#15 | |
There are inexpensive or cheap aftermarket pumps out there. They are not equal. Can be hard to tell the difference but rule of thumb is the normal if it seems way to cheap it probably is crap (I know that always applies).
| The Following User Says Thank You to Tcoat For This Useful Post: | KDad2 (12-17-2019) |
#16 |
Drives: 2013 Raven
Good point. Cheap is often cheap.
Easy to tell when I have coolant leaking from the water pump onto my header after I got up to operating temps. There was even a trail of coolant leading up to my driveway from down the street. It started with a loose hose connection on my forester cooler, temps went to red and not much left in the radiator. I suspect it damaged the seals. |
#17 | |
#18 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Aisin is cheaper on RockAuto, but you'd have to pay shipping. They are an OEM supplier (Toyota included). Not sure if it's the brand on the twins but I would trust it. Gates has a good rep for belts but their water pumps don't have great QC.
#19 | |
Drives: 2013 Raven
Sent from my SM-N960U using Tapatalk |
| Water Pump Replacement | Djratrap | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 01-19-2018 12:29 AM |
| Water pump pouring fluid | SavingManuals | Engine, Exhaust, Transmission | 5 | 07-23-2014 12:31 AM |
| Leaking water pump | DJCarbine | Issues | Warranty | Recalls / TSB | 11 | 05-13-2014 06:59 PM |
| Water pump | Micene | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 03-08-2013 08:57 AM |
