Drives: 2013 FR-S 10 series [755]
Weird noise over 3500 rpm
I dont know if anyone has experience this...
when i accelerate over 3500 rpm,,i start hearing a noise like a louder version of HPFP sound, or a very small loosing metal moving so fast. It is noticable from the steer wheel/dash area. It is not the high pitch sound. When I let go my gas,,the sound stop. When i press the gas over 3500rpm,,it happens again. I just had my service 3 weeks ago, and everything is fine. Does any one experience this? Is it a big problem? Because i have a invidia N1 exhaust and i still hear it. I am sorry if i post on a wrong section. I dont know where i can post this. |
not playing cards
I bet it's the clutch return spring inside the master cylinder. I could not figure out the noise, sounded like engine to me and actually had me pretty worried until I stumbled onto an old thread.
Next time while it's doing it, tap the clutch pedal a little. Should just quit -poof-
#3 | |
not playing cards
If that's what it is, yup. I yelled out "sonofabitch!" when I discovered it for myself.
#5 | |
Do i hold the gas over 3500 and tap the clutch, or gas over 4500, let go of the gas and do it??@@ Noted: but it doesnt have the sound before 3500 rpm many thanks. |
#6 | |
not playing cards
Just tap the clutch pedal a little while it's loudest. If that's what it is, it will be obvious. It's like finding any old rattle, touch it and it disappears.
Are you sure it ain't the turbo spooling up? Or possibly VTEC?
#8 | |
it only happens on 2nd and 3rd gear,,3500-4000rpm =[ |
It's called...
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#10 |
#11 |
Drive From Home
Drives: BRZ STI Performance
It's probably a metal piece vibrating. Have the car on the lifter and see if something's not fasten properly. What was serviced 3 weeks ago?
#12 |
not playing cards
Damn, well, it was a shot. Can you record a clip?
#13 |
Drives: 2014 Subaru BRZ LTD 6MT
I have a creak like noise in that rpm range. Generally 2nd and 3rd gear. Maybe present in higher gears as well, though everything gets pretty loud. I first noticed it last summer, driving with the windows down. IE, I bought the car new (150 miles) in February.
It only happens when I dip into the throttle. Just a creak/squeak sound. It can also be with a rev match downshift in that range with the clutch fully depressed. It happens every time. I kind of just figured it was something mechanical in the engine. I reckon I ought to set up an appointment at some time or another. The nearest Subaru dealer is like an hour away, thus me putting it off. |
#14 | ||
for my case,,it doesnt happen on high gear tho,, only 2nd/3rd 3500rpm + |
| Weird Chain Noise? | megamarines | Engine, Exhaust, Transmission | 9 | 08-28-2015 02:53 AM |
| help!! weird humming noise?? | sid94 | Issues | Warranty | Recalls / TSB | 3 | 05-17-2014 12:16 PM |
| Weird Noise | FloridaBRZ | BRZ First-Gen (2012+) — General Topics | 7 | 04-25-2014 08:35 PM |
| Weird Noise??? | caradd | Issues | Warranty | Recalls / TSB | 3 | 11-01-2013 11:42 PM |
| Weird noise | Touge_ninja | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-28-2012 01:46 AM |
