Old 12-30-2019, 06:17 PM   #1
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
"duct" panel near underbody is loose and rattling
Does anyone have experience with these? I took off the front-most skid plate, and the hard plastic tray beneath that, to access the horns without removing the bumper. There are these small plastic panels(ducts) that attach on the top of the hard tray with ONE pop clip. It seemed to have no where else to connect however there are some forked tabs which only loosely fit around a vertical piece of sheet metal that sits where the washer fluid reservoir is on the driver's side.
This completely baffled me once they were out, as there is only one pop clip for this flimsy piece of plastic. Now I have some rattling going on over bumps and it's driving me crazy.
Spacemane969 is offline   Reply With Quote
Old 12-30-2019, 07:10 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Yes. Those are the radiator air guides.
The driver one is held on by two clips actually. One large pop clip to the plastic undertray and one small clip into the crash beam/frame (you can actually see it in the picture you posted: the hole that is raised on the left side).
It is probably more important that you get the rear tabs aligned correctly with the vertical sheet metal to keep it from rattling. Having the extra small clip would also help.
The small clip is obviously easily lost/broken. I've replaced it in the past. I have the part number on file, but I can't pull it from my list until I return from work.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
Spacemane969 (12-31-2019)
Old 12-31-2019, 08:10 PM   #3
Spacemane969
My rattling is coming strictly from the passenger side. I just couldn't see any opposing slot on the sheet metal that would allow the plastic tab to attach. I might just have to take the bumper off to get a better view. Thanks for the breakdown that's a huge help!
Old 12-31-2019, 08:12 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Self tapping screws are a thing too
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
humfrz (01-01-2020), soundman98 (01-01-2020)
Old 01-01-2020, 12:55 AM   #5
EndlessAzure
Wheels for Brains
I have my passenger side one in storage since it had to be removed for my oil cooler. I'll take a look later
Old 01-01-2020, 03:08 AM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
Just don't be an idiot and use drywall screws without any corrosion resistance. I've had to fix enough rusty drywall screw repairs...
DarkPira7e (01-01-2020)
Old 01-01-2020, 02:12 PM   #7
norcalpb
norcalpb's Avatar
Those are loose with the bumper off, but tight with the bumper on.
You most likely knocked them out of the bumper if they are loose and making noise.
Dual Oil Coolers in "fog light duct" area? iBoost Forced Induction 22 02-18-2019 01:09 PM
3D printed "Deep Dish" Fuse panel cover canyons Electronics | Audio | NAV | Infotainment 12 03-08-2018 07:00 PM
Gearbox Loose and "Slushy" Sound When Under 2200 RPMs astrubinger Issues | Warranty | Recalls / TSB 9 07-08-2015 10:48 PM
Borla UEL flex sections "loose"? Fast_Freddy Engine, Exhaust, Transmission 28 07-24-2013 09:13 PM
350z style "ram air duct" BMHumanic Cosmetic Modification (Interior/Exterior/Lighting) 17 03-09-2013 11:01 PM
