Old 01-23-2020, 06:26 AM   #113
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Why?????
Hey, the Geo Metro sold as a convertible, why not a Yaris?
Originally Posted by Jordanwolf View Post
Here's the solution to 2nd gen 86 sitting right here.
Drop Subaru, who needs them. It's not like they're going to come out with anything worth while anyway. WRX 2021, bring your dog edition.
Modify this Yaris platform, delete the AWD and make it RWD with two engine trims (NA/FI). Boom, I am genius, gib me money now.
Only thing you are going to get off that platform is a new MR2. But I doubt we are going to be that lucky.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
JD001 (01-23-2020)
Old 01-23-2020, 07:29 AM   #114
Why?????
to make a marginally ugly car full on ugly?
JD001 (01-23-2020)
Old 01-23-2020, 07:48 AM   #115
JD001
JD001's Avatar
Drives: Subaru BRZ
I always struggled with the idea behind the E30 M3 convertible as the 'tin top' started life as a homologation special.. so who the hell races a convertible E30 M3?
I have the same view regards the Yaris..
I read in Evo mag this week that Toyota is looking to build circa 24,000 units and that the UK will receive a four figure sum..
Old 01-30-2020, 12:28 AM   #116
jflogerzi
jflogerzi's Avatar
This has been said already.
The problem is that Subaru is already signed up to partner for the next 86, and I am sure they will still be the one building the MKII. The GR Yaris will likely be built on the same line as the standard (Jap) Yaris, but the 86 will need its own production line, which is where Subaru comes in. The car will also need an engine. I don't think the 100hp NA motor will cut it, nor may the turbo motor if it couldn't be easily adapted to be longitudinal. In fact, I was trying to see if this TNGA is even compatible with an 86. The dimensions seem similar enough, but what motor would fit? I don't think many longitudinal engines will fit because the firewall position. Another NA boxer motor is the best guess. My thinking is that they will add D4S to the 2.4L motor and try to squeeze 240-250hp out of that motor. It only has a larger bore, so it won't be wider than what we have currently. It really depends on how adaptable this platform is for the 86:
Side by side: Look at the height difference of the windshields or the dash position relative to each other.
Engine position: Look how far forward the motor is relative to the strut towers.
Engine bay differences: The steering wrack is further back, which means the motor could move further back, but it doesn't look big enough for a transmission to fit in the tunnel. Just enough size for a driveshaft and front diff. Then again, the 86's transmission has a long bell housing, so I'm not sure.
Rumors are the MK2 twins will be built on Toyota's current next gen platform and Subaru will be providing the power plant...
2013 Series 10 FRS #553
Old 01-30-2020, 07:18 AM   #117
why?
why?'s Avatar
Drives: series.blue
but that rumor makes absolutely zero sense. If it is on Toyota's platform it should use a Toyota engine. And is Toyota going to manufacturer it now?
The Following 2 Users Say Thank You to why? For This Useful Post:
Dadhawk (01-30-2020), WolfpackS2k (01-30-2020)
Old 01-30-2020, 11:59 AM   #118
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
That seems necessary considering Subaru no longer has a RWD architecture, but it also seems difficult if Subaru is going to continue to build these cars. Before it was their chassis with their engine on their assembly line. Now it would be Toyota’s chassis with Subaru’s engine on Subaru’s assembly line. I don’t know how adaptable the assembly line would be for such a situation.
I understand Lexus models will be built on the TNGA platform, so they must be able to accommodate FR architecture, but a common mold could also mean a bulbous body. We will see. Regardless, I’m so invested in my car that I won’t be updating anytime soon.
Old 01-30-2020, 12:03 PM   #119
Irace86.2.0
I see zero reason why this is necessary. Visit the Engine Swap section sometime and see what can easily fit given modest adaptations. The bigger question is what will this inefficiency cost?
Old 01-30-2020, 12:16 PM   #120
jflogerzi
jflogerzi's Avatar
I am guessing Toyota might take the lead and assemble and source the boxer engine from subui. Same here not giving up my car for anything. Soon this will become a dedicated track car and will get a turbo vs the current SC.
Old 01-30-2020, 01:46 PM   #121
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
WAT? If that platform is going to be used for Lexus models, we can kiss a sub 3000 lb curb weight good-bye.
Dammit.
Old 01-30-2020, 02:42 PM   #122
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Dammit.
Current Corolla is 2900 lbs with 4-doors, a hatch, and decent sound deadening/interior quality.
Edit: Japanese Yaris with 2wd is <2,600 lbs based on what I can find. Even claims down to ~2100lbs but I bet that's like a 2cylinder twist beam shitbox that iracer thinks is what will be sold here.
TNGA supports AWD already with cars on the road, the only oddities Toyota will have to adapt the platform for (if this is real which I highly doubt it) would be the longitudinal engine/transmission, coupe body lines, and Subaru's mfg process.
That third one will be the hardest unless they've been working on it for the last 5 years already.
ineedyourdiddly
Old 01-30-2020, 02:53 PM   #123
Irace86.2.0
Dammit.
https://www.wardsauto.com/industry/t...p-evs-due-soon
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
WolfpackS2k (01-31-2020)
Old 01-31-2020, 06:26 AM   #124
why?
why?'s Avatar
Drives: series.blue
But Why? They've noted the compromises they had to fit in the boxer, and how they really don't like the result as much as they thought they would. If Toyota manufactured the car they could easily put an i4 in it and make it far superior to what the engine is now, even if they choose to have the same power levels.
The Yaris is at least a foot or two shorter that our car. They could have gone that way and had a taller trunk if they wanted to fit 4 wheels and tires. If they want to compete weight wise with the Miata maybe they do choose this.
strat61caster (01-31-2020)
Old 01-31-2020, 11:16 AM   #125
strat61caster
Toyota USA put up a Facebook post last night.
https://m.facebook.com/story.php?sto...cus_composer=0
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
JD001 (01-31-2020), ScoobsMcGee (01-31-2020), weederr33 (01-31-2020)
Old 01-31-2020, 12:38 PM   #126
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
No lie, if Toyota brought the car to the US, I'd trade up for it.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Toyota Yaris GR Sport revealed ahead of Paris debut gymratter Other Vehicles & General Automotive Discussions 8 09-16-2018 02:04 PM
Toyota Yaris WRC announced vh_supra26 Other Vehicles & General Automotive Discussions 55 08-12-2017 05:59 AM
My Review of 2011 Toyota Yaris (Loaner Car) danthedirt Other Vehicles & General Automotive Discussions 19 07-13-2012 02:42 PM
2012 Toyota Yaris Dark Other Vehicles & General Automotive Discussions 13 10-10-2010 11:57 AM
