| Software Tuning Discuss all software tuning topics. |
Drives: Yellow FR-S Rs 1.0
Warm start issues with bigger injectors
I recently had id1050 injectors, warlboro 485, with delicious flex fuel kit installed on my car. I went through two different tuners and still cant figure why my car has problems when starting at warm start. The car cranks and fires then there is a massive rpm dip to sometimes 450 rpm. Sometimes it goes lower and stalls (not as often). I asked few folks and some have the issue and some don't. So not exactly sure whether this is an after effect of having bigger injectors or something is wrong with tuning/mechanical. Cold starts are absolutely fine and I have no problems with rpm dips or stalling.
Below is the video I was able to capture. |
#2 |
Drives: brz 2017 hksv2
You need to log this and upload it to datazap if you want help
| The Following User Says Thank You to tomm.brz For This Useful Post: | Ultramaroon (11-17-2019) |
#3 |
Drives: Toyota 86 Turbo, Lexus NX300H
I solved same problem by zeroing out MAF correction after start (neutral) table .
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
| The Following User Says Thank You to Yobiwan For This Useful Post: | steve99 (11-18-2019) |
#4 |
I dont know, shouldn t the first 2 rows active during cols start? He said cold start is good
| The Following User Says Thank You to tomm.brz For This Useful Post: | Yobiwan (11-18-2019) |
#5 |
#6 | |
maybe zeroing out middle section (warm temperature area ) will be enough for effect. but I didn't test that.
#7 | |
adding the numbers of specific temerature range solved problem.
| The Following User Says Thank You to Yobiwan For This Useful Post: | tomm.brz (11-26-2019) |
| help!! can’t get car to start with bigger injectors | Kalebhall | Software Tuning | 15 | 02-17-2020 06:22 PM |
| WTB: Bigger Injectors, Fuel Pump & Flex Fuel Kit | spagti | Want-To-Buy Requests | 4 | 04-13-2019 03:33 PM |
| ECU reset + warm start = stall | phrosty | Issues | Warranty | Recalls / TSB | 3 | 04-08-2018 06:31 AM |
| Bigger injectors ecutek | aquaman | Software Tuning | 2 | 04-05-2017 01:15 PM |
| E85 issues with injectors? | CaptainSlow | Software Tuning | 66 | 07-31-2016 10:47 AM |
