Old 07-12-2019, 02:21 PM   #127
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
I found out that the older FRS/BRZ OEM wheel has deeper packets than the newer 2017+ OEM Premium wheel.
Pic of the 25mm spacer with replacement 17mm lugs.
Older FRS/BRZ wheel. Narrower but has more depth for thin spacers.
2017+ OEM wheel. Less depth but not so narrow.
"My teacher tells me real beauty is on the inside." "That's just something ugly people say."
xenarc is offline   Reply With Quote
The Following User Says Thank You to xenarc For This Useful Post:
Thefalls (08-01-2020)
Old 07-14-2019, 03:52 AM   #128
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by BcRuZn View Post
I have 20f 25r
I would have probably preferred 15/20 but my spacers came as a set so I went with these..
I believe the reason you'd want narrower spacers for PP wheels is they are 0.5" wider than non-PP with the same offset, which means they poke 6mm more
Old 07-21-2019, 10:08 PM   #129
Iron_dookie
Drives: 13 BRZ
I ran 32mm spacers front and rear for about a year. No issues, and I definitely don't drive timidly. As long as you use quality hubcentric spacers and torque them to spec you should be fine. If you go this route, it will rub on the rear bumper tab. Also, I'm lowered like 2.25"-2.5" on coilovers.
Iron_dookie is offline   Reply With Quote
The Following 2 Users Say Thank You to Iron_dookie For This Useful Post:
smg1138 (10-23-2019), Tristor (12-14-2019)
Old 11-25-2019, 06:49 PM   #130
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
What's the consensus on eBay spacers? Are they any good or total crap? Talking about the bolt-on hub-centric type, not slip-on.
smg1138 is offline   Reply With Quote
Old 11-25-2019, 08:26 PM   #131
Infinity
Drives: 2016 Scion FR-S
I'd like to know this as well. The Blox spacers on ebay look decent. I read some reviews on the Tesla forum that said they were fine.
Infinity is offline   Reply With Quote
The Following User Says Thank You to Infinity For This Useful Post:
smg1138 (11-26-2019)
Old 11-26-2019, 09:25 AM   #132
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
There are 2 school s of thought.
1. Its a hunk of metal, and some studs, what could go wrong.
2. Cheap spacers are made with cheap materials, and they are the only thing holding your wheels on.
BigTuna is offline   Reply With Quote
The Following 2 Users Say Thank You to BigTuna For This Useful Post:
smg1138 (11-26-2019), Tristor (12-14-2019)
Old 11-26-2019, 11:39 AM   #133
smg1138
smg1138's Avatar
One thing I've noticed on the cheap spacers is they use 10.9 grade studs. Seem like the higher end ones all use 12.9 grade studs. Not sure how much of a difference that makes.
Old 11-26-2019, 12:03 PM   #134
JD001
JD001's Avatar
Drives: Subaru BRZ
Get decent kit!! Don't waste money on junk, junk that could put you, your passengers and road users lives at risk!! Not worth considering!
The Following User Says Thank You to JD001 For This Useful Post:
Old 11-29-2019, 12:13 AM   #135
RWDWeekend
RWDWeekend's Avatar
Drives: 2017 Subaru BRZ PP
I have 20f 25r
Looks fantastic. What are you lowered on? This is the exact look I’m seeking for my PP BRZ.
RWDWeekend is offline   Reply With Quote
Old 11-29-2019, 01:20 AM   #136
86MLR
86MLR's Avatar
http://www.ft86club.com/forums/showthread.php?t=137248
Will swap for booze
Need garage space.......and booze
Old 12-14-2019, 10:08 PM   #137
BcRuZn
Drives: 2017 Brz Series Yellow
I am lowered on TRD Springs “eibach pro kit”
BcRuZn is offline   Reply With Quote
Old 06-05-2020, 02:24 AM   #138
TastefulRides
Drives: 2019 Subaru BRZ
Was there rubbing with the stock lugs?
TastefulRides is offline   Reply With Quote
Old 06-05-2020, 11:35 AM   #139
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I have a 2016 FR-S lowered about 1.5" on stock wheels. At the recomendation of this thread, I got 20mm front spacers and 30mm rear spacers. The rears fit about perfect, but the fronts are sunk into the wheel well a bit and not flush. If I had to do it again, I would get 30mm spacers front and rear for ideal fitment.
Mike_ZN6 is offline   Reply With Quote
Old 07-25-2020, 04:11 AM   #140
Misfit714
would 20/f and 25/r fit the brz 2015 with stock wheels? Just want it to be flush.
Misfit714 is offline   Reply With Quote
Best springs+spacers for stock wheels? retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-22-2015 09:52 AM
Spacers on all 4 corners / stock wheels (20mm/25mm) zoltiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-14-2015 12:43 PM
Spacers and stock wheel studs solidONE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-31-2013 09:55 AM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 12:49 PM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 02:31 PM
