Old 12-10-2019, 10:21 AM   #1
Alpha86
Drives: 2013 Firestorm Red FRS
Carpeting Panels for Sound Deadening
Hi guys,
I saw the thread about adding insulation to the interior panels, but it doesn't seem like many people have considered adding carpeting to the exterior, underpanels, etc. I've thought about carpeting the wheel wells and adding it to a Verus transmission tunnel cover, would these areas affect anything? What kind of carpet or material should you use? Thoughts?
Alpha86 is offline   Reply With Quote
Old 12-10-2019, 11:28 AM   #2
toast
Drives: 14 BSP Edelbrock BRZ
You're talking about under the trim panels? Carpet retains moisture too well. If you want to help with sound get yourself a big roll of Ensolite, a couple cans of super90 spray glue, some instructions on how to remove the entire interior and a weekend. It can make a pretty big difference. My car is considerably quieter than a stock BRZ. You'll never get to Audi levels of sound but it can make a big difference.
toast is offline   Reply With Quote
Old 12-10-2019, 11:42 AM   #3
Alpha86
Not on the interior, I think that's been addressed very well. How about one step further? All these new manufacturers are using carpet undertrays to isolate road and tire noise. Higher end cars like Mercedes use carpet on the plastic wheel well cover for the same reason. Does this work? Maybe not carpet, if there's some sort of outdoor use foam as well. How about inside the hood and fenders?
Old 12-10-2019, 12:19 PM   #4
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
http://www.dynamat.com/
Pretty sure this is what you're asking about. Way different from "carpeting."
Unless you meant like "carpet material" that's found in the wheel wells. I think that's more to prevent damage from road debris than it is for sound deadening.
ROFL it's Waffle is offline   Reply With Quote
Old 12-10-2019, 04:41 PM   #5
86MLR
86MLR's Avatar
I've seen astro turf used on inner guards.
Not for years though.
I wouldn't do it.
Old 12-10-2019, 06:56 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
on a scale of 1-10, how afraid of you are rust?
Old 05-14-2020, 09:58 PM   #7
DreamSpeedBRZ
Drives: 2017 86
Originally Posted by Alpha86 View Post
Hi guys,
I'm about to try this. I'm going to use foil backed insulation and seal the edges with aluminum hvac tape so no moisture can get behind it. I'm going to do the front wheel wells and see how it works. I just installed the oem underbody aero panels, I might take them back off and put some of the same insulation in them so they absorb a little more road noise. Will probably just put a little nearest the front wheels and transmission.
How do you like the exhaust tunnel covers? I've been thinking about getting that too.
DreamSpeedBRZ is offline   Reply With Quote
Old 05-15-2020, 12:03 AM   #8
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Without knowing exactly where and what you are trying to damp, I'd recommend these products for interior applications:
1. https://tinyurl.com/ycat9a5l
2. https://tinyurl.com/y7zpdgzv
3. https://tinyurl.com/y78bf6c5 (messy and difficult to apply, but works great)
Source: I'm an NVH Engineer
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 05-15-2020, 11:06 AM   #9
Ernest72
I have used dynamite or equivalent and ensolite with good results. Carpet is heavy and would add weight without achieving what you want.
Dynamite for vibration absorption
Ensolite or foam for sound deadening.
Think about acoustic or quiet rooms for music, tons of foam on the walls.
Sound Deadening Ernest72 Engine, Exhaust, Transmission 18 02-07-2018 07:18 PM
What are you using for sound deadening ? mashal Electronics | Audio | NAV | Infotainment 108 11-06-2015 12:51 PM
SOUND DEADENING White64Goat BRZ First-Gen (2012+) — General Topics 7 04-22-2013 01:36 AM
Sound deadening yomchi1989 Electronics | Audio | NAV | Infotainment 16 01-02-2013 02:08 PM
Sound deadening yomchi1989 AUSTRALIA 9 12-27-2012 09:09 PM
