Old 09-10-2019, 05:51 PM   #1
COBlue
COBlue's Avatar
Drives: 2017 Subaru BRZ Limited PP
Brakes(?) squeaking when hot but not applied
2017 PP with 8,000 miles on current stock pads and rotors. Fourth time at the track on current brakes, sessions 3&4 I noticed a speed dependent high pitched intermittent squeaking after a few laps returning to the paddock when the brakes were NOT being applied. (Hadn't noticed on previous track days.) Quieter and a little higher pitched than normal brake application squeaking. Rotors ~280-300F. Noise is gone after cooling and never present for DD.
Possible slight brake drag/rubbing from heat expansion? Local shop says pretty normal and no issue as long as temps even and not present for DD. Anyone else experience this?
COBlue is offline   Reply With Quote
Old 12-08-2019, 06:11 PM   #2
jflogerzi
jflogerzi's Avatar
Rotors wraped?
2013 Series 10 FRS #553
Old 12-08-2019, 06:51 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by jflogerzi View Post
Rotors wraped?
Rotors don't warp.
Others have noted the pp brembos are noisy. Part of the joys of brembos
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
strat61caster (12-08-2019), Tcoat (12-10-2019)
Old 12-08-2019, 07:51 PM   #4
COBlue
COBlue's Avatar
Rotors don't warp.
They definitely squeak at the right (wrong) brake pressure, but this is different from that. Quieter, higher pitch and only with no brake pressure.
Season is over out here, will see if it's back in the Spring. Just odd I didn't hear it last season but I did this year (both years had basically new brakes: first season new car/brakes, second season new brakes because Subaru replace them due to pulsing).
Old 12-09-2019, 11:36 AM   #5
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Get better pads and fluid before next track day
TommyW is offline   Reply With Quote
Old 12-09-2019, 11:39 AM   #6
COBlue
COBlue's Avatar
I put Motul RBF 600 in there before the first track, but yes, have been considering better pads.
Suggestions? (It's also my DD)
Old 12-09-2019, 12:07 PM   #7
BRZ383
Drives: 2018 BRZTs,
I just installed Porterfiled R4S pads front and rear on my PP BRZ my initial impressions are good, they have a good bite when cold and warm. they are advertised to not squeak and have little dust.
BRZ383 is offline   Reply With Quote
Old 12-09-2019, 11:06 PM   #8
TommyW
TommyW's Avatar
there are a lot of good ones I’m using powerstop Track Day pads and great on the street and great on the track for HPDE 20-30 minute stints. Quiet also. I’ve seen a lot of combo pads that were very loud. I have 12000 miles on em and. Several track days. Replacing rotors tomorrow and will see how the pads look. I bought a new set in case they’re getting down there
Knocking/Rattling Sound when stopped with brakes applied. darkslide18 Engine, Exhaust, Transmission 2 03-06-2019 01:57 PM
[SOLVED] Grinding / Squeaking noise FL Brakes kakacarrotcake Issues | Warranty | Recalls / TSB 14 03-01-2017 02:51 PM
Nitro seal applied bacon_cheese_beer Cosmetic Modification (Interior/Exterior/Lighting) 0 11-19-2012 01:22 PM
Cquartz finest Applied-firestorm kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 21 09-25-2012 12:44 PM
3M Di-Noc Applied to Interior PrimeMotoring Cosmetic Modification (Interior/Exterior/Lighting) 28 06-24-2012 04:24 PM
