Drives: Passat
Borla UEL flex sections "loose"?
I searched but didn't find anything useful. I just got a Borla UEL today and the flex sections don't feel right. I haven't found any cracks yet but looking at them they appear to be solid, yet there is a fair amount of movement in one of the flex sections. Basically I can wiggle the header at the flex section with very little effort. It feels as though the flex section is made of press-fit pieces rather than solid.
Is this normal? TIA http://img580.imageshack.us/img580/2...fuzsawtxpf.mp4 . Last edited by Fast_Freddy; 07-11-2013 at 07:11 PM. |
Drives: FR-S Firestorm
http://www.ft86club.com/forums/showthread.php?t=39591
May be you have a bad flex section. Chris from Borla told me it was the cause of my rattle problem.
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow - 2007 Honda CBR 600RR - 2002 Bombardier Legend 800SE Website : http://nofear99.monchar.com |
i've never had any luck with flex sections on exhaust. they usually end up leaking or cracking, at least the mesh looking ones do. i've never had one like borla uses.
#4 | ||
Drives: Passat
Thanks. Quote:
Me neither which is why I had to ask about this. They look solid but feel broken. Even if it's not broken, I bet it would rattle if I installed it. The last batch is sold out and they have 70 more units coming soon. Hopefully the latest batch are better quality. Although the collector on this one looks better than any that I've seen pictured here. Thanks. |
Shorter of breath
Drives: a soft bargain
The stock manifold uses two of the same type of flex joints, so it's not necessarily the design that's a problem.
Drives: 2JZ FRS
My car rattles so bad from idle to 3k rpm from the flex section I can't stand driving it right now. I posted a video i made on the above thead. Borla is supposed to have the new batch finished tomorrow and Ill have a replacement on the way. Also covering install and gaskets
Drives: 2013 Raven Black FRS
its a 2 piece part on the inside to allow for movement. Could be something on the inside you can't see.
#8 | |
Drives: Passat
Thanks! I did not know that. Is it common for these flex sections to "wiggle" freely? It doesn't move much but requires little effort to move. |
Tech Master / Car Geek
Drives: 2013 AT Hot Lava FR-S
I installed my Borla UEL on last week. That section was stiff and solid on mine.. In fact, I did not notice any movement. I guess I am one of the lucky ones, because the construction, welds and all was solid and good.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys Borla: UEL Header Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT -= OFT - Stage 2 UEL E85 - fine tuned by me. =- |
#10 |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Never had any flexing issue when I got it, seemed solid. However it had a significant rattle once installed between 2000-3000 RPM which I have told Borla, they are sending me a new header next week so hopefully it resolves the issue.
#11 | |
Drives: Passat
Thank you. I still have hope that Borla will eventually get this header right. No way can they make money when they end up replacing most of them under warranty. |
#12 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
FWIW the third replacement header I got from Borla before giving up on them had the exact same issue as @Fast_Freddy 's.
The flex joints allowed A LOT of movement. I didn't feel comfortable installing it because of that and a few other issues like a warped flange and a crappy collector. I got my refund and moved on to a JDL UEL header. |
#13 |
Drives: Passat
I heard back from Borla today:
Good Morning Fred, I spoke to my head of R&D and showed him all of this that you sent. He assures me that this new style flex flange is supposed to move just like it is. It does have more play than the older mesh style. If you have any other questions feel free to contact me. Thanks, Heath Nelson Good enough for me. The head flanges were machined perfectly flat, the collector looks good and the only small issue is that the overpipe flange is warped. It should flatten out when properly torqued to the overpipe so not a big deal. Hopefully I can get it installed tomorrow. |
#14 |
Drives: Passat
BTW, just because. Not the worst collector ever made.
![]() Head flanges clearly machined flat by Borla after welding.
| Diagrams for the "FRS' and "RS FRS" (includes US Part numbers) | Mrqb22 | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 06-24-2013 08:26 PM |
| WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 05:49 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
