Old 01-31-2020, 06:36 PM   #1
Wil
Wil's Avatar
Drives: Drives like a crab.
Do all catless header sound like complete garbage?
Hi everyone,
I recently installed an OFH 2 UEL catless header on my 2013 GT86 and it sounds like crap.
I mean, almost like there's a leak. Except there's none! It sounds like my exhaust is made of coke cans. Sounds like a helicopter, almost. Do you see what I mean?
Here's what I've done:
1. I installed the header with 3 new gaskets - sounded bad
2. I retorqued everything to be absolutely sure everything was perfectly installed - still sounded bad
3. I unmounted the header, noticed a very very small crack (it's second hand) - rewelded it and rebolted the header after polishing the block, header and overpipe flanges and applied some Holts Firegum on the header to overpipe section - still, no improvement
4. Retorqued everything again after driving just to be sure.
Still bad
I already had that problem with a gutted stock header but assumed it was the empty cat that was creating some resonance.
So, simple question:
Do all catless header sound "tiny" like described above?
Can't even say it's because of the thinner stainless steel, it does it with a the gutted stock header as well.
Thank you for your inputs
Wil is offline   Reply With Quote
Old 01-31-2020, 06:52 PM   #2
86MLR
86MLR's Avatar
Personally I found a catless UEL header to be obnoxiously loud on a NA car with a 2.5" XForce or decated OEM header back exhaust.
So much so I removed the Tomei UEL header within 2 weeks of installing it and replaced it with a decated OEM header.
I never found the OEM decated system tinny. And I decated both the hesder and front pipe.
I currently have an UEL header with my AVO turbo setup, but the turbo does an excellent job at muffling the noise.
Old 01-31-2020, 07:04 PM   #3
PulsarBeeerz
Drives: JRSC BRZ SOLD
I have a catless HKS header, resonated front pipe and resonated Perrin exhaust. I have zero raspiness. I could see the oem exhaust not being able to tone it down.
PulsarBeeerz is offline   Reply With Quote
Old 01-31-2020, 07:26 PM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I have catless HKS headers and their R-Spec front pipe and find the tone just fine.
MS, CSCS, TSAC-F, CPT
Old 01-31-2020, 09:16 PM   #5
Lantanafrs2
Drives: 2013 frs red
No drone or raspiness with my ofh. Completley stock from header back
Lantanafrs2 is offline   Reply With Quote
Old 01-31-2020, 09:34 PM   #6
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
you have uel they are designed intentionally to sound like trash.
i have ace headers and as of right now stock everything behind the merge and think it sounds fine. i will be pick up a 60s tomorrow so its probably going to sound like shit. ill probably get a custom straight through on the end or something
Old 01-31-2020, 10:35 PM   #7
jflogerzi
jflogerzi's Avatar
My catless JDL 4-2-1 EL sounds great with a stock FP with stock resonator removed and a nice vibrant resonator added in place and a mxp SP catback
2013 Series 10 FRS #553
Old 01-31-2020, 10:42 PM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Unequal length is literally the sound of poor design. With that said, a catted UEL header gets the lumpiness without the bark
Old 01-31-2020, 10:48 PM   #9
Nothing says performance like the sound of a dead cylinder.
Old 02-01-2020, 03:10 AM   #10
Wil
Wil's Avatar
I don't think the problem is EL/UEL.
It sounds like there's a leak. You see what I mean when I say the "helicopter sound", on throttle? Like pulses are resonating against thin metal. I don't have the problem with a catted stock header.
Had the problem with a gutted stock header that had the heat shield removed. Might try putting it back on and see what develops.
Old 02-01-2020, 07:53 AM   #11
DarkPira7e
DarkPira7e's Avatar
Why not pay a shop the labor to put it on the lift and find out if there's a leak? It's take them 2 minutes to diagnose
Old 02-01-2020, 08:03 AM   #12
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
I was never happy with the quietness of the stock exhaust. (MY14) Did some reading and decided to keep stock EL header. Although I replaced the CAT with a straight section of stainless and replaced the O2 sensor bungs. It still didn't really sound like a sports car. Next I removed the muffler unit and replaced it with a single pipe to the left exit. I love it! No rasp! Very little cost! ( I intend to replace my muffler delete with a nice one, though.)
Sent from my XT1254 using Tapatalk
snuff58 is offline   Reply With Quote
Old 02-01-2020, 11:30 AM   #13
Wil
Wil's Avatar
done and rewelded in the process.
At low rev, the car just farts out that's embarassing.
Old 02-01-2020, 11:34 AM   #14
jflogerzi
jflogerzi's Avatar
Video... Not used to UEL sounds?
Sound question : Catless header + HFC Fp and Catted headr + catted Fp ? l3ooml3al2al3a Engine, Exhaust, Transmission 12 03-22-2019 10:22 AM
Sound Clip of Catted UEL Header with Catless Front Pipe lc300 Engine, Exhaust, Transmission 1 03-21-2019 05:24 AM
Catted Front Pipe w/ Catless Header sound difference? HeresMyMind Engine, Exhaust, Transmission 6 09-19-2018 09:05 PM
catless header vs catless frontpipe steveholt Engine, Exhaust, Transmission 30 10-10-2017 07:13 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
