Old 10-22-2019, 08:44 AM   #29
TunaNoCrust
TunaNoCrust's Avatar
Drives: 86, 981S, RX8, 2500HD, GenesisV8
I am regularly over 270F, probably close to 290F more than a few times, but I rarely check. Also, thanks for the coolant gage tip!
TunaNoCrust is offline   Reply With Quote
Old 10-22-2019, 10:17 AM   #30
Semiihcircle
Drives: 17 BRZ
Yeah anyhow i recently purchased and installed the Jackson racing oil cooler now my oil temps are perfect during autox and extended highway driving
Sent from my SM-G973U1 using Tapatalk
Semiihcircle is offline   Reply With Quote
Old 10-22-2019, 11:15 AM   #31
tfp
tfp's Avatar
Drives: 2017 BRZ WRB with PP
Semi, what kind of oil are you using? Debating on switching from subaru 0-20 to a 0-30 or 0-40.
Sent from my SM-N960U using Tapatalk
tfp is offline   Reply With Quote
Old 10-22-2019, 11:42 AM   #32
Semiihcircle
Drives: 17 BRZ
0-20 but im NA
Old 10-22-2019, 11:43 AM   #33
Semiihcircle
Drives: 17 BRZ
I only ever get that high when I'm on extended highway trips above 3500rpm or during autox
The Following User Says Thank You to Semiihcircle For This Useful Post:
tfp (10-22-2019)
Old 10-23-2019, 02:39 PM   #34
goldenfri
goldenfri's Avatar
Drives: 2017 BRZ Limited PP
Send a message via AIM to goldenfri
Personally, I wouldn't be worried unless it goes over 270. Mine '17 is stock and IIRC I've gotten it up to where yours was on the tail of the dragon, driving hard etc. Quality oils can handle 250-270 just fine with out too much degradation. If you daily it, I would be more concerned about oil taking too long to warm up if you get an oil cooler. If you are really worried just change the oil at shorter intervals.
goldenfri is offline   Reply With Quote
The Following User Says Thank You to goldenfri For This Useful Post:
DaBoBo21 (10-24-2019)
Old 10-23-2019, 03:12 PM   #35
Semiihcircle
Drives: 17 BRZ
I would too, but i don't daily and only drive it in the summerish months
Old 10-29-2019, 06:16 PM   #36
tfp
tfp's Avatar
Whoa! That's crazy hot!
Old 10-29-2019, 08:39 PM   #37
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Knock Knock.... Do somthing about it
Old 10-29-2019, 11:38 PM   #38
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
WTF? Do you redline it everywhere you go, or only drive in the extreme heat? O_o
MS, CSCS, TSAC-F, CPT
Old 10-31-2019, 07:20 AM   #39
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Originally Posted by alphasaur View Post
Boost exacerbates the issue. Stock I hit near 220 during autocross and I space out my runs to cool down.
220 is normal operating temperature and perfectly fine.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
Grady (10-31-2019)
Old 10-31-2019, 12:15 PM   #40
TunaNoCrust
Its really only ever on the track, and on the street I have no idea what it does. I will try to remember to check when I bring it to the dealership.
Its warrantied I have an oil change appointment coming up and am going to see what they say...I bet I can guilt them into putting an oil cooler in.
Old 11-01-2019, 05:36 PM   #41
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
I hit 220F driving in stop and go traffic, and 230F sometimes just driving in the winter.....but 2014 with "oil cooler" forester mod.
0w-30. 250F is high but I'm just adding anecdotal evidence.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 11-01-2019, 06:33 PM   #42
norcalpb
norcalpb's Avatar
It’s not a degradation of the oil, it’s the reduction in oil pressure that is a problem.
Also most oil coolers have a thermostat that won’t open until 185F, so the engine warms up as normal.
Engine Oil Temps after Oil Cooler ryoma Engine, Exhaust, Transmission 31 03-23-2016 09:21 PM
Air temps and impact on engine load brn12345 Software Tuning 0 04-30-2014 02:50 PM
Boxer engine and temps SlinkyAvalanche Engine, Exhaust, Transmission 9 03-27-2014 03:00 PM
Reducing engine compartment temps mike_ekim1024 Engine, Exhaust, Transmission 1 12-11-2013 02:57 AM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
