Old 12-16-2019, 12:09 AM   #1
SamtheKorean
September
SamtheKorean's Avatar
Drives: 2015 BRZ
Looking for some advice on fine tuning on OFT
I've noticed that from the Open flash tablet site the most recent OTS tune files are a bit different than i expected. For example wasn't there 2 separate Stage 2 tunes for EL and UEL? Im in the process of installing nameless EL longtube headers rn, had some issues with fitment so sitting on jack stands. Other mods overpipe, catless frontpipe, top speed pro 1 axle back, drop in aftermarket filter. Question is because the header design is longtube, wouldn't there be any different ecu inputs on various things for my set up and from lets say running an UEL headers? if so could i make any changes on romraider or any other methods?
SamtheKorean is offline   Reply With Quote
Old 12-16-2019, 12:38 AM   #2
steve99
Drives: FT86
Ues you could likey use some differnt cam timing more suited to your el long tube header, oft tunes based on uel openflash header
Old 12-16-2019, 12:48 AM   #3
SamtheKorean
September
Drives: 2015 BRZ
would it cause any harm or any benefit of running OFT OTS stage 2 tube then? for my setup
Old 12-16-2019, 03:41 AM   #4
steve99
Drives: FT86
? Wont cause any harm running out of the box oft tune but if you custom tune it likely to get some benifit
I can do that for you if interested pm me
SamtheKorean (12-16-2019)
Advice on desired exhaust setup/tuning? Weigaldo Engine, Exhaust, Transmission 21 05-30-2017 03:45 PM
94 Octane rom fine tuning for OFT FT86Z Software Tuning 12 01-09-2016 09:15 AM
Fine Line Tuning Rocket Bunny V2 Bumper Replica 555 Cosmetic Modification (Interior/Exterior/Lighting) 23 06-18-2015 11:01 PM
Advice - Modding / tuning recommendations in SD BubsMcLogin Southern California 9 02-21-2014 10:07 PM
New to Tuning, some advice? RyanOver9000 Engine, Exhaust, Transmission 8 05-23-2013 03:30 PM
