Old 01-08-2020, 02:25 AM   #1
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
Does anyone know where to get spring clamps?
So I'm getting rid of my Perrin inlet hose and I'll need a spring clamp for the PCV. Does anyone know where I'd get them?
Also, does anyone know a good way to remove the PCV from the inlet hose? Its on really tight.
Ryan GT86 is offline   Reply With Quote
Old 01-08-2020, 02:45 PM   #2
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Not sure about sourcing spring clamps, but for getting out the PCV (that's not a PCV valve, its an open elbow fresh air intake for the PCV system. Symantics.), take a small right angle pick and carefully insert and run it around circumference of the valve between valve and intake to unstick the silicone.
Should come out with some twisting after that. I use that trick for coolant hoses too when they don't wanna pop.
If you can't find the spring clamps, and don't want to chew up the intake with a normal hose clamp, pick up some lined clamps.
Good luck!
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Old 01-08-2020, 08:40 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
check at the local hardware store in the small engine section, or small engine repair shop. that's a very common small engine fuel line fitting.
Old 01-08-2020, 09:56 PM   #4
Grady
Grady's Avatar
It is such a pain looking around for parts. I wish the Subaru would make it easy to get parts. Like make a parts manual available and maybe talk their dealers into selling those parts. One of these days you may even be able to buy parts on line!
Old 01-08-2020, 10:07 PM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Like literally any auto parts store or hardware store.
Removing the hose, hold on to it, wiggle it in a circular motion.
Exhaust Without Collar Clamps? daoznn Engine, Exhaust, Transmission 3 03-28-2016 08:32 AM
Tomei exhaust spring clamps Bach415 Engine, Exhaust, Transmission 2 06-29-2015 03:46 AM
What size clamps come in the vortech kit? Frs32907 Forced Induction 2 01-27-2014 02:28 PM
Clamps and Check Valves for FI sw20kosh Forced Induction 1 12-17-2013 06:32 PM
Reservoir Clamps/Mounts swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 07-15-2013 09:23 PM
