Old 12-17-2019, 11:53 AM   #15
Originally Posted by KDad2 View Post
I know my water pump is going out. I can get one from toyota, but I see several after market brands for a fraction of the cost. Does anyone have experience with these? Damage to the engine is a whole lot more than an oem part. However, if a cheap one works just as well, I'd rather save my money.
Sent from my SM-N960U using Tapatalk
Curious as to what symptoms you have that make you think the pump is going. Mileage? Mods? I don't recall any issues with pumps on these. Coming from the Mitsubishi world where water pump failures are regular I have sort of watched for problems here but haven't really noticed any.
There are inexpensive or cheap aftermarket pumps out there. They are not equal. Can be hard to tell the difference but rule of thumb is the normal if it seems way to cheap it probably is crap (I know that always applies).
KDad2 (12-17-2019)
Old 12-17-2019, 05:53 PM   #16
KDad2
KDad2's Avatar
Drives: 2013 Raven
Good point. Cheap is often cheap.
Easy to tell when I have coolant leaking from the water pump onto my header after I got up to operating temps. There was even a trail of coolant leading up to my driveway from down the street.
It started with a loose hose connection on my forester cooler, temps went to red and not much left in the radiator. I suspect it damaged the seals.
KDad2 is offline   Reply With Quote
The Following 2 Users Say Thank You to KDad2 For This Useful Post:
JohnJuan (12-18-2019), Tcoat (12-17-2019)
Old 12-17-2019, 06:56 PM   #17
Thanks. The extenuating circumstances of your failure reduce my concern.
JohnJuan (12-18-2019), KDad2 (12-17-2019)
Old 12-17-2019, 07:23 PM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
ACDelco makes a replacement for $66 on Amazon Prime. I've already had the car up on jack stands and under panels off 3 times this weekend for other projects. I'm sure I will be either under the hood or under the car doing something to it again.
Aisin is cheaper on RockAuto, but you'd have to pay shipping. They are an OEM supplier (Toyota included). Not sure if it's the brand on the twins but I would trust it. Gates has a good rep for belts but their water pumps don't have great QC.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
KDad2 (12-17-2019), Tcoat (12-18-2019)
Old 12-17-2019, 08:34 PM   #19
KDad2
KDad2's Avatar
Drives: 2013 Raven
Thanks. That's good to know. I saw that brand on many sites.
Water Pump Replacement Djratrap Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 01-19-2018 12:29 AM
Water pump pouring fluid SavingManuals Engine, Exhaust, Transmission 5 07-23-2014 12:31 AM
Leaking water pump DJCarbine Issues | Warranty | Recalls / TSB 11 05-13-2014 06:59 PM
Water pump Micene Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-08-2013 08:57 AM
