#71 |
Dismember
Drives: 2013 Red Scion FR-S
Yes, true. True. Historically higher HP street cars (big engine and heavy) were ones that couldn't corner, and lower HP (small engine and light) were ones that could. Modern tech has changed that a lot for street cars.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | Lantanafrs2 (10-29-2019) |
#72 |
Drives: '13 FRS - STX
So because of this thread I almost bought this car tonight, but it'd be a downgrade from my wife's current DD so I couldn't justify it, neat car if you're into RWD, 2JZ's, double wishbones, factory LSD's, and hatchbacks. It's a driver, but the owner was very accommodating, wants it to go to an enthusiast.
https://sfbay.craigslist.org/pen/cto...992136247.html
#73 | |
| The Following User Says Thank You to funwheeldrive For This Useful Post: | strat61caster (10-30-2019) |
#74 |
Database error
I can't think of a single reason for not to buy an Ariel Atom, if you can.
This one is a bargain. It only has 1 digit more, wouldn't be so much trouble.. https://www.ebay.com/itm/2016-Ariel-...wAAOSwCN5dnMzo |
| The Following User Says Thank You to korhun For This Useful Post: | Ultramaroon (10-30-2019) |
#75 |
If I had space to keep 4 cars I would have bought it as a more comfortable 'beater' DD than my FR-S just because.
#76 |
Drives: Crapcan
#77 |
Database error
| The Following 3 Users Say Thank You to korhun For This Useful Post: |
#78 |
Drives: Crapcan
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | korhun (10-30-2019), Ultramaroon (10-30-2019) |
#79 |
Database error
#80 | |
id be very surprised if the only reason to buy an 86 over a miata was practicality on this board. definitely a valid reason though. the most valid probably.
Drive upgrades. Don't buy them.
| The Following User Says Thank You to fatoni For This Useful Post: | strat61caster (11-01-2019) |
#81 | |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
I *VERY* specifically DON'T want a ragtop, articulated hardtop, sunroof, moonroof or ANY holes above my head. The stupid hole for the AM/FM radio gives me the willies! (edit: heebie jeebies is a racist meme. I'm ashamed for having used it without thinking.) It's wet, janky and yuk up here all the time and everyone should go somewhere else. There.
"I gotta rock." -- Charley Brown Last edited by bcj; 07-25-2020 at 11:36 AM. |
| The Following User Says Thank You to bcj For This Useful Post: | funwheeldrive (11-02-2019) |
#82 | |
Drives: '06 AM V8V Coupe
If this is the last of its kind, one day when the cars are under 10k I would consider welding a partial roll cage and using a bikini top since that makes it just as light and rigid as a real roof, but I can't do that to a new-ish car. |
#83 |
Drives: 2020 Toyota 86
I sold my nearly perfect RX8 with 44k miles for $7500, I'd hunt for another one. The 86 is the closest thing I could find to that car, I loved it and should have kept it.
#84 |
| Bad ball joint;possible to just replace balljoint or do I have to replace control arm | kev0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 01-03-2019 03:07 PM |
| What to replace... | Skeneypoo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 06-21-2018 03:02 PM |
| Have to replace entire assembly to replace fuel filter? | tobkin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 08-04-2017 02:26 PM |
| To replace rims or not replace? | unlimited86 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 23 | 09-21-2015 12:12 PM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 02:36 PM |
