Team Legacy
Drives: LS swapped FRS, 5 speed
Water pump pouring fluid
Hey everybody, I am racing my boosted frs so I am being in no means gentle on it. Stuff is going to break, more rapidly obviously. However I'm encountering a strange problem which I haven't seen come up around here. On the bottom of the face of the water pump, I am pouring coolant out like crazy. Enough to cause smoke from it burning off of the headers while still a lot being left on the ground. Has anybody had their water pump seals fail? It doesn't look like a big fix, but if it is, enlighten me.
Team Legacy @timeattackrob @team_legacycc |
Have not heard of this one but it does sound like water pump seals. What kind of coolant are you running and how high are the temps?
Turbo 86
Drives: GT86
bring to dealer and file clalim
10 - 1 = 0
real math |
Team Legacy
I don't think the dealer would appreciate that lol. Basically everything has been modified.
Team Legacy
So for an update everybody. I noticed my external wastegate dump pipe had come loose and was smacking into my water pump pulley. It was definitely bearing failure after inspecting when I pulled the pump. The hits to the pulley is the only thing I can see causing it.
If it was too close it may have heated up the shaft and melted the seal
| Raceseng | Water Pump Pulley Recall | Raceseng | Engine, Exhaust, Transmission | 98 | 10-30-2014 04:46 PM |
| SOLD | Mr. | Engine, Exhaust, Bolt-Ons | 12 | 06-10-2014 06:28 PM |
| Leaking water pump | DJCarbine | Issues | Warranty | Recalls / TSB | 11 | 05-13-2014 05:59 PM |
| Water pump | Micene | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 03-08-2013 07:57 AM |
| Water pump reliability - track use | Kamran | Tracking / Autocross / HPDE / Drifting | 13 | 01-20-2013 10:30 AM |
