Old 10-31-2019, 06:17 AM   #15
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by 86MLR View Post
Wrapping is much more efficient than ceramic coating.
In saying that we don't use salt on the road here, so IRT wrap and contamination for your area, I have no idea.
Lagging a header on a street car is a really good idea, the added temps from an unlagged header when you are sitting in traffic is huge.
Ceramic coating should be inside and outside.
Ceramic coating only the outside will not have a large effect, it will negate some corrosion though, but minimal heat.
Painting a header with high temp paint (protects against corrosion) and then wrapping (heat retention) gives the best of both worlds.
I have had headers ceramic coated and wrapped before, but, I feel the additional cost of the ceramic coating was unjustified when some high temp paint could have been used, with simular results in heat control.
I am currently waiting for a time to put my car up on a lift or over a pit to wrap the AVO turbo manifold and dump, they are coated, and the coating seems to be holding up well, but, not really what I would call efficient at heat control in comparison to a wrapped header.
The best place to get ceramic coating done is at an industrial flame coating place.
Ceramic coating to control temps isn't just a case of spraying on a coat, sadly this is what all alot of places do, and they charge alot of coin for it.
Quality of base materials, thickness of coating and longevity are also things to concider.
then remember to keep an estinguer in your car, since you are also SCed if I don't recall wrong
or if you end up like me with a thrown rod that caused a lot of oil to go over a 800°C header and start a fire, you will regret not having one
If my header were wrapped , fire wouldn't stop by itself after 1 minute without other damages
Old 10-31-2019, 06:52 PM   #16
86MLR
86MLR's Avatar
I always have a 2.5kg extinguisher
Anything under 2.5kg is just hopeful thinking
Old habit from when I was a track junkie
The Following User Says Thank You to 86MLR For This Useful Post:
Tristor (11-01-2019)
Old 10-31-2019, 07:46 PM   #17
Hawk77FT
Drives: GTS 86
I would say one or the other. Wrapping over ceramic coating increases the chances of the coating to be overheated and eventually flake off. The other thing to consider, is the quality of the header and welds in particular. The ceramic coating will help with keeping the heat inside the tube, so when you add another layer of "protection" you contribute to increasing the temps in the manifold which will cause fatigue on the actual manifold. That could cause welds cracking, etc.
But, up to you! Your choice, your money.
Hawk77FT is offline   Reply With Quote
Old 10-31-2019, 11:16 PM   #18
86MLR
86MLR's Avatar
I lied, it's a 1.5kg
This one >
Old 11-01-2019, 05:22 PM   #19
Grady
Grady's Avatar
The extra layer will slow down cooling. this will help reduce stress. only time it is too hot is if it melts.
The Following User Says Thank You to Grady For This Useful Post:
Old 11-01-2019, 11:04 PM   #20
lamawithonel
Drives: 2014 Subaru BRZ Ltd.
https://www.ft86club.com/forums/show...0&postcount=24
http://www.ft86club.com/forums/showp...4&postcount=31
*question everything*learn something*answer nothing*
lamawithonel is offline   Reply With Quote
Old 11-02-2019, 02:05 AM   #21
Impureclient
Drives: 2015 FR-S
Pretty sure I can touch my header very shortly after it's off after running the car up to full temperature. I thought for sure after going from the stock one to
aftermarket that I had ceramic coated, things under the hood weren't as hot.
I'd be interested in running a timed test and then shooting the headers and a couple different areas under the hood to see what it is compared to a stock car.
I have a laser thermometer if anybody wants to do their stock header and see what the real difference is.
In fact tomorrow, I will get it fully warmed up and then shoot the laser at the header and several parts under the hood and record it at like 1, 5 and 15 minutes
after it's off and report temps.
Done: Ambient temp here is 73 F, Inside my garage where I checked is 82 F. I couldn't get a 1 min reading as I had trouble finding the laser thermometer in time. At about 7 minutes after parking, I could wrap my hand around the header and keep it there without taking it away. The temps on the header where all the places I could aim the laser at. That plastic boxer piece at the top of the engine is still warm to the touch right now and actually went up in temp after I closed the hood and just opened it back up now to get one last reading at 30 min(126 F) and the header feels slightly above garage temperature in some spots but is (100-110 F).
The Following User Says Thank You to Impureclient For This Useful Post:
lamawithonel (06-20-2020)
Anyone know the typical temps on the OEM header heat shield? canyons Engine, Exhaust, Transmission 5 08-07-2019 04:24 PM
Ceramic Coat Or Heat Wrap For Turbo Setup nearvincent Forced Induction 10 06-20-2017 11:25 PM
OFT + Gruppe S UEL header with heat shield, Berk front pipe Smough Engine, Exhaust, Bolt-Ons 8 05-11-2017 02:17 PM
Mounting aftermarket header. Do i have to wrap/ ceramic coat for heat protection? giorgi0424 Engine, Exhaust, Transmission 9 03-03-2017 08:58 PM
Stock heat shield vs Ceramic coated? deuncos Engine, Exhaust, Transmission 29 02-29-2016 06:12 PM
