Old 12-10-2019, 03:15 PM   #85
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by DarkSideFRS View Post
Ok...lots of conflicting info here.... Assuming an N/A setup (prob with aftermarket headers), is it safe to run e85?
Pat says no with no evident proof, and some swear there are no issues at all in relation to the health of the fuel system and motor...
There is a difference between me not being able to provide proof and it not existing. That said, it is good to have a healthy dose of skepticism for things read in forums, so I understand where you're coming from.
Old 12-10-2019, 06:05 PM   #86
fika84
fika84's Avatar
I can back up @Pat here. I know the shop and person he's referring to and have seen the internals of some of the engines that were torn apart after ~15k miles of running "e85"... One of my understandings of the issue is the range of quality in the gas. I put e85 in quotes because the fuel that comes from the pumps is dirty garbage and that's what primarily causes the crap build up inside the engines. I wouldn't be at all surprised if the quality of e85 differs across state lines as well! Maybe some areas are better than others.
I would be more apt to finding 5-20 gallon drums of VP or Sunoco quality race gas instead of running the e85 from the pump. Just my 2 cents
fika84 is offline   Reply With Quote
Old 12-11-2019, 07:20 AM   #87
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by ROFL it's Waffle View Post
10% ethanol in most pump gas is the "norm" and should be fine.
85% ethanol is a different story https://fuelandfriction.com/weekend-...less-you-know/
that guy is selling something, so you cannot believe a word he says.
In general I've seen people say to run a tank of 93 every month, or every 4 or 5 fill ups, or people run a gallon of 93 every time they fill to cancel out the vast majority of issues e85 can cause.
why? is offline   Reply With Quote
Old 12-11-2019, 10:08 AM   #88
DarkSunrise
DarkSunrise's Avatar
Was it black gunk buildup on injectors that you saw?
2022 BRZ Build
2013 FR-S Build
Old 12-11-2019, 10:55 AM   #89
fika84
fika84's Avatar
It was a ton of black gunk on top of the pistons. But I have to imagine it was elsewhere too!
Old 12-11-2019, 04:51 PM   #90
Lantanafrs2
Drives: 2013 frs red
Drag reducing agents in the fuel.
Lantanafrs2 is offline   Reply With Quote
Old 12-11-2019, 05:57 PM   #91
Lantanafrs2
I think it has more to do with who is supplying the fuel.
Old 12-12-2019, 06:45 AM   #92
why?
why?'s Avatar
Drives: series.blue
and if the gas station has ever cleaned anything internally. I can imagine after a decade or two the crap that can build up in those pumps and tanks is pretty horrific.
Old 09-28-2021, 01:23 AM   #93
KurtFehl
Unhappy
Originally Posted by Surok View Post
http://www.vpracing.com.au/product/vp-m2c try about 300ML in 1 tank of E85
Sorry to post on an old thread but I have to +1 this.
I am currently having to replace my engine with about 25,000-30,000 miles on primarily E85 due to scoring/pitting to the cylinder walls and damage to the piston rings, only making about 30psi average of compression across the cylinders.
I was also dealing with a prolonged issue with my OCV's and the exhaust cam phaser on the right side of the engine, so that's not to say that running E85 was the only cause of the issue. However my tuner and a Subaru master tech came to the conclusion that the damage to the cylinders and rings was most likely caused by a lack of lubrication from using E85 without a lubrication additive.
I have a AVO turbo and was at 350whp and 280fl/lbs on 12PSI at the time but after this loss I am going to use pump gas until I can come up with a more permanent solution.
I know it's just a story and "anecdotal evidence" but for what its worth, just throwing it out there.
KurtFehl is offline   Reply With Quote
Old 09-28-2021, 06:44 AM   #94
Lantanafrs2
^ I think the boost was the bigger problem. I appreciate your post but many have gone 6 figures or close to it on ethanol. I've never read about boosted cars lasting that long.
Old 09-28-2021, 12:06 PM   #95
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Looks like not enough ring gap to me
Old 09-28-2021, 12:50 PM   #96
alphasaur
friendly
Drives: 17' 86
Back in my mazdaspeed 3/6 days when we were experimenting with ethanol we would run into an issue called "black death". Effectively what would happen was engine oil would mix with some fuel in the HPFP and cause a black sludge to develop on the HPFP internals and prevent the HPFP from working. The HPFP would function again after cleaning. This issue only presented in high concentrations of eth and could be completely avoided by running a 30-50% blend. 30-50% was also a sufficient amount eth to hit MBT so running higher percentages provided minimal benefit.
Just some food for thought.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 09-28-2021, 03:18 PM   #97
Frankz54
Drives: 2019 Toyota GT86
I'm now 20k miles on my 2019 86 and no issues what so ever. Have never gone back to octane 93.
Frankz54 is offline   Reply With Quote
Old 09-28-2021, 04:49 PM   #98
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
My AVO kit went on at 5k miles, just over 30k now and still running strong 90+% E85. I track at 6 to 7psi and play at 9 to 10psi.
Long term E85 use redrocket89 Engine, Exhaust, Transmission 92 06-28-2021 05:40 AM
Long-term adverse effects of Whiteline chassis inserts? ApexEight Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 09-07-2017 07:13 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
