Sam Strano
Old 02-04-2019, 12:14 AM   #4803
Shadotracker
Drives: 2018 Subaru BRZ TS
And thus starts a new season of Autocross.
Shadotracker is offline   Reply With Quote
The Following 2 Users Say Thank You to Shadotracker For This Useful Post:
DocWalt (02-07-2019), strat61caster (02-04-2019)
Old 02-04-2019, 03:18 PM   #4804
jtmroczk
Drives: C-Street FR-S
Originally Posted by KevBRZ View Post
Yeah i agree, i added parts one by one on my old stx civic and i liked that, i was starting to think about starting with those konis and also possibly the front bar from the kit, but i may end up having to order the bar again with the kit from tire rack in the future being I am not sure if they can be separated,Not sure how that bar would fair for D street (although not sure how competitive i will be anyhow) ,but even if i get a specific D street bar i could always just resell it on here etc. and also thought about just running the falkens also to start so i would learn those along the way, although i do have some z2s that are getting old and need to be used up. i would say SSC sounds very likely for 2020.If not SSC then STX.
If you go SSC, I would suggest buying the whole kit ASAP. You cant, LOL “can’t”, make a mistake in the purchasing stage. It has pretty minimal tuning and you can also easily folow another more experienced competators damper setting selections. Aswell as underatand what your car, and maybe aspirationaly yourself, is realistically capable of by watching others on course.
Now STX, pretty well none of the above applies and you can even screw up the car with a pourly selected set of coilovers, generally speaking.
jtmroczk is offline   Reply With Quote
Old 02-08-2019, 03:16 AM   #4805
Shadotracker
Quick question just to make sure I am understanding something. We can change the struts/shocks but can we change the springs as well or must they remain stock?
Old 02-08-2019, 06:20 AM   #4806
TMF
TMF's Avatar
Drives: '14 FRS TT5
Springs must stay stock. Unless it says you can, you can't
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 11-19-2019, 01:58 PM   #4807
Mball19
Drives: Toyota 86 TRD/SE
Originally Posted by doctor_driver View Post
So I just got into a 2017 BRZ-PP and have a Spec-D Tuning Catback Exhaust (the neighbor's are big fans) and a set of Enkei RPF1's 17x7.5 (having to use 5mm spacers to clear brembo's) with BFG Rival S 1.5 245/40/17 (probably too wide but I wanted to try out the new BFG -there was no 235 option- and get as much out of the extra half inch on the wheels as i could).
Does anyone know of any front bar upgrades or brake pads that autocrossers have been successful with in the 17 PP? Or is this a time where progress requires experimentation?
Are you running the 5mm spacers with the stock studs?
Mball19 is offline   Reply With Quote
Old 11-20-2019, 11:35 AM   #4808
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'd suggest not doing that. 3mm is about the max for safe thread engagement with stock studs.
The Following User Says Thank You to DocWalt For This Useful Post:
Clutch Dog (11-20-2019)
Old 11-21-2019, 12:07 PM   #4809
Mball19
I won't
The Following User Says Thank You to Mball19 For This Useful Post:
DocWalt (11-21-2019)
Old 11-21-2019, 12:08 PM   #4810
Mball19
I am planning on running my 86 in CS in 2020. I ran it in DS this year. My current mods are Toyota camber bolts, a TRD front bar and RE71s. The car felt great and would rotate on demand. I will install the TRD springs and rear sway bar. I have a couple of questions.
1. Are the Sachs struts ok with the TRD springs? I have had several sets of Konis on other cars and was unimpressed with the quality of the last 2 sets that I had. I would prefer to keep my stock struts or go with Cuscos.
2. I have a 22mm Perrin front bar also. Is this too much front bar for the TRD rear bar? I felt it was too much for the stock rear bar and springs.
3. Is there a preferred alignment with the CS mods?
Old 11-21-2019, 10:32 PM   #4811
Biggins
Drives: Yes
1. Yes. I have no experience with the Sachs, but the stock struts/shocks are very good. I would pick the Konis over the Cuscos and Sachs, but I still think the stocks are really good. I'm on the CS-legal MCS 2WNR set-up which are a different level of cost/performance. I don't know the cost of the Sachs, but I suspect they will be okay.
2. It depends on driving style and other set up choices. I am running both TRD bars and am content with it. I have previously run a 25mm Hotchkis and 19mm Perrin with success. I will eventually switch to the Karcepts trick bar, but I think you will be fine with the 22mm on soft.
3. Max camber, very slight toe out in front, 0 toe or very slight toe in in the rear.
I'm also switching back to CS this year, so let's see if we can surprise some NDs and S2ks!
Biggins is offline   Reply With Quote
The Following User Says Thank You to Biggins For This Useful Post:
Clutch Dog (11-22-2019)
Old 11-22-2019, 03:48 PM   #4812
Mball19
Coming from a WRX, this car is just so much fun to drive. I want to be competitive but, mainly have fun. I was beating the NDs and Fiats in DS configuration, so I think that CS will be even more fun. Thanks for the input. I will probably try the TRD front bar first and see if I need more.
strat61caster (11-22-2019)
Old 11-22-2019, 04:58 PM   #4813
oofie
Might be a stupid question, but how do you guys (Biggins and Mball19) switch between CS and DS?
oofie is offline   Reply With Quote
Old 11-22-2019, 05:04 PM   #4814
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
TRD package was considered factory equipment on the RS1.0 an RS2.0 FR-S so TRD lowering springs and swaybars were allowed on all FR-S's and they bumped the non-TRD pack FRS and all BRZ's down to DS. The option exists on the 86 as well so pre/post facelift isn't an issue and I believe parts are the same.
It's called out in Appendix A for both CS/DS citing with/without TRD pack.
Edit: I didn't realize the 86 without TRD stuff was classed in DS which is nice, I think it's got a better shot at being a dark horse in that class by being more agile than the souped up economy cars whereas the ND Miata is just better in CS. But hey as above make the car fun and who cares, stiffer springs and sways should help with the camber wear and transitions.
ineedyourdiddly
oofie (11-22-2019)
Old 01-30-2020, 10:36 AM   #4815
Mball19
I have my TRD springs and bars installed. I am getting it aligned on Saturday. My alignment plan, based on your suggestion is max front negative camber, 1/8" toe out and matching the front camber in the rear with 0 toe. I'll see how it goes.
I am signed up for the Dixie tour. So far I am the only car in CS with a fixed roof.
Clutch Dog (01-30-2020)
Old 02-07-2020, 01:54 PM   #4816
Jrwilliams
Jrwilliams's Avatar
I just picked up a 17' BRZ non PP in november. I used to autoX my camaro but I'll be running in DS class. Got some RS4's on the way, OEM crash bolts but beyond that I am just gunna run the car flat out as is and see where I think it needs anything. Probably get a factionfab catback exhaust. They sound good and only weight 17lbs!
Jrwilliams is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
