Old 10-31-2019, 12:49 AM   #1
cat94
Drives: '17 86
Squeaky clutch pedal. Where to lube?
Hi all,
My 2017 has recently developed a squeaky clutch pedal. I'm pretty certain that the noise is coming from the clutch pedal assembly itself, and I was wondering if anyone had any tips on where/how to lube it.
I previously a really bad and loud squeak that could be heard from outside, and ended up having the throwout bearing replaced under warranty. This noise is much quieter, and localized to the footwell.
cat94 is offline   Reply With Quote
The Following User Says Thank You to cat94 For This Useful Post:
humfrz (10-31-2019)
Old 10-31-2019, 01:10 AM   #2
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
BlOody_BoOger is offline   Reply With Quote
Old 10-31-2019, 01:19 AM   #3
Originally Posted by cat94 View Post
Hi all,
You might try lubricating the clutch fork.
Quick & dirty: from @Ultramaroon
1. Detach the slave cylinder. Leave the hydraulics alone.
2. Remove the dust boot from the fork.
3. Reach down behind the fork with a finger and feel for the pivot. It's going to be tight because of the retaining clip.
4. Squeeze a decent glob of Lucas Red & Tacky #2 in there with your finger.
5. Jiggle the fork to distribute the grease as much as possible. It'll work in more on its own.
6. Put a dab of grease in the top pivot where the slave pin goes.
7. Reassemble.
This is a common clutch mechanism squeak.
dhuang (10-31-2019), FT86Z (04-29-2020)
Old 10-31-2019, 04:26 AM   #4
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
This.
My '17 BRZ and other higher mileage 17+ cars I've come across developed a squeak on the clutch fork pivot -- It isn't the throwout bearing if you can still hear the squeak when the car is off.
Be generous when greasing and actuate the clutch fork a few times to ensure coverage. The squeak will come back if you use white lithium grease spray, so use something more robust.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
The Following User Says Thank You to dhuang For This Useful Post:
humfrz (10-31-2019)
Old 10-31-2019, 12:18 PM   #5
cat94
Drives: '17 86
If the noise is coming from the clutch fork, will I be able to hear it distinctly from the engine bay?
Old 11-04-2019, 07:22 PM   #6
vladniko86
vladniko86's Avatar
Drives: FRS
7. Reassemble.
This right here. Had the same exact issue, had to lube both spots decently. I just pulled the slave pin out and dipped the whole thing in lube and put it back together. As well as that location inside the trans behind the fork. Depressed the pedal like 10 times after and haven't heard it since. Was ready to drop the trans and switch the TOB too
vladniko86 is offline   Reply With Quote
The Following User Says Thank You to vladniko86 For This Useful Post:
humfrz (11-04-2019)
Old 11-04-2019, 08:03 PM   #7
You can also hear it from the cabin, especially if the engine isn't running.
Old 11-04-2019, 08:05 PM   #8
Thank ol @Ultramaroon -
Ultramaroon (11-04-2019)
Old 04-12-2020, 07:23 PM   #9
cat94
Drives: '17 86
This post is a little old now, but I finally figured it out.
This is a video of a WRX that was having the same issue. I was skeptical that it would work, because the 86 doesn't have a rubber boot like in the video, but sure enough after smearing a bunch of grease on this ball joint looking thing the squeaking was gone!
Old 04-14-2020, 03:04 AM   #10
That's just wrong. Please see the service manual for more info. You are applying grease to the open end of the master cylinder. The actual working parts are buried underneath that washer and retaining clip.
edit: I was wrong! Maybe that IS a source of noise! I had even posted an image from the manual years ago in that thread I found below. ~facepalm~
Old 04-14-2020, 04:40 AM   #11
Compelica
Compelica's Avatar
Drives: 86 GT
7. Reassemble.
I don't suppose there's a post with detailed instructions and pretty pictures in it?
Compelica is offline   Reply With Quote
Old 04-14-2020, 03:22 PM   #12
Found it.
https://www.ft86club.com/forums/show...17#post2854717
Old 04-14-2020, 03:28 PM   #13
Not wrong at all depending upon the source of the squeak. MY squeak was the shaft of the master and putting some light grease on the shaft and working it down into the seal did indeed eliminate it. It has also worked for at least 3 other people I walked through it.
PerCompLLC (08-30-2024), Ultramaroon (04-14-2020)
Old 04-14-2020, 03:50 PM   #14
ls1ac
ls1ac's Avatar
I had a pedal squeak and used a non drippings garage door lubricant up under the dash and stopped it.
edit: more like a creaking of an old door than a squeak.
The Following User Says Thank You to ls1ac For This Useful Post:
Squeaky Clutch Noise, Help? Jfheisenberg Engine, Exhaust, Transmission 9 08-16-2018 11:51 AM
How I fixed my squeaky clutch jacjac3 Issues | Warranty | Recalls / TSB 40 09-27-2017 10:35 PM
Squeaky Clutch when depressed! oppiee Issues | Warranty | Recalls / TSB 29 09-01-2016 07:01 PM
squeaky clutch issue bhbnuckle Issues | Warranty | Recalls / TSB 3 06-27-2016 03:58 PM
Squeaky clutch V1B Engine, Exhaust, Transmission 24 06-16-2016 03:48 AM
