Old 03-14-2016, 06:31 PM   #1
Cole
Not a troll
Cole's Avatar
Lower rad support + rad replacement
To make a long story short (just for you, @go_a_way1);
Last summer, living the low life, I drove over a raised watermain valve. It bashed in my lower rad support pretty good and ruined part of the under panel there. No big deal, everything still held. Now, this past weekend, I was putting new wheels on, had the front of the car jacked up. Got lazy and didn't use jack stands (), car slipped off the jack partially, thankfully, the rad support bracket saved me from the wheel landing on my foot.
Result was: Rad support bracket is busted off the lower rad support (are these even the right terms?) and the rad support bracket stayed attached to the rad and dented it in at the bottom.
Sorry for the lack of pictures, car is parked at a friend's house and I don't feel like making the 2 minute drive to go and get pictures.
Now, obviously I need to look into getting replacement parts. My question is,to replace the lower rad support, do I need to weld it in? Ideally, I'd like to stay OEM with everything, but if the aftermarket solutions are going to be about the same price and superior in function, I'll look at getting them.
Next question is, what the hell are these parts actually called? So far, I've found this. And it looks like I need #10 in that diagram.
So, to buy:
1) New radiator
2) New lower radiator support
3) Support tab from lower support to radiator
4) ?????????
Tried searching, and haven't found a whole lot. pls halp
Edit: Car is an AT, in case that matters for aftermarket radiators
The Following User Says Thank You to Cole For This Useful Post:
go_a_way1 (03-14-2016)
Old 03-14-2016, 07:12 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
So, to buy:
1) New radiator
4) ?????????
TL;DR lmao!
You will likely need to weld in new rad supports. Bodyshop will be able to get you one if the dealership is stupid and can't find it.
Secondly I believe it's much cheaper $200 or so to get a aftermarket rad like mishimoto.
Cole (03-14-2016)
Old 03-14-2016, 07:22 PM   #3
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
The lower rad support needs to be welded in, you can buy the whole front end assembly from subaru for a pretty reasonable price (the guys crash a lot.... we replace these often)
Gear_One_Performance is offline   Reply With Quote
The Following 2 Users Say Thank You to Gear_One_Performance For This Useful Post:
Cole (03-14-2016), go_a_way1 (03-14-2016)
Old 03-14-2016, 08:07 PM   #4
humfrz
@Cole ...........slowly ..... back away from your car ...... lay down your tools ....... pick up the phone ....... call a tow service ....... have it towed to a shop ....... have the shop fix it.
humfrz
Old 03-14-2016, 08:22 PM   #5
Cole
Not a troll
Cole's Avatar
I really only need the lower part. It's around 87 bucks. The radiator is what I'm more curious about. I've found used replacements for around 100. But, I don't know if it's worth it to buy used and have one that leaks.
As it is now, there aren't any leaks, but it's a ticking time bomb. Maybe I'll invest in the @Mishimoto one, but the dollar is such garbage I'm kind of hesitant to do so.
Old 03-14-2016, 08:24 PM   #6
Cole
Not a troll
Cole's Avatar
humfrz
Fortunately, it doesn't leak and is drivable. I'll be able to wait on the parts for a couple of weeks, then take it to a shop once I have everything I need for replacement.
Luckily I have another vehicle so I don't need to drive around with a rad that's ready to go.
humfrz (03-14-2016)
Old 03-14-2016, 08:35 PM   #7
15limited
15limited's Avatar
I hit a raccoon which bent my AC condenser and radiator about 10 months ago. Koyorad makes a radiator that fits oem radiator stays (brackets) without any modifications for ~$300. Haven't had any problems with it yet, and it's larger than OEM. Install took me almost 8 hours with a basic socket and end wrench set. AND jacks stands haha good luck!
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 03-16-2016, 09:34 AM   #8
Cole
Not a troll
Cole's Avatar
Ended up getting the @Mishimoto rad. That's what the shop I dealt with recommended.
Did some more looking at the car yesterday, I think I can hold off on replacing the lower support, but it will be on my to-do list for the coming year when I have the money to throw down on getting a quality job done.
D_Thissen (03-16-2016)
Old 03-16-2016, 09:45 AM   #9
D_Thissen
D_Thissen's Avatar
I like your logic. If its busted, might as well upgrade lol. How much was an OEM rad going to set you back?
Old 03-16-2016, 09:52 AM   #10
Cole
Not a troll
Cole's Avatar
Around 350 if new, 80-120 for OEM aftermarket and OEM used ones.
The Mishi ended up being around 480 all in. So, a bit more than I wanted to spend, but I think the benefits of going with a bigger rad are worth it
Lumbar support for seats? My lower back is killing me Indestruct Cosmetic Modification (Interior/Exterior/Lighting) 65 05-18-2017 11:56 AM
Rear Coilover and Lower Control Arm Replacement Seth Hawkins DIY (Do-It-Yourself) Guides 3 12-08-2015 03:28 PM
A thank you for your support CSG Mike Tracking / Autocross / HPDE / Drifting 10 05-03-2014 12:34 PM
IOS 6 MAP Support w/BRZ HU xwd Electronics | Audio | NAV | Infotainment 19 10-04-2013 07:15 PM
ID3 Support RMStringer Electronics | Audio | NAV | Infotainment 0 01-21-2013 09:55 PM
