Old 12-02-2019, 01:56 PM   #4173
JimmyBoy
Drives: 2013 BRZ WRB
Originally Posted by Vital View Post
No, there's no downside of getting slightly wider wheels. A 215/45/17 tire size will fit on a 17x8 wheel just fine, but if you decide you want to get wheels that are 17x8.5 or higher you will need a 225/45/17 or larger.
Thanks for your help! So I wouldn't notice any performance or handling differences between these tires that are only slightly different in size?
JimmyBoy is offline   Reply With Quote
The Following User Says Thank You to JimmyBoy For This Useful Post:
Vital (12-02-2019)
Old 12-02-2019, 02:02 PM   #4174
Suzuyans
Something something
Drives: 2017 BRZ (Vortech), 1993 R32 GT-R
It will likely fit with a 245/35 tire or maybe 235/40. I dont think you'd be able to fit a 255/35, but all tires are different and have slight variances. No, the camber bolt isnt going to give you clearance if anything it will hinder it because if you decide to run camber in the front its only going to be get closer to the spring perches.
Okay thanks!
Sounds like my only option is to get coilovers or run 245 tires then.
I guess I might as well run coilovers since the Toyo Tires I'm getting with are very good already.
Suzuyans is offline   Reply With Quote
The Following User Says Thank You to Suzuyans For This Useful Post:
Vital (12-02-2019)
Old 12-02-2019, 02:41 PM   #4175
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Originally Posted by Suzuyans View Post
Yeah that's the thing I'm worried about is not clearing the stock suspension since it apparently it'll sit very close to the spring perch.
I'm probably getting wheels first then coilovers later. Afraid someone might snatch them before I can get to them.
Any word on if it rubs though?
Might be getting the TEIN Flex Z coilovers. Also thinking about just getting 245s as well.
EDIT: Would camber bolts do anything?
I'm admittedly not very knowledgeable when it comes to wheel/suspension stuff on cars.
Pretty much what @Vital said. I would test fit the 255s and see how they work out. If they rub, you could get some spacers or just switch out for 245s. But the tires are good so I'd just get the Flex Zs to run the 255s safely. Camber bolts are to dial in front camber and fix poke, but they will bring your tire closer to the strut so they won't really help anything.
Slightly different can actually improve performance and handling as long as you can get a lighter than stock wheel and a 225 tire. You would be reducing weight and increasing grip.
Will BRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to Will BRZ For This Useful Post:
Leonardo (12-02-2019), Suzuyans (12-02-2019), Vital (12-02-2019)
Old 12-02-2019, 03:02 PM   #4176
Suzuyans
Something something
Alright cool. I'll look into running 5mm spacers for the time being since it's very minimal.
Thanks!
Will handling be affected if I just had 5MM spacers to the front and not the rear? From what I heard, the back clears just fine.
Otherwise coilovers first to me.
This is pretty much the last peace of mind I need.
Old 12-02-2019, 03:51 PM   #4177
Vital
Drives: 2015 BRZ
Thanks!
Personally, i would start with a 3mm spacer. I think with a 5mm spacer you might need extended studs. No, the handling wont be affected much for you to even notice.
The Following User Says Thank You to Vital For This Useful Post:
Old 12-02-2019, 04:14 PM   #4178
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks!
I agree with @Vital. Adding a 5mm spacer, that needs extended studs, adds cost and labor. And, with out any room to add negative camber, it will poke 5mm more. A 3mm would be better, if it is needed.
A 18x9.5 +32 = 17x7 +0 offset. This is setup (18x9.5 +32) will poke like a stock wheel with a 64mm spacer. if a 30mm spacer is needed to make a stock wheel flush in the front, then your new wheel will poke 34mm.
I would just get a 245/35/18 front tire for your +35 offset 18x9.5 wheels. YOu can run a 255/35 in the rear. This small stagger won't change your cars feel that much at all. Then, later, after you get coils, you can add a bunch of negative camber, and matching front tires.
Or get coils first, it is something to contemplate...
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Vital (12-03-2019), Will BRZ (12-02-2019)
Old 12-02-2019, 10:17 PM   #4179
jRuN
Got some 18x9.5 +35 wheels. What is the widest tire I can run? I have coilovers with adjustable camber in the front and rear. I wouldn't mind running a meatier 40 tire vs a 35 too. But if I need to run a 35 too be able to squeeze a 255 in there that's fine.
Should I get the fenders rolled regardless with a 9.5 wide wheel?
Sent from my Pixel XL using Tapatalk
jRuN is offline   Reply With Quote
Old 12-02-2019, 11:06 PM   #4180
Sev995
Drives: Black 2013 frs
Originally Posted by jRuN View Post
Got some 18x9.5 +35 wheels. What is the widest tire I can run? I have coilovers with adjustable camber in the front and rear. I wouldn't mind running a meatier 40 tire vs a 35 too. But if I need to run a 35 too be able to squeeze a 255 in there that's fine. You can always go with a wider tire but it really depends on your coilover.
You should be able to snuggly fit a 245/40r18 in there, since that size fits stock. The stock spring are pretty big so any coilover would help with that Clarence. Depending on how low you want to ride will depend if you scrape, the wheel should fit fine on the outside so no fender rolling needed. If you are trying for a 255 you might scrape, but there is decent room if you don't lower to much.
Sev995 is offline   Reply With Quote
Old 12-03-2019, 07:38 AM   #4181
Vital
Drives: 2015 BRZ
You will easily be able to fit a 255/35/18 tire. Idk why you would want to use a 255/40/18 tire that tire is way too tall. On coilovers you shouldnt have issues as theres way more clearance.
Leonardo (12-03-2019)
Old 12-03-2019, 08:00 AM   #4182
jRuN
Any need to roll the fender with that 255/35 ? I guess I just think about a 40 tire providing a little more protection from harsh road conditions, potholes etc
Old 12-03-2019, 09:29 AM   #4183
Vital
Drives: 2015 BRZ
No i dont think you need to roll fenders for that spec wheel. That size has become pretty common these days. Although it will depend on how low you are though...
Old 12-22-2019, 12:44 AM   #4184
Suzuyans
Something something
Turns out the tires I got were bad sadly. Two were torn.
I'm on stock suspension as before but.
Does 245/35/18 Nankang NS-25 rub with 18x9.5 wheels on stock suspension? I keep hearing different answers about it.
Option Lab R716s.
Old 12-22-2019, 07:49 AM   #4185
jRuN
Please delete
Old 01-17-2020, 12:32 PM   #4186
equachie
Drives: Subaru Brz - WRB
Will 17 x8.5 +30 fit on stock suspension? I know it'll poke a bit, but I want to ensure before pulling the trigger on a purchase.
If it does, what tire sizes would you recommend to limit any potential for rubbing?
equachie is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
