Old 11-26-2019, 10:15 PM   #1
solidsnake11
Drives: brz
76mm throttle body replace 65mm
C
solidsnake11 is offline   Reply With Quote
Old 11-26-2019, 10:29 PM   #2
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
If you have a 76mm intake manifold to go along with it, then why not?
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
The Following User Says Thank You to Spawn_Of_Creation For This Useful Post:
SuperTom (11-28-2019)
Old 11-27-2019, 12:54 AM   #3
PulsarBeeerz
Drives: JRSC BRZ SOLD
I run a 72mm TB on the red MY17 IM. It is port matched to 72mm as well and totally worth it. I believe the black IM opening is ~67-68mm.
PulsarBeeerz is offline   Reply With Quote
Old 11-27-2019, 08:42 AM   #4
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by solidsnake11 View Post
$72.00 Upgrade. I haven't drove it yet but it runs without codes.
correct me if im wrong but you shouldnt get a code because the air is already metered
Old 11-27-2019, 11:13 AM   #5
Stomachbuzz
Drives: 2013 FRS
There are many reasons it could throw a code if the air flow is suddenly changed.
Going from a 65mm diameter throttle body to a 76mm diameter (quite a large jump, in my opinion) is a ~37% increase in flow area (bore of the TB), which is huge.
That much increase in flow area is going to significantly change the pressure inside the manifold, which is measured by the MAP (manifold absolute pressure) sensor. It is also going to change air velocity. Not sure if velocity is directly measured by the computer, indirectly, or maybe not at all.
As air velocity changes, it will change how the air interacts with the incoming fuel - both the port injection and direct injection inside the cylinder.
I suspect port injection will not change much, but I do know that direct injection is heavily dependent on strong air velocity, creating a 'swirl' effect inside the cylinder.
Even if there were no official codes thrown, I would fully expect the car to 'run like shit' if handicapped with that huge of a throttle body.
Stomachbuzz is offline   Reply With Quote
Old 11-27-2019, 11:47 AM   #6
Breadman
Breadman's Avatar
oh yeah without a tune its gonna run like shit. i just meant that it shouldnt throw a lean code because its all metered. at least from my understanding
Old 11-27-2019, 01:51 PM   #7
Grady
Grady's Avatar
The throttle body is not the restrictive part of the intake. It may be 37% larger but you are not going to get 37% more air. Look at the size fo the intake just before it, it is probably 40% smaller. Airflow will slow down, pressure and temp will drop. Then it will speed back up pressure temp will increase again when the air hits the restriction of the intake ports. The ECU will figure out any minor changes this made and be happy.
The Following 2 Users Say Thank You to Grady For This Useful Post:
mrg666 (11-28-2019), wparsons (11-28-2019)
Old 11-27-2019, 02:29 PM   #8
Grady
Grady's Avatar
Tube is 73mm id throttle body is 76mm id. The outside makes it look bigger.
The oem throttle body was the biggest restriction in my cold side.
I am not saying it is not going to help, and the price you have in it is reasonable for a 2% improvement. I just do not see the 37% more air coming in is going to confuse the ECU theory.
Old 11-27-2019, 03:21 PM   #9
StraightOuttaCanadaEh
Wes
I think it’s more about initial throttle response than power. People report just that when they install a larger throttle body. It’s because the air rushes in faster through a larger opening but then it reaches a plateau so you might shift your power curve a bit but unless you’re FI, I doubt there will be more power
Instagram: @gt86ws
Old 11-27-2019, 03:44 PM   #10
Lantanafrs2
Drives: 2013 frs red
Motor doesn't need 37 percent more air, unless it's being pushed in
Lantanafrs2 is offline   Reply With Quote
Old 11-27-2019, 04:55 PM   #11
Lantanafrs2
Goto post 4 and slide picture over.
Gotcha. Thank you
Old 11-27-2019, 10:43 PM   #12
Hawk77FT
Drives: GTS 86
The air will run slower through a bigger diameter! That't not a Bollywood movie where the physics don't apply man!
Hawk77FT is offline   Reply With Quote
Old 11-28-2019, 12:03 AM   #13
PulsarBeeerz
Slower velocity and greater air mass. Like quickly breathing through a straw vs an open mouth.lol
Old 11-28-2019, 09:53 AM   #14
wparsons
wparsons's Avatar
You sure about that? I'll bet the intake runners or even the head are still more of a restriction.
With the bigger throttle plate it'll feel more responsive because you're getting more air at smaller throttle openings (unless you remap the throttle curve), I'd be shocked if it actually makes a significant amount more power (even boosted) over the stock one unless you replace the intake manifold and open up the head (and cams).
I'd compare a log of the raw MAF reading before and after the swap to see if it's actually flowing more air at WOT or not. It doesn't matter if the TB flows more air, if it can't get into the combustion chamber it'll still be backed up before the TB.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
Grady (11-28-2019), Icecreamtruk (12-13-2019), mrg666 (11-28-2019)
WTB FRS/BRZ Throttle Body Tboxer Want-To-Buy Requests 3 12-01-2014 12:13 PM
toyota 1gr 76mm throttlr body michael336 Engine, Exhaust, Transmission 115 06-13-2014 05:50 PM
BIU (body integragted unit) replace wrohdejr Cosmetic Modification (Interior/Exterior/Lighting) 2 02-25-2013 03:15 PM
