Old 01-21-2020, 11:47 PM   #1
MrSir
Gentleman/scholar
MrSir's Avatar
Drives: 13 FRS, 89 RX 3dr, 00 gf8, 73 F250,
Mild lower core support damage
Hit some falling rock coming down the mountain some time ago. Didn't see this damage initially, but here it is! How should I be going about this? I can straighten it out pretty easily, but if someone has experience with this repair and has some advice, I'm all ears.
The hood, bumper and fenders still meet straight, and there doesn't appear to be damage to anything other than the lower core support.
Note the control arm support, and the mild crumple in the driver's side, right under the radiator.
Having issues posting the images
MrSir is offline   Reply With Quote
The Following User Says Thank You to MrSir For This Useful Post:
soundman98 (01-22-2020)
Old 01-21-2020, 11:50 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
Do you have pictures? The more angles, the better
Old 01-22-2020, 12:01 AM   #3
MrSir
Gentleman/scholar
MrSir's Avatar
Finally got them up. Lol
Old 01-22-2020, 12:14 PM   #4
MrSir
Gentleman/scholar
MrSir's Avatar
After some digging, I found that the lower core support has been dented, not bent. Now the debate is whether or not I'm even going to mess with it. It drives straight, and everything seems pretty square when I measure it, aside from that very small portion of the lower core support.
Old 01-22-2020, 12:47 PM   #5
Drives well. Looks fine. Not going to suddenly let go. Leave it alone.
Old 01-22-2020, 12:54 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Looks like it did a good job protecting the really important things. Just for fun I'd check your oil pan to be sure nothing made it further back and dented the pan. Seems fine otherwise!
Old 01-22-2020, 02:04 PM   #7
ls1ac
ls1ac's Avatar
Stop driving over parking lot stops.
You will have to stop a little sooner
Old 01-22-2020, 03:01 PM   #8
norcalpb
norcalpb's Avatar
Are we talking about the splash guard here?
Old 01-22-2020, 03:06 PM   #9
MrSir
Gentleman/scholar
MrSir's Avatar
Looks that way doesn't it?! Lol That's SR330 for you. It rains, then it rains rocks.
Old 01-22-2020, 03:08 PM   #10
MrSir
Gentleman/scholar
MrSir's Avatar
It's the lower core support, the front of the aluminum tray, the radiator, and the front bolts for the control arm supports bolt to it, among other things.
Old 01-22-2020, 03:18 PM   #11
MrSir
Gentleman/scholar
MrSir's Avatar
Damage to the pan, frame rail welds, core support welds, panel alignment, steering alignment, and strut tower welds were the first things I checked. I thought I got a clean pass at first, until I was poking around trying to figure out where I'm at as far as brake pad life.
DarkPira7e (01-22-2020)
Old 01-22-2020, 03:25 PM   #12
MrSir
Gentleman/scholar
MrSir's Avatar
Thats about where I'm at. I pushed the rock for about 20 feet to get off the road, I felt the jarring, heard it for sure, but nothing changed as far as controls go. The road was pretty messy, so it had plenty of lube. Lol
Old 01-23-2020, 01:18 PM   #13
Stomachbuzz
Drives: 2013 FRS
It might be moot point now, but I can't see what you're talking about.
Not to be pretentious, but those are quite low quality images for 2020. Huge loss of detail when trying to look carefully, and lighting is poor.
A little bit of rust on the front lip of the control arm support brace, but that's all I can see really.
I guess I see what looks to be 'the crease' you're talking about under the radiator, but it almost looks factory.
The passenger side bolt for the undertray actually looks tweaked compared to the driver's side.
Stomachbuzz is offline   Reply With Quote
Old 01-24-2020, 11:40 AM   #14
MrSir
Gentleman/scholar
MrSir's Avatar
Yeah...... I had to resize and compress them, but I'm also a neanderthal with phones. I probably went overboard.
I'm just going to let it go. The component locations are well within tolerance, and there aren't any compromised welds. Headed to the road course tonight, so if it's squirrelly I'll come back and fix it. But for now it's fine. Lol
Lumbar support for seats? My lower back is killing me Indestruct Cosmetic Modification (Interior/Exterior/Lighting) 65 05-18-2017 11:56 AM
Lower rad support + rad replacement Cole Engine, Exhaust, Transmission 9 03-16-2016 09:52 AM
MI: fire damage engine (core) + transmission SomeoneWhoIsntMe Engine, Exhaust, Bolt-Ons 10 12-29-2014 03:04 PM
2013 FRS Mild STX Build. feldy Tracking / Autocross / HPDE / Drifting 2 01-24-2014 02:29 PM
a mild lapping session complete ill86 Tracking / Autocross / HPDE / Drifting 14 08-28-2012 06:17 PM
