Old 09-15-2019, 10:42 PM   #57
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by lextrueno View Post
E85 is made unfit to drink because of the gasoline as the additive.
SO why not go with E97 or something equivalent that is still unsafe to drink and higher percentage? Because gasoline stabilizes ethanol, espcially in the cold. Gasoline can vaporize at very low temperatures which is why it is added. When there is 15% or more gasoline, there is enough vapors to spark at low temps.
I was just curious. I did not know why they added 15% gasoline. I’ve been reading up on it. 100% Ethanol is used in Brazil in some cases and they use a prewarmer or a separate gasoline tank for “cold starts” below 15c lol
I’m still curious as to the additives/lubricants that are used with E85. Ethanol can be purchased by the drum
Old 09-16-2019, 03:03 AM   #58
spike021
spike021's Avatar
Originally Posted by Breadman View Post
i toss in a squirt of injector cleaner every tank since i fill up almost weekly
Is this sufficient compared to filling up every few tanks with 91 or 93? Reason I ask is because since getting my flex fuel kit back in July I’d only been filling with E85 and this week had to use 91 to clean the injectors because I’d started getting some rough idling at times.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 09-16-2019, 12:16 PM   #59
It would be unfit to drink (in any volume over a sip) even without the gasoline added. It is far, far stronger that the consumable versions. The reason the gasoline is added are explained in the second part of your answer very well. The first part is just not true though.
Old 09-16-2019, 01:48 PM   #60
Lantanafrs2
Drives: 2013 frs red
Tell that to grandpa
Lantanafrs2 is offline   Reply With Quote
Old 09-16-2019, 01:50 PM   #61
Lantanafrs2
Made a few crackles and pops and keeled over. Guess we loaded the wrong tune?
Old 09-16-2019, 06:58 PM   #62
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
ive been doing it for over a year and works for me
Old 09-17-2019, 09:18 PM   #63
lextrueno
lextrueno's Avatar
Drives: 2013 Firestorm Frs
Darn, I've disappointed you just like I disappointed my dad.
lextrueno is offline   Reply With Quote
Old 09-17-2019, 10:03 PM   #64
Lantanafrs2
Dont take it personally
Old 12-09-2019, 11:49 AM   #65
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Originally Posted by 8RZ View Post
I doubt it's an issue for modern cars since gas has had small amounts of ethanol in it for years now. Older cars were not designed to run it so I've heard fuel line and pump issues but that's all moot now.
10% ethanol in most pump gas is the "norm" and should be fine.
85% ethanol is a different story https://fuelandfriction.com/weekend-...less-you-know/
ROFL it's Waffle is offline   Reply With Quote
Old 12-09-2019, 12:43 PM   #66
DarkSideFRS
Drives: 2013 pearl white FR-S
So, is it safe to use e85 or do we have rubber components in our fuel system? I have 3 gas stations nearby with e85
DarkSideFRS is offline   Reply With Quote
Old 12-09-2019, 12:46 PM   #67
DarkSunrise
DarkSunrise's Avatar
Had my first hard start with e85 today. Temps were in the 50's and my car had sat for about 2 weeks while I was on vacation. Engine died on first start, but cranked over fine on the second try.
After that, the engine felt great on the drive. Forgot how much the combination of cooler temps and e85 really wakes the engine up.
2022 BRZ Build
2013 FR-S Build
Old 12-09-2019, 01:10 PM   #68
Fred E
Drives: WRB BRZ
Completely safe to use E85 in these cars. People have been doing so for thousands upon thousands of miles since this car first came out. Personally, I have driven on E85 for 100k miles across two BRZs.
If you're NA, you don't need to change any fuel system components (except the flex fuel kit if you want to make sure your ECU knows the actual ethanol content). If you're FI and under 400whp, you only need larger port injectors, and a larger in-tank pump if you're aiming over 400whp.
Fred E is offline   Reply With Quote
Old 12-09-2019, 02:59 PM   #69
Pat
Pat's Avatar
Drives: 2023 BRZ
Have you seen one of our engines that has had ethanol run through it for 100,000 miles? I am told it's not pretty.
Old 12-09-2019, 05:05 PM   #70
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Have you seen any kind of actual evidence of that? People like to talk a lot of trash on the internet, but I've never seen any proof of e85 having negative effects on our cars.
smg1138 is offline   Reply With Quote
Long term E85 use redrocket89 Engine, Exhaust, Transmission 92 06-28-2021 05:40 AM
Long-term adverse effects of Whiteline chassis inserts? ApexEight Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 09-07-2017 07:13 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
