Old 01-06-2020, 04:50 AM   #43
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Firstly for maintenance and then before the Reds went back on the car after the ASTs Josh suggested going non-inverted with 7k springs up front so I did.
Old 01-06-2020, 05:03 AM   #44
86MLR
86MLR's Avatar
Greasing?
Old 01-06-2020, 05:56 AM   #45
Captain Snooze
Drives: Red Herring
I can't remember, it was too long ago.
Old 01-06-2020, 08:42 AM   #46
Tokay444
Don't waste your money on trash.
Save longer and get something worth putting on the car.
BC and everything else in that barrel are worse than the oem dampers.
The Following 3 Users Say Thank You to Tokay444 For This Useful Post:
Griever423 (01-16-2020), Tristor (01-06-2020), wparsons (01-06-2020)
Old 01-06-2020, 10:18 AM   #47
wparsons
wparsons's Avatar
If comfort is priority, look at Ohlins, or stick with a mild drop on lowering springs.
BC is going to ride like garbage, regardless of how you adjust it.
flickr
Old 01-06-2020, 10:37 AM   #48
steverife
Drives: 2016 Scion FRS
For the fuel pump comments, I've autocrossed several cars that would require over half a tank of fuel to avoid the risk of fuel starving (CRX, S2000, MR2 Spyder). I frequently run my FRS with the fuel light on and have never had such an issue.
As far as budget street/track/autocross coilovers, I have no experience with their FT86 products, but I've purchased coilovers from both Pro Parts and Redshift and think both are fantastic companies that offer fantastic products and support.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
wparsons (01-07-2020)
Old 01-06-2020, 10:41 AM   #49
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Petah78 View Post
Redshift is a very well known in the Honda world. I navigated to their site last night to see if they offer anything for the 86 platform to find this:
https://store.redshiftmotorsports.co...vers-s/147.htm
Intrigued, as they offer coilovers with no damping adjustment, which I'd prefer for classification purposes (saves me 40 lb.!).
However the damping curve on their site seems to be seriously lacking in low-speed rebound damping. But I'm no expert...
Old 01-06-2020, 10:54 AM   #50
ZDan
ZDan's Avatar
Drives: '23 BRZ
Regarding fuel starvation, that happened to me once, at Palmer after two [LEFT]-hand turns 1 & 2. With just under half a tank the car momentarily lost power between 2 and 3 in my first two time-trial laps! Then another car in my TT group had a big off (he was fine but bent the car he borrowed!) so I was able to duck into the pits and borrow some fuel for re-run Won TT by 1/2 a second, would have been CLOSE with sputtering car...
FTR that was with factory PP dampers, Raceseng camber plates, Swift BRZ Sport lowering springs, on 225 RE71R tires.
Old 01-06-2020, 11:13 AM   #51
Tokay444
Reminds me of the OE dampers with TRD springs.
I'm going to try Sachs and then make a decision.
Old 01-06-2020, 11:31 AM   #52
Tristor
Tristor's Avatar
For that money you should be buying a Bilstein B12 Pro-Kit or finding PP Sachs dampers used and running the RCE Yellow lowering springs /w their combo (comes with SPC Rear LCA and camber bolts for the front). If you can find CSG Spec Tein Flex As for less than $1500 all-in, that's also a good option.
Don't buy BC Racing or any other Chinesium junk, as they're going to be worse than the factory dampers. There's a ton of people in this platform community that slam their cars, which means the damper quality basically doesn't matter since they're riding on springs mostly (due to running high spring rates to stay off the bump stops). Since you're not planning on slamming it and seem to want to enjoy driving it, don't listen to anyone recommending ChinaBay brands... they don't know what the fuck they're talking about.
Tristor is offline   Reply With Quote
The Following 3 Users Say Thank You to Tristor For This Useful Post:
finch1750 (01-06-2020), Griever423 (01-16-2020), Tokay444 (01-06-2020)
Old 01-06-2020, 11:51 AM   #53
ZDan
ZDan's Avatar
Drives: '23 BRZ
Current track setup is PP Sachs dampers with Swift BRZ Sport springs and Raceseng camber plates. Similar stiffness to RCE Yellows and Eibach Pro-Kit. Unfortunately the lower ride height combined with the camber plates (more lost bump travel) and factory PP dampers results in harsh bottoming-out of the fronts over all but the smallest bumps... That's with the front bump stops cut down from ~60mm to ~25mm.
I'd like to go stiffer overall vs. current 3.8/4.5 rates, while gaining back lost bump travel.
I might consider sticking with my current springs and camber plates but swapping in Bilsteins in place of the stock PP Sachs dampers *if* the Bilsteins have significantly more bump travel...
Old 01-06-2020, 12:56 PM   #54
norcalpb
norcalpb's Avatar
Regarding fuel starvation, that happened to me once, at Palmer after two right-hand turns 1 & 2. With just under half a tank the car momentarily lost power between 2 and 3 in my first two time-trial laps! Then another car in my TT group had a big off (he was fine but bent the car he borrowed!) so I was able to duck into the pits and borrow some fuel for re-run Won TT by 1/2 a second, would have been CLOSE with sputtering car...
I thought fuel starvation only happened turning left?
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
finch1750 (01-06-2020), NoHaveMSG (01-06-2020), ZDan (01-06-2020)
Old 01-06-2020, 01:37 PM   #55
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Fuel starve happens. Even on 245 SX2s with no aero and over half a tank lol.
Originally Posted by solidONE View Post
BC utilizes a 46mm piston with a 12mm center bore at about .5" thick, like some other popular brands. Nobody would stop you from shoving an Ohlins or Bilstein piston and valving in a BC cartridge. Know what I mean? lol
As far as the reliability of the components go, I think there are enough out there to vouch for them. People beat the shit out of them, hellaslamming dragging them around car meets and getting stuck in driveways. The main issue is QC and the quality and consistency of the valving, which is probably not great but not quite as bad as many make them out to be.
BCs modified to that extent are no longer BCs but instead just use a cheap housing that BC also happens to use. Like Feal or other companies mentioned it is possible to make something good from that. When BC gets mentioned here it's ots stuff and while it may not be the worst in the world it is not great and there are much better options in OPs price range.
The Following 3 Users Say Thank You to finch1750 For This Useful Post:
Griever423 (01-16-2020), Tristor (01-06-2020), wparsons (01-07-2020)
Old 01-06-2020, 01:38 PM   #56
ZDan
ZDan's Avatar
Drives: '23 BRZ
Dammit-all! Yeah, running Palmer CCW, turns 1 & 2 are indeed LEFT turns!
Will fix in previous post...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
norcalpb (01-06-2020), wparsons (01-07-2020)
brz, coilovers, comfort
What coilovers should I purchase? 403 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 71 05-20-2017 03:09 AM
Ohlins Coilovers - $1500 Shipped Bobby@Forged Brakes, Suspension, Chassis 1 09-28-2016 05:38 PM
isc n1 coilovers and 19x9.5 rays 57extremes 1500 miles mint kingkai23 NY / NJ / CT / PA 1 08-10-2014 11:11 AM
Eibach Multi PRO R2 Coilovers: $1500 FRSdrive Brakes, Suspension, Chassis 11 02-24-2014 07:00 PM
$1500 budget coilover - what would you choose? smbstyle Tracking / Autocross / HPDE / Drifting 27 11-17-2013 09:35 PM
