Old 12-31-2019, 04:36 PM   #1
Andrei
Drives: Leon4x4 PRECISION6466,buyng soonBRZ
Hard ticking noise in 2500-3500 RPM
hello everyone,
I have a really frustrating problem, trying to find it over 2 months!
I have like a knocking noise, sound like metal ticking, only under load (so I can't check it on stands) only from 2500-3500 rpm from the front of the car
sound like it getting worse with time, now even can be heard from 1500 rpm
the noise started after I fuel in a different gas station then usual
(I refueled 4 times at my regular gas station from then, and even add 15 liters of Toluene)
2 weeks before that I changed my clutch (to OEM one) and changed the final drive on the differential (from 4.1 oem to 4.556)
things I done already to trying to find the noise:
change the shocks+hats, the 2 front hubs, steering ball joints, disassemble the sway bar and the undercar shield.
engine mount, bushings, the two hydraulic timing tensioner, change the clutch again, swap my gear.
i don't have any error code, (my car have ECUTEK+UEL)
check on my live parameters with the ECUTEK scenes like everything is fine, EGT, fuel pressure, knocking etc.
(the car is also feels find, no power loss or something)
I'm so frustrated, tried all kind of good mechanics, I have no Idea what to do next, I will be glad to hear maybe you guys have and Idea
Thanks!
Andrei is offline   Reply With Quote
The Following User Says Thank You to Andrei For This Useful Post:
humfrz (12-31-2019)
Old 12-31-2019, 05:46 PM   #2
kev0
Drives: '14
[ame]https://www.youtube.com/watch?v=WAdC7B7xYEU[/ame]
fix: https://www.ft86club.com/forums/showthread.php?t=133606
I can almost guarantee you that it's this.
kev0 is offline   Reply With Quote
The Following User Says Thank You to kev0 For This Useful Post:
humfrz (12-31-2019)
Old 12-31-2019, 05:51 PM   #3
Sure does sound like it.
What did you do to fix it?
Old 12-31-2019, 06:22 PM   #4
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
Sure sounds like @ermax solved this. What causes it to break?
davesrave is offline   Reply With Quote
Old 01-01-2020, 04:19 PM   #5
Andrei
unfortunately it's isn't it, I checked it
and the noise don't happen after 3500 RPM no matter what, I can track the car and nothing, but on the way home on normal driving it's all the time
Old 01-01-2020, 06:17 PM   #6
gravitylover
Exhaust header bolt is loose or there's a pinhole leak there. At high rpm you're building up more pressure and it's sort of sealing itself but then opens up and you can hear it down lower. I have something like this happening on my beater suv.
The Following User Says Thank You to gravitylover For This Useful Post:
Ultramaroon (01-01-2020)
Old 01-05-2020, 12:19 PM   #7
Andrei
already checked it, it wasn't it
gravitylover (01-07-2020)
Old 01-05-2020, 04:39 PM   #8
Andrei
I found the problem, it was one of the direct injectors,
why? don't know yet, maybe the fuel? maybe detonation?
changed one and the knocking vanished.
why we didn't see any fault on the ecu? even when doing live logs on every parameter
hope my tuner have an answer for that.
interesting if on the stock map it was giving an error
Horrible rasp between 2500-3k and 3500-4k. oldlostcory Engine, Exhaust, Transmission 7 10-16-2019 03:18 PM
Weird noise over 3500 rpm FR-Sky Scion FR-S / Toyota 86 GT86 General Forum 20 04-01-2016 02:48 AM
New coilover ticking noise ItzBidge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 01-07-2016 09:41 PM
Strange noise at 2500 RPM midnight23 Engine, Exhaust, Transmission 7 06-07-2013 10:01 AM
ticking noise? iHeartmyFR-S Issues | Warranty | Recalls / TSB 13 04-18-2013 06:42 PM
