#113 | |
Drives: Q5 + BRZ + M796
The problem is that Subaru is already signed up to partner for the next 86, and I am sure they will still be the one building the MKII. The GR Yaris will likely be built on the same line as the standard (Jap) Yaris, but the 86 will need its own production line, which is where Subaru comes in. The car will also need an engine. I don't think the 100hp NA motor will cut it, nor may the turbo motor if it couldn't be easily adapted to be longitudinal. In fact, I was trying to see if this TNGA is even compatible with an 86. The dimensions seem similar enough, but what motor would fit? I don't think many longitudinal engines will fit because the firewall position. Another NA boxer motor is the best guess. My thinking is that they will add D4S to the 2.4L motor and try to squeeze 240-250hp out of that motor. It only has a larger bore, so it won't be wider than what we have currently. It really depends on how adaptable this platform is for the 86: Side by side: Look at the height difference of the windshields or the dash position relative to each other. ![]() ![]() ![]() Engine position: Look how far forward the motor is relative to the strut towers. ![]() ![]() Engine bay differences: The steering wrack is further back, which means the motor could move further back, but it doesn't look big enough for a transmission to fit in the tunnel. Just enough size for a driveshaft and front diff. Then again, the 86's transmission has a long bell housing, so I'm not sure.
#114 |
Drives: Subaru BRZ
Why?????
#115 | |
Only happy when it rains.
Drives: series.blue
Hey, the Geo Metro sold as a convertible, why not a Yaris?
| The Following User Says Thank You to why? For This Useful Post: | JD001 (01-23-2020) |
#116 |
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | JD001 (01-23-2020) |
#117 | |
Drives: Subaru BRZ
I have the same view regards the Yaris.. I read in Evo mag this week that Toyota is looking to build circa 24,000 units and that the UK will receive a four figure sum.. |
#118 | |
2013 Series 10 FRS #553
#119 |
Drives: series.blue
but that rumor makes absolutely zero sense. If it is on Toyota's platform it should use a Toyota engine. And is Toyota going to manufacturer it now?
| The Following 2 Users Say Thank You to why? For This Useful Post: | Dadhawk (01-30-2020), WolfpackS2k (01-30-2020) |
#120 | |
I understand Lexus models will be built on the TNGA platform, so they must be able to accommodate FR architecture, but a common mold could also mean a bulbous body. We will see. Regardless, I’m so invested in my car that I won’t be updating anytime soon.
#121 |
I see zero reason why this is necessary. Visit the Engine Swap section sometime and see what can easily fit given modest adaptations. The bigger question is what will this inefficiency cost?
#122 | |
#123 | |
Drives: '12 C63 P31, '23 GRC
Dammit.
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#124 | |
Drives: '13 FRS - STX
Edit: Japanese Yaris with 2wd is <2,600 lbs based on what I can find. Even claims down to ~2100lbs but I bet that's like a 2cylinder twist beam shitbox that iracer thinks is what will be sold here. TNGA supports AWD already with cars on the road, the only oddities Toyota will have to adapt the platform for (if this is real which I highly doubt it) would be the longitudinal engine/transmission, coupe body lines, and Subaru's mfg process. That third one will be the hardest unless they've been working on it for the last 5 years already. |
#125 | |
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | WolfpackS2k (01-31-2020) |
#126 | ||
Drives: series.blue
But Why? They've noted the compromises they had to fit in the boxer, and how they really don't like the result as much as they thought they would. If Toyota manufactured the car they could easily put an i4 in it and make it far superior to what the engine is now, even if they choose to have the same power levels. Quote:
The Yaris is at least a foot or two shorter that our car. They could have gone that way and had a taller trunk if they wanted to fit 4 wheels and tires. If they want to compete weight wise with the Miata maybe they do choose this. |
| The Following User Says Thank You to why? For This Useful Post: | strat61caster (01-31-2020) |
| Toyota Yaris GR Sport revealed ahead of Paris debut | gymratter | Other Vehicles & General Automotive Discussions | 8 | 09-16-2018 03:04 PM |
| Toyota Yaris WRC announced | vh_supra26 | Other Vehicles & General Automotive Discussions | 55 | 08-12-2017 06:59 AM |
| My Review of 2011 Toyota Yaris (Loaner Car) | danthedirt | Other Vehicles & General Automotive Discussions | 19 | 07-13-2012 03:42 PM |
| 2012 Toyota Yaris | Dark | Other Vehicles & General Automotive Discussions | 13 | 10-10-2010 12:57 PM |
