a straight section of stainless and replaced the O2 sensor bungs. It still didn't really sound like a sports car. Next I removed the muffler unit and replaced it with a single pipe to the left exit. I love it! No rasp! Very little cost! ( I intend to replace my muffler delete with a nice one, though.)
Sent from my XT1254 using Tapatalk
snuff58 is offline   Reply With Quote
Old 02-01-2020, 11:30 AM   #13
Wil
Wil's Avatar
done and rewelded in the process.
At low rev, the car just farts out that's embarassing.
Old 02-01-2020, 11:34 AM   #14
jflogerzi
jflogerzi's Avatar
Video... Not used to UEL sounds?
Sound question : Catless header + HFC Fp and Catted headr + catted Fp ? l3ooml3al2al3a Engine, Exhaust, Transmission 12 03-22-2019 10:22 AM
Sound Clip of Catted UEL Header with Catless Front Pipe lc300 Engine, Exhaust, Transmission 1 03-21-2019 05:24 AM
Catted Front Pipe w/ Catless Header sound difference? HeresMyMind Engine, Exhaust, Transmission 6 09-19-2018 09:05 PM
catless header vs catless frontpipe steveholt Engine, Exhaust, Transmission 30 10-10-2017 07:13 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
