Old 06-20-2018, 12:52 PM   #1
Skeneypoo
Skeneypoo's Avatar
What to replace...
My BRZ just hit 90,000 miles and it's feeling pretty beat.
I can hear the axles clicking in the rear, so I'll have to replace those..but in the front, this is what's driving me crazy...thoughts? (I have BC BR Coilovers).
I haven't searched and haven't checked if anything is loose. Am hoping to get some input before throwing her up on the lift.
Skeneypoo is offline   Reply With Quote
Old 06-20-2018, 12:56 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
How many of the 90,000 miles have you had the BC's installed?
I LIKE TIRES!
Old 06-20-2018, 12:59 PM   #3
humfrz
YIKES! I'd strongly suggest you get it up on a rack and tighten whatever is loose, before you drive it much further …
humfrz
Old 06-20-2018, 01:20 PM   #4
Skeneypoo
Skeneypoo's Avatar
Hmmm, 20k?
Old 06-20-2018, 01:21 PM   #5
Skeneypoo
Skeneypoo's Avatar
humfrz
Yeah, my assumption is that i'll need new sway bar endlinks or something off the sort..just wanted to see if people have experienced anything like it before.
The Following User Says Thank You to Skeneypoo For This Useful Post:
humfrz (06-20-2018)
Old 06-20-2018, 01:25 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Hmmm, 20k?
Unless you have your car as low as possible, the coils should last a bunch more miles.
I agree with @humfrz Check everything out to see if anything is loose.
I LIKE TIRES!
humfrz (06-20-2018)
Old 06-20-2018, 02:19 PM   #7
humfrz
Sounds like this guys last words, before he crashed...
humfrz
Old 06-21-2018, 11:25 AM   #8
Skeneypoo
Skeneypoo's Avatar
humfrz
These cars are lacking in everything except safety standards. I'll be fine, thanks.
humfrz (06-21-2018)
Old 06-21-2018, 11:27 AM   #9
You are the only one on the road in your area?
Old 06-21-2018, 11:34 AM   #10
Skeneypoo
Skeneypoo's Avatar
Old 06-21-2018, 11:59 AM   #11
Skeneypoo
Skeneypoo's Avatar
Some bastard stole my windshield wipers the other day, so apparently not.
Tcoat (06-21-2018)
Old 06-21-2018, 12:02 PM   #12
Well the black market demand is way up!
Can't see your pics since they appear to be blocked so what did you find?
Old 06-21-2018, 12:40 PM   #13
Skeneypoo
Skeneypoo's Avatar
Endlinks are shot on both sides, sway bar bushings look a little wet, but not torn or cracking. No play in the wheels and everything is tight. Wheel bearings COULD be starting to go...doesn't seem likely though.
Also my axles are clicking a bunch, time for replacement i presume.
Old 06-21-2018, 01:20 PM   #14
strat61caster
strat61caster's Avatar
Replace the axle nuts before you assume you need new axles, they go soft and allow a bit of slop (that can't be felt by hand). The other cheap thing is the parking/e-brake needing to be lubricated, noticeable if there's clicking getting in and out of the car with the e-brake engaged.
ineedyourdiddly
Tcoat (06-21-2018)
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 02:26 PM
When do you replace your tires? housecat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-29-2016 07:02 PM
To replace rims or not replace? unlimited86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 23 09-21-2015 12:12 PM
Better Mic to replace OEM Mic in BRZ / FRS ??? Zgrinch Electronics | Audio | NAV | Infotainment 42 02-06-2015 01:19 AM
Looking to replace my sedan carbonBLUE Other Vehicles & General Automotive Discussions 5 01-11-2013 08:41 PM
