Old 12-11-2019, 06:10 PM   #1
hexxen
Drives: 2018 Toyota 86
How to add door courtesy light
You dont need to go through the door and tap into the dome light.
just tap into the wires in the door
[ame="https://www.youtube.com/watch?v=SjTjz-eEiiA"]https://www.youtube.com/watch?v=SjTjz-eEiiA[/ame]
hexxen is offline   Reply With Quote
The Following 4 Users Say Thank You to hexxen For This Useful Post:
acuatlsfan (01-15-2020), Bowflex (12-16-2019), Busybee (01-15-2020), kmbkk (12-18-2019)
Old 12-14-2019, 07:18 AM   #2
RainEG
MTXclusive
Drives: 2017 Toyota 86
What gauge wire did you use? also is it necessary to add an in-line fuse or no?
RainEG is offline   Reply With Quote
Old 12-15-2019, 11:09 PM   #3
hexxen
The wire I used was about a 14 gauge and I didn't bother to use a fuse
Old 12-16-2019, 10:52 AM   #4
Circa85
Jesus Christ dude, do you think you've shared this video enough yet?
Circa85 is offline   Reply With Quote
The Following User Says Thank You to Circa85 For This Useful Post:
soundman98 (12-16-2019)
Old 12-16-2019, 01:13 PM   #5
hexxen
It was a pain in the ass to fish that wire through the door so I wanted to make sure no one had to do that lol Sorry XD
Old 12-16-2019, 01:19 PM   #6
Bowflex
Drives: Scion FR-S
I probably won't do the mod, but I appreciate you taking the time to show the process.
Bowflex is offline   Reply With Quote
Old 12-17-2019, 11:52 PM   #7
TheBatman
TheBatman's Avatar
Drives: Scion FR-S 10 Series
THANK YOU for sharing this. This is exactly what I was looking for and I have not been able to find it anywhere!
TheBatman is offline   Reply With Quote
Old 12-17-2019, 11:53 PM   #8
TheBatman
TheBatman's Avatar
Can you confirm its same wire colors on the drivers side door?
Old 12-18-2019, 10:10 PM   #9
hexxen
Yes, I did both doors the same way
Old 01-15-2020, 03:35 PM   #10
acuatlsfan
Drives: whiteout
This is awesome! I cant believe u were the first one to share this after the car has been out for so long!
I kept putting off this project bc I didn't want to run extra power wires through the door grommet.
Just a small tip. I freaked out after doing this mod bc the window didn't automatically rolled up ~1inch after closing the door. (I disconnected battery before staring) Thought I blew a fuse, but wasn't. Just have to open the window all the way down, then all the way up so the window can reinitialze
acuatlsfan is offline   Reply With Quote
The Following User Says Thank You to acuatlsfan For This Useful Post:
FRS_Ken (01-21-2020)
courtesy light, door light
BRZ Driver's Door Courtesy Light Won't Work delusional Issues | Warranty | Recalls / TSB 31 05-29-2022 07:15 AM
LED Door Courtesy Light install FRS2017 DIY (Do-It-Yourself) Guides 16 02-01-2022 11:00 AM
D.I.Y. - BRZ courtesy door light bulb change joergasm DIY (Do-It-Yourself) Guides 24 09-13-2018 02:06 AM
Courtesy Door Light Help Zero90 Cosmetic Modification (Interior/Exterior/Lighting) 5 03-16-2014 08:53 AM
Passenger Door Courtesy Light Wont Turn Off zex Issues | Warranty | Recalls / TSB 12 10-04-2013 01:31 PM
